  • 3041阅读
  • 3回复
DR-130 [复制链接]
离线BD4VNF
只看楼主 倒序阅读 0楼 发表于: 2003-02-21
我的dr-130收发频率为130-174,还能扩频吗?主要想收航空频段。
离线BG4RFF
只看该作者 1楼 发表于: 2003-02-21
here is the expanded tx mod for the alinco dr-130
open the top of the case by removing the three screws.
locate the blue and red loop of wire near the display, facing toward you.
cut the blue and red loop of wire, and tape up the ends.
red wire = rx and
blue wire= tx.
replace cover of the radio.
reset the radio by holding the function key down and turning on the power.
this modification has been read 3841 times.
top of page
add a comment
change display between frequency or channel
insted of seeing frequency display (147.585 etc.) you can have it read out like a business band radio (ch-1) by holding the vfo/m/w key and turning on the power.
离线BG7TBL
只看该作者 2楼 发表于: 2003-02-22
呵,要打开机壳
离线BD4VNF
只看该作者 3楼 发表于: 2003-02-22
bg4rff
谢谢老朋友,我试试看
