  • 250932阅读
  • 864回复
DIY一台电子管HF功率放大器 [复制链接]
离线BD7IWW
只看该作者 80楼 发表于: 2003-07-08
bv6fo
能提供一个传真号吗?
离线BA3CE
只看该作者 81楼 发表于: 2003-07-10
811音频功放。
离线bv6fo
只看该作者 82楼 发表于: 2003-07-10
单管 811a 功放(俄文)
离线bv6fo
只看该作者 83楼 发表于: 2003-07-10
单管 811a 功放(e文) 175 watts
离线bv6fo
只看该作者 84楼 发表于: 2003-07-10
单管 811a 功放(e文) 50 mhz
离线bv6fo
只看该作者 85楼 发表于: 2003-07-10
单管 811a 功放(e文) 50 mhz - 2
离线bv6fo
只看该作者 86楼 发表于: 2003-07-10
811ax4 with pcb part 1/5
离线bv6fo
只看该作者 87楼 发表于: 2003-07-10
811ax4 with pcb part 2/5
离线bv6fo
只看该作者 88楼 发表于: 2003-07-10
811ax4 with pcb part 3/5
离线bv6fo
只看该作者 89楼 发表于: 2003-07-10
811ax4 with pcb part 4/5
离线bv6fo
只看该作者 90楼 发表于: 2003-07-10
811ax4 with pcb part 5/5
离线bv6fo
只看该作者 91楼 发表于: 2003-07-10
811ax6 1300w
离线bv6fo
只看该作者 92楼 发表于: 2003-07-11
811a bias
离线bv6fo
只看该作者 93楼 发表于: 2003-07-12
microwave oven application-1
离线bv6fo
只看该作者 94楼 发表于: 2003-07-12
离线bv6fo
只看该作者 95楼 发表于: 2003-07-12
microwave oven transformer application - 2 again
哈罗cq火腿社区 > 火腿技术区 > 设备 > 我是diy焊机派
离线bv6fo
只看该作者 96楼 发表于: 2003-07-12
microwave oven transformer application - 3
离线bv6fo
只看该作者 97楼 发表于: 2003-07-12
microwave oven transformer application - 4
离线bv6fo
只看该作者 98楼 发表于: 2003-07-12
811a with mot ( microwave oven transformer )
离线bv6fo
只看该作者 99楼 发表于: 2003-07-12
to do this you need a suitable high current transformer 12-0-12 volts which i am attempting to make from a scrap microwave oven transformer by replacing the high voltage secondary (removed with a hacksaw and hammer) with a few turns of much thicker wire to use as a primary. each turn gives about 0.78 vac, so i put on two lots of 15 turns (16 might have been better). safety warning. the working insides of a microwave oven are most definitely absolutely lethal, the transfomer of which can supply something like 300ma at 2000+ dc volts, with the chassis acting as ground return plus a smoothing capacitor that can stay charged for a long time. under no circumstances mess under the cover of a microwave oven if you don"t know what you are doing. finally, if you rewind a transformer you cannot use it from the mains again as you cannot guarantee that the insulation is satisfactory.
