  • 5629阅读
  • 11回复
为什么RF电路的特性阻抗大多选择50欧姆? [复制链接]
离线BD4OS
只看楼主 倒序阅读 0楼 发表于: 2003-09-27
the history of 50 ohms
a lot of people ask, so here's the answer to the eternal question, "how did 50 ohms get to be the standard rf transmission line impedance?" here are a few stories. bird electronics will send you a printed copy of their version if you ask for it. this from harmon banning of w.l. gore & associates, inc. cable:there are probably lots of stories about how 50 ohms came to be. the one i am most familiar goes like this. in the early days of microwaves - around world war ii, impedances were chosen depending on the application. for maximum power handling, somewhere between 30 and 44 ohms was used. on the other hand, lowest attenuation for an air filled line was around 93 ohms. in those days, there were no flexible cables, at least for higher frequencies, only rigid tubes with air dielectric. semi-rigid cable came about in the early 50's, while real microwave flex cable was approximately 10 years later.somewhere along the way it was decided to standardize on a given impedance so that economy and convenience could be brought into the equation. in the us, 50 ohms was chosen as a compromise. there was a group known as jan, which stood for joint army and navy who took on these matters. they later became desc, for defense electronic supply center, where the mil specs evolved. europe chose 60 ohms. in reality, in the us, since most of the "tubes" were actually existing materials consisting of standard rods and water pipes, 51.5 ohms was quite common. it was amazing to see and use adapter/converters to go from 50 to 51.5 ohms. eventually, 50 won out, and special tubing was created (or maybe the plumbers allowed their pipes to change dimension slightly).further along, the europeans were forced to change because of the influence of companies such as hewlett-packard which dominated the world scene. 75 ohms is the telecommunications standard, because in a dielectric filled line, somewhere around 77 ohms gives the lowest loss. (cable tv) 93 ohms is still used for short runs such as the connection between computers and their monitors because of low capacitance per foot which would reduce the loading on circuits and allow longer cable runs.volume 9 of the mit rad lab series has some greater details of this for those interested. it has been reprinted by artech house and is available.
离线BD7BS
只看该作者 1楼 发表于: 2003-09-27
他就这脾气
离线BD3RJ
只看该作者 2楼 发表于: 2003-09-28
7bs给翻译一下?
离线BG4-2-12747
只看该作者 3楼 发表于: 2003-10-01
仔细看了一下,没看懂。
离线bd2oc
只看该作者 4楼 发表于: 2003-10-04
:d
离线bd4jp
只看该作者 5楼 发表于: 2003-10-04
嘻嘻,译的好玩。
离线ncradio
只看该作者 6楼 发表于: 2003-10-04
呵呵!是用翻译软件翻译的吧?
离线oneyan
只看该作者 7楼 发表于: 2003-10-05
定是计算机翻译的.
离线鹰击长空
只看该作者 8楼 发表于: 2003-10-31
看不懂,说的是什么
离线BG7PMZ
只看该作者 9楼 发表于: 2003-11-02
离线BG7TBL
只看该作者 10楼 发表于: 2004-01-27
有线电视为什么要用75鸥?
离线火腿蛋
只看该作者 11楼 发表于: 2004-01-27
bd2oc好象军语密码
