  • 3805阅读
  • 9回复
K3软件更新,采纳了我的一个建议 [复制链接]
离线BA4RF
只看楼主 倒序阅读 0楼 发表于: 2009-06-19
k3 beta-test firmware revision 3.19 (with dsp rev. 2.17) is now
available. see release notes below.
please send problem reports to k3support@elecraft.com. beta firmware
load instructions can be found at
    http://www.elecraft.com/k3/k3_software.htm
73,
wayne
n6kr
mcu 3.19 / dsp 2.17, 6-14-2009
* power-related control lock: the pwr, mic, and cmp controls
can be locked by tapping Ƈ' in config:pwr_set. this is useful in
some contests, such as field day, where a carefully-set up k3 might be
used by multiple operators. accessing a locked control flashes "locked".
spd/delay/mon functions are still accessible. tapping a locked knob
still
displays the current parameter value, even though you can't change it.
* automatic cw vfo offset on mode change: allows switching
quickly between ssb and cw mode without either you or the other station
having to re-tune the vfo (often done on 6 meters and transverter
bands).
first, locate config:cw wght and tap ‘5’ on the keypad until you see
“vfo ofs”. from then on, when switching to cw mode from any other
mode, the vfo will be offset by an amount equal to your sidetone pitch
(as set using the pitch switch in cw mode). if the sideband most
recently
used on this band is usb, the vfo will be shifted up; if it was lsb, the
vfo will be shifted down.
note: if you make frequent use of this feature, you may want to
use cw reverse on bands where you use usb, and cw normal
on bands where you use lsb. this results in perfect pitch matching
when listening to a cw signal and switching from ssb to cw.
* ghz transverter digits are now shown for two seconds on any
band change, if applicable (i.e. if transverter frequency is set for >
999
mhz in menu entry config:xvn rf). this serves as a reminder of
the actual band in use, since the mhz digits alone can be ambiguous.
* am modulation: now closer to 100%.
* tuning vfo from one band to another with bands
mapped out: this no longer alters config:bnd map settings.
* synth unlock when using ptt/cw: when using ptt, cancelling
cw message play by tapping the key or keyer was sometimes causing the
synthesizer to unlock.
* cw sidetone stuck with ptt: when using ptt, cancelling cw
message play during a cw element was sometimes leaving sidetone on.
* 6m can be permanently disabled: this is required for some
countries. this would normally be done at the factory, but can also be
done in the field with a pc program (contact customer support if
interested).
* max power level now 110 w (was 120 w): this is intended
to reduce the possibility of excess kpa3 operating current on some
bands. this might have occurred when using a high power setting
along with low power supply voltage and/or a high load swr.
(note: the recommended maximum power setting is still 100 w.)
for software developers:
* monitor level (ml) command: mlxxx (000-060 where 000 is
off, in effect). applied per-mode.
* ic command now has a "tx msg playing" flag. byte "a" bit b2.
k3原本就有分波段功率控制的功能,每个波段可以设置不同的功率输出,例如160m输出20w,10m输出100w等。这主要是考虑到有些功放达到满功率所需要的推动功率不同,有这个功能后切换波段就不需要再调整功率了。
大概一个半月前,我在论坛上发了一个帖子,希望提供功率、mic设置等的锁定功能,这样能最大限度地减少偶尔犯错导致很严重的后果,尤其是在多人参加的比赛中。
elecraft显然是在仔细倾听用户意见的,今天他们release了一个新版本提供了这个功能。
离线BA0BZ
只看该作者 1楼 发表于: 2009-06-20
其实你需要的不是软件更加完善的k3,而是更加pro的amp……
离线BD3RJ
只看该作者 2楼 发表于: 2009-06-20
陈老大已经超越了amp的境界
拍拍马屁
离线7600
只看该作者 3楼 发表于: 2009-06-20
本坛有k3系统的探子?
离线BG4XNG
只看该作者 4楼 发表于: 2009-08-08
本坛有k3系统的探子?
应该是在米国的网站发的,以后我们也可以去发些中文建议,乱码急死那丫的……
离线BA4RF
只看该作者 5楼 发表于: 2009-08-08
不知道你现在能看帖子吗?
要不你写一个你梦想中amp的技术要求吧!
离线BA7EI
只看该作者 6楼 发表于: 2009-08-09
可惜国内套件尚未达到K2的水平
谁如果开发达到最廉价入门级商品电台功能和性能的机器,应当在操作功能方面应当向陈老大等大佬们讨教,amp方面应当向0bz,7kw等老大讨教。
离线BA4RF
只看该作者 7楼 发表于: 2009-08-09
现在我最期待的山寨货就是前段时间在坛里有人谈到的 山寨steppir天线了,经我验证此天线的效果确实不错。
离线BA7EI
只看该作者 8楼 发表于: 2009-08-09
天线开发属于高科技,阻抗匹配倒不是最难的,一台真正的天线分析仪____矢量网络分析仪就搞定,难的是要兼顾方向角和仰角,还有辐射效率等......山寨则仅仅是仿造尺寸和电抗网络即可
当然,山寨的天线想要达到原厂的水平所需要的恐怕不仅仅是无线电技术,耐候性比较难.
离线bg1iwk
只看该作者 9楼 发表于: 2009-08-09
dingqilai....
