  • 2750阅读
  • 1回复
科索沃成为新DXCC?-- 现在还不行 [复制链接]
离线BA4RF
只看楼主 倒序阅读 0楼 发表于: 2008-02-25
如果觉得累,就看最后一段:
kosovo and adding new countries to dxcc - bill moore, nc1l, arrl dxcc
manager, reports (on february 19th): "naturally there are many questions
about the dxcc status of kosovo, and whether or not it will be added to
the dxcc list.
  the dxcc rules, which were modified in 2000 to better handle inclusion
to dxcc, are clear on how additions can be made:
  for inclusion in the dxcc list, conditions as set out below must be
met. listing is not contingent upon whether operation has occurred or
will occur, but only upon the qualifications of the entity.
  political entities, geographical entities, special areas
  #1, political entities is the category with which we are concerned
    with respect to kosovo.
  1. political entities: political entities are those areas which are
    separated by reason of government or political division. they
    generally contain an indigenous population which is not pre-
    dominantly composed of military or scientific personnel.
    an entity will be added to the dxcc list as a political entity if
    it meets one or more of the following criteria:
    a) the entity is a un member state.
    b) the entity has been assigned a callsign prefix bloc by the itu.
      (the exceptions to this rule are international organizations, such
      as the un and icao. these entities are classified under special
      areas, 3.a); and ineligible areas, 4.b).) a provisional prefix
      bloc assignment may be made by the secretary general of itu.
      should such provisional assignments not be ratified later by
      the full itu, the entity will be removed from the dxcc list.
    c) the entity contains a permanent population, is administered by
      a local government, and is located at least 800 km from its
      parent. to satisfy the 'permanent population' and 'administered
      by a local government' criteria of this sub-section, an entity
      must be listed on either (a) the u.s. department of state's list
      of 'dependencies and areas of special sovereignty' as having a
      local 'administrative center,' or (b) the united nations list
      of 'non-self-governing territories.'
new entities satisfying one or more of the conditions above will be added
to the dxcc list by administrative action as of their 'event date.'
so, kosovo will be added to the dxcc list if it becomes a member of
the un, or (2), if it receives a prefix bloc from the itu. the third
condition does not apply. the date upon which either (a) or (b) occurs
will be the event date." bill moore spells it out even more in this
week's "arrl letter": "the 'event date' will be either the date kosovo
became a un member or it receives its prefix from the itu. contacts
made before the 'event date' will be counted as serbia."
参见:
http://www.hellocq.net/forum/showthread-t-169056&highlight=dxcc.明天(2月17日)将诞生一个新的dxcc实体.html
离线BG4DVK
只看该作者 1楼 发表于: 2008-02-25
parent.
上面这段挺有意思:d
