  • 250933阅读
  • 864回复
DIY一台电子管HF功率放大器 [复制链接]
离线bv6fo
只看该作者 100楼 发表于: 2003-07-12
an 811-a 200-watt grounded-grid linear amplifier(one 811-a) (1,179,474 bytes, pdf file)
arrl handbook 1968, pp. 187-190
from http://i5uxj-2.cln.it/amp/schemi/pdf/68hb187.pdf
离线bv6fo
只看该作者 101楼 发表于: 2003-07-12
a table-top half kilowatt (two 811a) (3,111,439 bytes, pdf file)
qst january 1960, pp. 24-27, 156, 158
from http://i5uxj-2.cln.it/amp/schemi/pdf/6001024.pdf
离线bv6fo
只看该作者 102楼 发表于: 2003-07-12
the rcc 230-l amplifier (two 807s, 230 watts) (3,209,186 bytes, pdf file)
qst february 1963, pp. 29-32
from http://i5uxj-2.cln.it/amp/schemi/pdf/6302029.pdf
离线bv6fo
只看该作者 103楼 发表于: 2003-07-12
i 5 u x j
qro home made linear amplifier
hf amplifier
g.g. a falcon (ua6cl)   amplifier with gu74b
g.g. a falcon (ua6cl)   amplifier with gu78b
aag-bhpl           beautiful 4cx10000a amplifier
a. tarasov (ut2fw)   amplifier with gu74b
a. tarasov (ut2fw)   amplifier with 2x gu74b
v.kotel'va (ua9fad)     eme 2 meters 2x gu34b
(ua1zcl)                 eme 2 meters gu35b
(ua1oj)                 2 meters gu7b
oh3aww amp         linear amplifier 2 meter with gu84b
w6sai                 linear amplifier 2 meter with 3cx1500
dl4mea               linear amplifier 2 meter with gs35b
clank               hf linear amplifier with 2 3-500z
amp hf 3000 wattamplificatore lineare hf con parallelo di   2 4cx800
la0by           amplificatore lineare vhf con push pull 2 4cx250
sm5bsz               building high power amplifiers page
how to run your (tube type - ed.) linear (975,720 bytes, pdf file)
qst november 1962, pp. 11-14
what it can do and what it shouldn't do.
a single 6146 amplifier (one 6146, 70-90 watts) (1,392,201 bytes, pdf file)
arrl handbook 1959, pp. 196-198
an all-purpose 813 amplifier (one 813) (1,244,174 bytes, pdf file)
arrl handbook 1959, pp. 199-201
a medium-power tetrode amplifier (one 7094) (1,224,597 bytes, pdf file)
arrl handbook 1959, pp. 202-204
a compact 650-watt amplifier (two 4x250b) (2,091,734 bytes, pdf file)
arrl handbook 1959, pp. 205-209
4-250-a's in a 1-kw. final (two 4-250a) (2,648,850 bytes, pdf file)
arrl handbook 1959, pp. 210-214
a high-power grounded-grid amplifier and power supply (one 3-1000z) (2,139,553 bytes, pdf file)
arrl handbook 1968, pp. 199-204
one-band kilowatt amplifiers (two 813) (1,25/8,687 bytes, pdf file)
arrl handbook 1968, pp. 195-198
a compact 3-400z grounded-grid amplifier (one 3-400z) (1,308,857 bytes, pdf file)
arrl handbook 1968, pp. 191-194
an 811-a 200-watt grounded-grid linear amplifier (one 811-a) (1,179,474 bytes, pdf file)
using 2 3-500zs in grounded grid (1,351,014 bytes, pdf file)
arrl handbook 1971, pp. 201-204
a one-kilowatt amplifier using a 3-500z (675,237 bytes, pdf file)
arrl handbook 1972, pp. 182-186
the ss-2000 amplifier (one 3-1000z) (1,477,098 bytes, pdf file)
arrl handbook 1972, pp. 178-182
a sweep-tube linear amplifier (four 6kd6) (1,201,283 bytes, pdf file)
arrl handbook 1972, pp. 176-178
a 160-meter amplifier (two 572-b) (1,111,682 bytes, pdf file)
arrl handbook 1978, pp. 184-186
a conduction-cooled two-kilowatt amplifier (two 8873) (1,943,097 bytes, pdf file)
arrl handbook 1978, pp. 186-190
a two-kilowatt amplifier using the eimac 8877 triode (one 8877 or 3cx1500) (2,080,841 bytes, pdf file)
arrl handbook 1978, pp. 190-195
1500-w-output amplifier for 160 meters (3cx1500a7) (1,450,439 bytes, pdf file)
arrl handbook 1990, pp. 30-46 to 30-49
a legal-limit amplifier for 160 through 10 meters (8877) (3,168,225 bytes, pdf file)
arrl handbook 1990, pp. 30-50 to 30-57
a 160- to 10-meter amplifier using the 3cx1200a7 (2,080,071 bytes, pdf file)
arrl handbook 1990, pp. 30-58 to 30-63
the lka-1 linear amplifier (two 4cx250b) (3,005,289 bytes, pdf file)
qst june 1975, pp. 39-43, 158
commercial schematics:
kenwood tl922         kenwood tl922 shematics
yaesu fl 2100         yesu fl2100 shematics
离线cqdx
只看该作者 104楼 发表于: 2003-07-13
大力支持。
我也爱‘胆’。
离线bd6bm
只看该作者 105楼 发表于: 2003-07-13
回复: 回复: 用fu-7可以吗
最初由 香肠级火腿 发表
用fu-7可以,但是有点划不来,原因是功率太小
如果用广东的en21垃圾板,电压只给15v,出70w,随便你的天线开路短路,均无法烧毁
是eni 21大功率管。请问,能弄到这种管子吗?我需要两只。
离线bv6fo
只看该作者 106楼 发表于: 2003-07-14
离线bv6fo
只看该作者 107楼 发表于: 2003-07-14
离线bv6fo
只看该作者 108楼 发表于: 2003-07-14
离线BD7IWW
只看该作者 109楼 发表于: 2003-07-16
谢谢BV6FO
bv6fo所发的首两个贴子就是我前发不了的图文。有兴趣的朋友请下载。
接在811a灯丝电路的两个高频扼流圈电感量为10微亨,载流量为8安培。
离线bv6fo
只看该作者 110楼 发表于: 2003-07-18
another 4x811 ( known language )
离线bv6fo
只看该作者 111楼 发表于: 2003-07-18
one more 811x4 ( unknown language )
离线bv6fo
只看该作者 112楼 发表于: 2003-07-18
此图为 pl509x5 600 watts 之功放,该管与苏联管 6p45c 或欧美管 6kg6 相似, 由此图上可以看出 b+ 扼流圈采用磁环绕制, 原图未提到绕制方法及规格, 有那位前辈有此经验的请发表您的高见, 不知是否可以用开关电源输出滤波磁环直接代用 ?
离线bv6fo
只看该作者 113楼 发表于: 2003-07-23
kb9bpf's 811a amp - top view
离线bv6fo
只看该作者 114楼 发表于: 2003-07-23
kb9bpf's 811a amp - bottom view
离线bv6fo
只看该作者 115楼 发表于: 2003-07-23
some internal pictures of the ameritron al-811hxce
离线硅两瓦
只看该作者 116楼 发表于: 2003-07-24
最初由 bv6fo 发表
手工一流,不知成本多高,顶!
离线bv6fo
只看该作者 117楼 发表于: 2003-07-24
japanese 6m 811ax1 50w gg linear amp - 1
离线bv6fo
只看该作者 118楼 发表于: 2003-07-24
japanese 6m 811a 50w gg linear amp - 1
离线bv6fo
只看该作者 119楼 发表于: 2003-07-24
japanese 6m 811a 50w gg linear amp - 2
