Technical specifications:
•Continuous 24 – 1800 MHz RX range with no gaps
•3.5 dB NF between 42 and 1002 MHz
•Tracking RF filters
•35dBm IIP3 RF front end
•12bit ADC @ 20 MSPS (80dB Dynamic Range, 64dB SNR, 10.4 ENOB) – Yeah, size does matter.
•10MSPS IQ output
•Experimental 2.5MSPS IQ output for low power devices (Raspberry Pi, Odroid, etc.)
•Up to 80 MSPS for custom applications
•Cortex M4F @ up to 204MHz with Multi Core support (dual M0)
•1.5 ppm high precision, low phase noise clock
•1 RTC clock (for packet time-st a m ping)
•External clock input (10 MHz to 100 MHz via MCX connector) – Ideal for phase coherent radios
•10 MHz panoramic spectrum view with 9MHz alias/image free
•IQ or Real, 16bit fixed or 32bit float output streams
•No IQ imbalance, DC offset or 1/F noise at the center of the spectrum that plagues all the other SDRs
•Extension ports: 16 x SGPIO
•1 x RF Input (SMA)
•1 x RF Output (Loopthrough, U-FL)
•2 x High Speed ADC inputs (up to 80 MSPS, U-FL)
•4.5v software switched Bias-Tee to power LNA’s and up/down-converters
•No drivers required! 100% Plug-and-play on Windows Vista, Seven, 8 and 8.1
