  • 7844阅读
  • 25回复
长期为广大HAM提供丽台和HOLUX的GPS OEM板 [复制链接]
离线wangjia1975
只看楼主 倒序阅读 0楼 发表于: 2005-01-01
gr-85 gps receiver module
     mmcx active and connetor
j1 connetor
     mcx active and connetor j1 connetor
      main features
      sirf star ii/lp (low power) chipset with embedded arm7tdmi cpu available for customized applications in firmware。
      12 parallel satellite-tracking channels for fast acquisition and reacquisition。
      compact size( only 25.4*25.4*6.8mm, include rf shield and connector)。
      high speed signal acquisition using 1920 time/frequency search channels。
      built-in waas/egnos demodulator。
      low power consumption with advanced trickle-power and push-to-fix mode。
      optional rechargeable battery for memory and rtc backup and for fast time to first fix(ttff)。
附件: 新建 Microsoft Word 文档 (2).doc (0 K) 下载次数:323
离线wangjia1975
只看该作者 1楼 发表于: 2005-01-01
和一元的硬币差不多大小!
附件: holux gps oem.rar (0 K) 下载次数:226
离线wangjia1975
只看该作者 2楼 发表于: 2005-01-01
tracking devices/systems and mapping devices application。
      products list
model no.      output
level      back-up battery
type      power
saving
     ttl or rs-232      lithium
gm-85-t0x      ttl      y      y
      specifications
snap start      < 3 sec (at < 25 minutes off period)。
hot start       8 sec(typ)。
warm start       38 sec(typ)。
cold start       45 sec(typ)。
satellite reacquisition time accuracy      100 ms。
channels      12 satellites。
position accuracy      25m cep without sa。
receiver      l1, c/a code。
protocol      nmea-0183 v2.2, 4800, 8, n, 1, gga, gsa, gsv, mc.(vtg , gll, rms option) or sirf binary。
maximum altitude      < 18,000 m (60,000 feet)。
maximum velocity      < 515 m (700knote)。
max. update rate      1 hz。
rf connector      mmcx。
interface      rs232 or ttl level。
dimension      25.4mm(l)x25.4mm(w)xxxmm(h)。
weight      xxg。
firmware upgrade      flash memory for programming software available。
time mark      output 1 pulse/sec, aligned with gps time +/ -0.1 usec。
operating temperature      -40 to +85 。
storage temperature      -45 to +100 。
operating humidity      5% to 95%, no condensing。
&#61550;      electrical specifications:
less than 70ma (without antenna )。
&#61550;      output terminal and definition :
6 pin header (2.0mm pitch).
j1 connector pin definition:
pin      pin name      function description
1      vcc_5v      +3.5~5.5vdc power input
2      txa      serial data output port a
3      rxa      serial data input port a
4      rxb      serial data input port b
5      gnd      power ground
6      timemark      1pps time mark output
1.      vcc_5v: +3.3 ~ 5.5v dc voltage input.
2.      dual communication channel ttl levels with user selectable baud rates (4800-default, 9600, 19200, 38400).
txa: main serial output. this output provides navigation data to user written software.
rxa: main receive channel. this input is used to receive software commands to the gm-85 from user written software.
rxb: auxiliary receive channel. this input is used to receive serial differential gps data.
3.      timemark: this pin provides one-pulse-per-second output from the gm-85 board, which is synchronized to gps time. this is not available in trickle-power mode.
附电路图1:
电路2:
电路3:
离线radiolee
只看该作者 3楼 发表于: 2005-01-05
没有报价?js?
只看该作者 4楼 发表于: 2005-01-05
王嘉,这个有没有10兆频标的输出?
只看该作者 5楼 发表于: 2005-01-05
有配套的天线吗?手册上说是有源天线。
离线wangjia1975
只看该作者 6楼 发表于: 2005-01-06
对有天线!为有需要的朋友提供!
只看该作者 7楼 发表于: 2005-01-06
怎么也不说要多少银子呀?
离线wangjia1975
只看该作者 8楼 发表于: 2005-01-06
400含进口有源天线!
离线BD7PA
只看该作者 9楼 发表于: 2005-01-12
这个价格作为gps oem全新品,有着如此微型的体积,还要是最新式的 sirf 芯片 support (xtrac firmware) 、还送有源天线(可以改隔离天线),bd7pa烧了这么多年gps,说句实在的话:“才400元,值~~!”
离线BD7CE
只看该作者 10楼 发表于: 2005-01-12
是否包含接头和天线? 最好也上张照片看看。
输出电平 ttl or rs-232,是指本身就可以通过设置程序修改,还是
要选择不同型号?
离线BD6CR
只看该作者 11楼 发表于: 2005-01-12
这个模块的输出接口是ttl的居多,mmcx天线接头。
离线BA7IX
只看该作者 12楼 发表于: 2005-01-12
真的么?
嘿嘿
我不说
打死也不说
离线BG7IMJ
只看该作者 13楼 发表于: 2005-01-12
真的么?
嘿嘿
我不说
打死也不说
只看该作者 14楼 发表于: 2005-01-12
真的么?
嘿嘿
我不说
打死也不说
虾米意思?
离线wangjia1975
只看该作者 15楼 发表于: 2005-01-12
要选择不同型号?
是包含接头和天线!过两天再上图.
离线wangjia1975
只看该作者 16楼 发表于: 2005-01-12
真的么?
嘿嘿
我不说
打死也不说
对啊,什么意思?不妨在这里说啊!如果你能找到性价比更高的,我还可给你定不少呢!
离线wangjia1975
只看该作者 17楼 发表于: 2005-01-12
对!是sirf 二代的!可直接代丽台,gamin的一些型号!
离线bg7ida
只看该作者 18楼 发表于: 2005-01-12
能手持吗??????????
离线BD7PA
只看该作者 19楼 发表于: 2005-01-14
楼上把我乐的,只要你喜欢,当然可以手持~~~~
ttl还是cmos电平,各有应用群,但是之间可以轻易互转。
如果用于联接掌上电脑,ttl是不二的选择,因为掌上电脑极大部份都是ttl电平串口,cmos电平适用于连接常规串口电脑,电平转换器可以使用约5元钱的高档专用转换芯片,要价格低廉嘛,几个三极管也可以。
