  • 2649阅读
  • 12回复
WIN-TEST升级后注册问题 [复制链接]
离线BA4XA
只看楼主 倒序阅读 0楼 发表于: 2009-08-08
刚注意到 wintest已经由v3升级到v4
现在有个问题 , 用v3的注册码发注册申请时 ,没有回应序列号
有人碰到这个现象吗?
离线BA4RF
只看该作者 1楼 发表于: 2009-08-08
写email去问吧
离线BA4XA
只看该作者 2楼 发表于: 2009-08-08
4rf 你装过wt4.0.1吗?  偶装了,好象起动不来 没有反应
离线bg2rje
只看该作者 3楼 发表于: 2009-08-08
q : what is the free upgrade policy applied from v3 to v4 ?
a : we apply an one-year free upgrade policy. it means that if you bought win-test v3 one year ago or less (june 26 2008 or later), you are eligible for a *free* upgrade to version 4. in all cases, if you are eligible, you will be notified by a private email to the adress you provided when you bought your wt 3 copy. then, you will be able to download, freely install and register your v4 copy. you can also consider to make a donation if you want. (contact sales@win-test.com)
离线BA4XA
只看该作者 4楼 发表于: 2009-08-08
回的序列号在垃圾箱里  刚找到
搞好了,关掉kaspersky就ok了
离线BA7NQ
只看该作者 5楼 发表于: 2009-08-08
我的wintest 3已经错过了免费升级的时间,只能upgrade...不过,暂时先不用v4,等再过多几个小版本的升级后再用。:-)
离线BA4XA
只看该作者 6楼 发表于: 2009-08-08
俺是去年十月买的,,刚好在一年免费升级里 :)
是不是意味着 wintest 4都不用再花钱升级,到v5再花钱 ?
离线BA7NQ
只看该作者 7楼 发表于: 2009-08-08
wintest目前的版本是4.0.1,还不是很稳定,大家使用前,务必对自己以前的wtb数据文件先进行备份!
以下是在wintest的mailing list上看到的邮件:
on mon, aug 3, 2009 at 6:59 am, posselt werner <w.posselt@maco.at> wrote:
unfortunately i just double clicked a .wtb file.
wt4 starts up and talks about converting it to .wt4 but after clicking ok you need a backup copy of the .wtb file otherwise you are out of luck.
the .wtb file has gone, and the .wt4 file grows until you kill win-test.
win-test version is 4.0.1.
isn't this the worst thing that can happen ?
73, werner / oe2wpo
yes, so i'm changing the subject line to try to get people's attention.
as you see, this also happened to w6xd, who lost his entire log. i searched everywhere on his hard disk, but could not find his original .wtb file anywhere. he had no cabrillo version to work with either.
i my opinion, everyone should just delete wt.exe (version 4.0.1). do not uninstall it, just delete the wt.exe file.
replace it with wt_dev.exe from:
  http://download.win-test.com/v4/nightly/wt_dev.zip
as the probem is fixed in that version.
in the mean time, if you have a cabrillo file or adif file, you should be able to reconstruct your log from that file. use file, import, cabrillo.
73,
bob, n6tv
离线BA4KW
只看该作者 8楼 发表于: 2009-08-08
回的序列号在垃圾箱里  刚找到
搞好了,关掉kaspersky就ok了  [表情]
咔吧死机太厉害 慎用
离线BA4RF
只看该作者 9楼 发表于: 2009-08-10
我看到v4.0.10已经出来了,跟我预计的一样,开始的几个版本肯定不那么稳定!
离线BA4XA
只看该作者 10楼 发表于: 2009-08-10
wintest版本是4.1.0 刚升了一下级 打上补丁
另外  好象原来v3的系列号已经不能用在v4了,虽然机器码还是一样
离线BD3RJ
只看该作者 11楼 发表于: 2009-08-15
那老大是如何注册上嘀?
离线BA4XA
只看该作者 12楼 发表于: 2009-08-15
那老大是如何注册上嘀?
付钱就能注册上啊
