  • 2296阅读
  • 7回复
FCC Exam [复制链接]
离线BA1AJ
只看楼主 倒序阅读 0楼 发表于: 2022-09-21
考虑11月下旬或12月在北京考一场。有想考的请发邮件ba1aj@163.com
报名前要做的事情:
1. 解决美国本土邮寄地址(如果没有地址清联系我);
2. 在FCC的CORES系统上注册账户(方法见下个帖子);
3. 用第1步的美国本土地址注册FRN(方法见下面第二个帖子);
4. 将第2部注册的账户与FRN关联;
5. 发邮件给ba1aj@163.com,告知姓名、住址、电话、微信(或/和QQ)、FRN、美国呼号(如有)
有关注册方法,FCC网站上由引导视频可以参考。
[ 此帖被BA1AJ在2022-09-21 16:06重新编辑 ]
离线BA1AJ
只看该作者 1楼 发表于: 2022-09-21
注册 FCC FCC账户的步骤
建议看有图的QQ群FCC EXAM及FCC EXAM 2中的群共享。此处不能加附件。
Register New FCC Username Account provides guidance on how to create a Username Account for an individual in the updated FCC Commission Registration System (CORES). Once an individual has a username, it can be used to link existing or new FCC Registration Numbers (FRNs) to the Username Account.
1. Access CORES from the FCC Registration - Login page at this link:
https://apps.fcc.gov/cores
2. From the FCC Registration - Login page, click the “REGISTER” link under “Need a Username?” See Figure 1 below.
Figure 1
3. Fill in the requested information; items noted with an * indicate required information. Then click “Create Account”. See Figure 2 below.
Note: Enter a valid email address in the “Username” and “Confirm Username” fields. This email address will be used as your username when logging in to the FCC User Registration System and other systems using an FCC Username Account. Any notifications relating to your Username Account will be sent to the email address provided.
Note: To ensure the email address you provide as a username is available, click “Check Availability” to the right of the “Username” field before entering additional information. Your email address may only be used once. If it has already been registered, you will be notified that the Username is not available.
Note: The Password must be 12 to 15 characters long, cannot include any part of your Username, and must meet all of the following criteria: 1 lower case letter, 1 upper case letter, 1 number, and 1 punctuation mark/special character.
Figure 2
4. Your FCC Username Account has been created and you will be directed to a Create New Account - Confirmation page. See Figure 3 below.
Note: Your FCC Username Account will not be activated until you have verified the email address provided (please see steps 5-7).
Note:提交时需要翻*墙。
Figure 3
5. A confirmation email from FCCRegistration@fcc.gov will be sent to the email address provided as the username during the FCC Username Account creation. Access the email and follow the instructions within the email to activate your Username Account.
6. Click on the confirmation link in the email from FCCRegistration@fcc.gov to verify the email address and activate your FCC Username Account. See Figure 4 below.
Figure 4
7. You will be directed to the Email Address Verification page. This page confirms that your email address has been verified, and you may now access CORES using your username and password.
Note: An FCC Registration Number (FRN) is not automatically associated with your FCC Username Account. Click “Go to CORES” to access your Username Account and link an existing FRN to your Username Account or to register for a new FRN.
离线BA1AJ
只看该作者 2楼 发表于: 2022-09-21
注册 FRN FRN步骤
Register for a New FRN provides guidance on how to obtain a new FCC Registration Number (FRN) in the updated FCC Commission Registration System (CORES).
2. Under the “Username Login”, enter your registered Username and Password. Then click “LOG IN”. See Figure 1 below.
3. Click on the “Register New FRN” link.
4. Under “Are you registering as an entity or as an individual?” select “An individual”. Under “Is your contact address within the United States or its territories?” select either “Yes”. Click “CONTINUE”.
Note: If you are registering as an individual you will be asked to select either a CORES FRN Registration or Restricted Use FRN. Restricted Use FRNs can only be used for reporting individuals on Form 323 and Form 323-E. Unless you are registering an FRN to use on Form 323 and Form 323-E, please register a CORES FRN Registration.
5. Fill in the requested information; items noted with an * indicate required information. Then click “SUBMIT”.
6. You will be directed to the FRN Registration Confirmation page. This page confirms that you have successfully registered for a new FCC Registration Number (FRN).
Note: Don not forget choosing “The individual is foreign” as the answer to “If you do not have a Social Security Number, select a reason”.
Note: Since you are logged in to CORES with your FCC Username Account, this new FRN registration will automatically link the new FRN to your Username Account and will also make you the default Administrator of the FRN. To log into other FCC
systems that require FRN and password, this FRN can be used along with your Username-password.
离线bd4jk
只看该作者 3楼 发表于: 2022-09-24
T题库新的
BG4-2-066(1993年-        )
BG4JK(1996年-2000年)
BD4JK(2000年-        )
AF5QM(2014年-       )
bd4jk@163.com
杜新桐
QQ:526140674
TEL:13562826548
QTH:山东省新泰市青云路860号
新泰市中医医院  271200
GL:OM85VV
离线bd4jk
只看该作者 4楼 发表于: 2022-09-24
题库图片
附件: 2022-2026 Tech Graphics.pdf (55 K) 下载次数:8
BG4-2-066(1993年-        )
BG4JK(1996年-2000年)
BD4JK(2000年-        )
AF5QM(2014年-       )
bd4jk@163.com
杜新桐
QQ:526140674
TEL:13562826548
QTH:山东省新泰市青云路860号
新泰市中医医院  271200
GL:OM85VV
离线BA1AJ
只看该作者 5楼 发表于: 2022-09-26
回 bd4jk 的帖子
bd4jk:题库图片 (2022-09-24 23:41)
谢谢阿杜。QQ群里已经更新过了。
离线bg6vbm
只看该作者 6楼 发表于: 2022-09-30
回 BA1AJ 的帖子
BA1AJ:谢谢阿杜。QQ群里已经更新过了。 (2022-09-26 11:47)
有群号吗
RX/TX:急急急急急急急90s
出售XIEGU全隔离数字通联盒子,独立声卡,抗干扰,带发报线功能,一根线连接电脑。欢迎砸单
E-mail:nanami@yosoro.hk
离线BA1AJ
只看该作者 7楼 发表于: 2022-10-01
回 bg6vbm 的帖子
bg6vbm:有群号吗 (2022-09-30 21:10)
653454830
