  • 22642阅读
  • 152回复
Peter I---- 3Y0X on air [复制链接]
离线VR2KW
只看该作者 80楼 发表于: 2006-02-11
11 feb 2006 0030utc: conditions are still as previously reported. the skies were clear enough for the helicopter to take off, but the seas were still too rough to safely land back on the ship. so no progress today on that front. maybe tomorrow..
since the cqww rtty contest is just starting, we plan to spend all of our time on ssb and cw and in the warc bands while the contest is on.
our spirits remain high but we're eager to have the rest of the team with us (and the rest of our gear and supplies, too!)
离线VR2KW
只看该作者 81楼 发表于: 2006-02-11
不谢,不谢,我就是通知了你一下嘛。(log里面已经有你了)
同时恭喜 vr2kw ba4tb
好小子,你已经通了两个波段 ,看来你是中国第一牛人了
离线VR2KW
只看该作者 82楼 发表于: 2006-02-11
很难通,我收他们qsb,不知道他抄我呼号的7抄对了没有,连我自己都听不清,还59…… [表情]
感谢ba4rf!! [表情] 请4rf帮查查log。
哈哈,就连归隐的大佬都跑出来凑热闹了。 :d
离线bd7ni
只看该作者 83楼 发表于: 2006-02-11
夺锦标争上游嘛! :d
离线BA7JC
只看该作者 84楼 发表于: 2006-02-11
看来星期天不得不到基地一趟,把发电机发动起来...
听说你要加班做标书,不过还是抽时间去基地吧,明天杀头猪来招呼你
离线BA4RF
只看该作者 85楼 发表于: 2006-02-12
11 feb 2006      1645utc: good news! the weather cooperated and we were (finally) able to get our other three team members ashore along with all our remaining supplies and gear! we have all stations working and looking forward to an even higher qso rate from now on.
thanks to the internatlonal ham community for your patience while we sorted out the weather problems.
73 from the peter i team!
离线BA7NQ
只看该作者 86楼 发表于: 2006-02-12
12 feb 2006 0110utc: just to bring you up to date, yesterday morning at 0230utc the helicopter began flying again and brought ashore 8-9 loads and our three orphaned team members. starting again at 0900utc, he starting bringing the final 5-6 loads and finished around 1500utc. at that time we finally had a full complement of people, equipment and supplies. in the last load was the job johnny (outhouse) which was very gratefully received!
here's a rundown on the antennnas in operation now:
battle creek special for 160
wire antenna for 80
wire antenna for 75
two 40m verticals
20m vertical
17m two-element vertical
30m vertical
two steppir 2el yagis for 10-20m
tomorrow we'll have another 30m vertical and the two remaining steppir 2el yagis up.
we presently have six stations on the air and tomorrow afternoon will have all eight.
today we had beautiful views of the mountain; hopefully the weather will continue to clear.
note: we are presently adding the rest of the computers to the lan so there will be some delay in getting the logs uploaded; please be patient with us. the main web page always indicates the latest logs available so that should be your trigger to check to see if you're in it.
离线BA7NQ
只看该作者 87楼 发表于: 2006-02-12
岛上的第一批照片...
小图 | 大图 图片
  • 哈罗CQ火腿社区 - DX通信 - Peter I---- 3Y0X on air - 第5页
离线BA7NQ
只看该作者 88楼 发表于: 2006-02-12
现在14.023 cw听,信号55,这是这几天来最好的信号,可惜,老妈叫我去吃饭了,55555555
离线VR2KW
只看该作者 89楼 发表于: 2006-02-12
今晚去了吃盘菜,后来临时架设yp2 + ft897d,20米cw有589,ssb有55,但都是ja的天下。
离线BA7NQ
只看该作者 90楼 发表于: 2006-02-13
我昨天晚上8点-9点,听他的信号有539-579左右,叫了一个小时,徒劳无功。
离线BA4RF
只看该作者 91楼 发表于: 2006-02-13
12 feb 2006      2130utc: the team has spent the better part of the past 36 hours putting the gear that arrived yesterday on the air. we are now up to seven active stations and we'll get the 8th up by daybreak tomorrow. this is allowing operations on 12m and 10m while putting two stations on 40m.
we put up another 40m vertical today and all the steppirs are up now (both verticals and beams).
we can now man 30m virtually around the clock and we'll be watching for the lp european opening that occurs during the ja runs.
because we've been so intent on getting the inter-station lan up and running, we've been forced to neglect collecting the logs off each machine (or they would have been out of sync or worse, missing qs on the website). we found the network was also susceptible to rf and it took quite a few torriods (and time) to correct those issues.
now that the network is running well, we can finally pull the logs and upload to n1dg which will be done sometime tonight.
we know the dx community wants the online logs, but getting the island network running was judged more important for putting qsos into the logs than confirming ones already made.
we are about three days behind the island infrastructure plan due to the continuing challenges of bad weather.
thanks for your patience,
离线BA4RF
只看该作者 92楼 发表于: 2006-02-13
今天3y0x 30m 40m都有559的信号,copy没有问题,但可恨的是不知道那个没有业余精神的人对准这两个频率连续放n个小时的载波干扰,由于频率对得极准,基本没有办法对付它。唉....
离线BA4VE
只看该作者 93楼 发表于: 2006-02-13
20米的传播也不错 看到你发的公告去听了听 有559-599的信号
离线VR2VAC
只看该作者 94楼 发表于: 2006-02-13
恭喜vr2kw,在20m波段ssb呼叫到3y0x和vr2px在30m波段cw呼叫到3y0x。best 73 kevin vr2vac
离线BA6QH/QRP
只看该作者 95楼 发表于: 2006-02-13
看来17M/20M出来的比较多,不知40M出来的多不多?到现在还没戏~~~~
离线vr2cia
只看该作者 96楼 发表于: 2006-02-13
恭喜vr2kw,vr2px
from vr2cia
离线VR2KW
只看该作者 97楼 发表于: 2006-02-13
谢谢。
今天3y0x在30米和20米cw都有599的信号,苦战了数小时,一股作气都把他攻克了,到目前已经完成了预定的大目标。
离线BA4RF
只看该作者 98楼 发表于: 2006-02-14
20m我已经不关心了,除非有rtty出来。
离线BA4RF
只看该作者 99楼 发表于: 2006-02-14
谢谢。
强烈恭喜啊。
昨天40m的那个干扰实在是太让我气愤了。转折点出现在bg1xxx在3y0x的频率上呼叫cq被赶走之后,这个干扰就一直存在,而且一直干扰了好几个小时(我不是说这个干扰是bg1xxx放的哦,因为信号强度等都不一样。只是很巧合)。然后在我苦叫无应的时候xyl qrm又出现,没办法,40m只好收手。
