  • 476660阅读
  • 2180回复
如何建立自己的时间和频率基准? [复制链接]
离线TITAN-ZY
只看该作者 1380楼 发表于: 2008-12-19
由此可见,datum lpro铷钟跟先前测试的prs-c铷钟无论准确度还是频率稳定度,都差了一个数量级,不知预热24h后稳定度是否会好些
离线TITAN-ZY
只看该作者 1381楼 发表于: 2008-12-20
求帖子里面 提到的 timemonitor 软件,有的可以pm我.需要报酬也可以.
另外谢谢 titan-zy,帖子不错,希望我们可以有下次business.
timemonitor软件有100多m,文件太大,发不了。
离线bg4kc
只看该作者 1382楼 发表于: 2008-12-22
年底的闰秒事件预告。届时大家一起来观测吧。
utc time step
                  on the 1st of january 2009
a positive leap second will be introduced at the end of december 2008.
the sequence of dates of the utc second markers will be:
                2008 december 31,   23h 59m 59s
                2008 december 31,   23h 59m 60s
                2009 january   1,     0h 0m 0s
the difference between utc and the international atomic time tai is:
from 2006 january 1, 0h utc, to 2009 january 1 0h utc : utc-tai = - 33s
from 2009 january 1, 0h utc, until further notice     : utc-tai = - 34s
leap seconds can be introduced in utc at the end of the months of december
or june, depending on the evolution of ut1-tai. bulletin c is mailed every
six months, either to announce a time step in utc or to confirm that there
will be no time step at the next possible date.
                              daniel gambis
                              head
                              earth orientation center of iers
                                  observatoire de paris, france
离线BG2VO
只看该作者 1383楼 发表于: 2008-12-22
从日本买了一个seiko手表,双日历100年不用调、电池10年不用换、误差1年<20秒。
到手后用gps对比了一下,误差不到1秒。问题是我不知道从出厂到现在是多长时间了。
1年20秒,相当于0.63ppm。
离线TITAN-ZY
只看该作者 1384楼 发表于: 2008-12-23
很漂亮,我还以为是机械表呢!
离线bg4kc
只看该作者 1385楼 发表于: 2008-12-25
100年不调要不要戴在手上? 最近看了一个ds3231的rtc芯片,有类似温度补偿技术。
甚至还能输出温度值。看看能不能达到这个精工手表的程度?
下面是它的手册文字:
accuracy ±2ppm from 0°c to +40°c
accuracy ±3.5ppm from -40°c to +85°c
battery backup input for continuous
timekeeping
operating temperature ranges
commercial: 0°c to +70°c
industrial: -40°c to +85°c
low-power consumption
real-time clock counts seconds, minutes,
hours, day, date, month, and year with leap year
compensation valid up to 2100
two time-of-day alarms
programmable square-wave output
fast (400khz) i2c interface
3.3v operation
digital temp sensor output: ±3°c accuracy
register for aging trim
rst output/pushbutton reset debounce input
underwriters laboratory (ul) recognized
离线bg4kc
只看该作者 1386楼 发表于: 2008-12-25
the ds3231 is a serial rtc driven by a temperature-
compensated 32khz crystal oscillator. the tcxo pro-
vides a stable and accurate reference clock, and
maintains the rtc to within ±2 minutes per year accu-
racy from -40°c to +85°c.
the change in ppm per lsb ..........................at +25°c, one lsb
ypically provides about 0.1ppm change in frequency.
离线Jambalaya
只看该作者 1387楼 发表于: 2008-12-25
58540a(锁定1小时后):
离线BG2VO
只看该作者 1388楼 发表于: 2008-12-26
这个ds3231的rtc芯片看来不错,但好象与手表的这个还不太一样。手表的工作温度范围窄,但精度更高些、功能弱。
离线STARLHL
只看该作者 1389楼 发表于: 2008-12-28
都比我的强啊,高精度=高价钱
离线世纪
只看该作者 1390楼 发表于: 2008-12-31
我的53131a有人收吗? 带原厂3g选件
离线ZOO
只看该作者 1391楼 发表于: 2008-12-31
报价!
离线世纪
只看该作者 1392楼 发表于: 2008-12-31
图片在这个帖子的31页,价格不方便说这里讨论技术不做交易!
离线TITAN-ZY
只看该作者 1393楼 发表于: 2009-01-05
哪位知道车载导航等用的gps天线是什么样的?想买一些小型的gps天线,但没有资料。
离线TITAN-ZY
只看该作者 1394楼 发表于: 2009-01-09
今天冒险将datum lpro的铷泡给拆出来了,给大家看看!
离线bg1grn
只看该作者 1395楼 发表于: 2009-01-09
庐山真面目,还是你厉害。
离线bd1es
只看该作者 1396楼 发表于: 2009-01-09
啊?titan-zy真行,我可不敢取铷泡!
顺便地说,淘宝上面有很多您需要的gps天线,还有trimble的灰色磁吸小天线很好用,连线和插头大约20元一套,仅供参考。
离线BG7YDO
只看该作者 1397楼 发表于: 2009-01-10
我的天线是自己弄得,感觉还行,就是不能稳定收8颗星,不知道您的能稳定收几颗星?
离线TITAN-ZY
只看该作者 1398楼 发表于: 2009-01-12
^_^,我当时也是胆战心惊!以后再也不冒险了!
离线BG2VO
只看该作者 1399楼 发表于: 2009-01-13
铷只有轻微的beta放射性,也就是电子流,有玻璃泡隔离出不来的。即便打碎,这东西在空气中最多也就走100多mm。
真要是有放射性,那要严格监管的,印上大红字。
