  • 21989阅读
  • 76回复
今晚第一次EME试验,未能完成QSO,两天后成功啦! [复制链接]
离线VR2KW
只看该作者 60楼 发表于: 2012-09-16
大佬,你用几多块板合成?
离线BA7KW
只看该作者 61楼 发表于: 2012-09-16
4块,28v,电流约60A。
BA7KW  张建华
BA7KW"at"163.com
离线bg7mnv
只看该作者 62楼 发表于: 2012-09-17
弱弱的问:图中接收到的信息是网络的还是EME系统的?
http://www.qrz.com
离线BA7KW
只看该作者 63楼 发表于: 2012-09-17
这个时延7.9秒有点不靠谱,正常在1-3秒间(大家都对过时,误差1秒内),可能你的时钟不准。
但你解读的信息是正确的,能收他的回复是很有可能的,这两天EME传播很好,损耗DGRD只有1.x到2.x,昨日和今日ECHO测试最好时都能收到-16.你可以试一试ECHO 模式。如果能够收到回波说明你的系统很正常。
BA7KW  张建华
BA7KW"at"163.com
离线BA7KW
只看该作者 64楼 发表于: 2012-09-21
昨晚通了一个比利时的电台,他仅仅用一支12单元(约6米`长)的天线,不用旋转器,250W的乌龟。
我的设备是入门级,他的设备更是门外级,这样也能通上,真是神奇。
我收他的信号:
113900  1  -29  2.7 -406  2 *      BA7KW ON7EH JO20          0  10
115500  1  -31      -384  3   RO
他收我的报告和QTH的照片如图片
我当时一直在追他给我发“73”,但他在EME CHAT里面说,他收到我的“RRR"就表示已经结束QSO了,呵呵。后来还收到他的来信解析这件事,一个3代都是火腿的世家。
另一个信息是,比利时也用华为的基站,真是让人觉得骄傲。
他以前也和Sug通过。
他的来信:
Hi Jan,
“Nie haw”
I am sorry to hear about ur Rx-problems. It must not be easy to do EME  under such circumstances!
I copied you very well as you can see in the attached screenshot.
Normally, for a complete EME QSO it is sufficient that one station has  copied RRR. With the logger it is common to stop when the station has received  the RR and announces it to the other station. In attach you can find the proof.  (3xRRR)
If you think the QSO was not complete please let me know and I’ll try  another time...
Below you’ll find the usual, QSO details, I sent to stations after having  made a QSO via 2m EME...
It is always nice to QSO a new station with my single “baby”-yagi...
Thanks for the new initial
I am glad you came back to me after your CQ.
You were not visible then so apparently (and luckily) the polarisation  changed...
You will see on the screenshots that you were rather good copy, here... Two  earliers minutes were only seen but not decoded. (traces)
Your (antenna) system is working very well!
The degradation was average (@ –3.8dB) and that certainly helped a lot  because the conditions were rather good but not many stations active. (they were  all in Cambridge...Lucky me...)
You were best decoded at –21dB  during our QSO.
As said, I had many good decodes with CQ, OOO and RRR.
The QSO was started in my first and end of my first GG  lobe.
The antenna here is just 10m agl and 30m asl .
The QRM is getting louder and louder in the back of my antenna (many, many  houses) so I am very happy, I can work via the moon on my moonrise...!Remember, I have no elevation rotor here! Only at my moonrise, the groundgain makes that I can tx/rx as the  equivalent of a 5y station...!You'll find attached my moonrise view, the pictures were taken at 120°, the QTF during our QSO was even more to the right.I have still very good ground gain here...You also see a picture of my "monster" antenna, one 12M2  (2.87 lambda long=nearly 6m long) on the side of the houseThe QTH is near to Brussels airport.Station is 250W+ (TS850S + transverter), Kathrein 144MHz  bandpass filter, LNA is by PA3BIY in the shack and desktop 1.8GHz.Thanks a lot for the nice QSO!  Would it be possible to get a picture of your antenna system?At work I often work with Chinese engineers from Huawei! Huawei is  our 2G/3G/4G base station equipment provider! 73, Michel, ON7EH (also 2nd op @ON5RR 23/13cm EME)http://users.skynet.be/on7eh/  (not updated for quite some time  now)
I am 3d generation ham;
I am the grandson of Leopold Spelier (ex-EA5ASN, OQ5EH, 9Q5EH, ON4SP)
My OM QRO (father) was ON5SP, Roland Spelier.
Both are SK  now.
[ 此帖被BA7KW在2012-09-22 09:17重新编辑 ]
BA7KW  张建华
BA7KW"at"163.com
离线BA7KW
只看该作者 65楼 发表于: 2012-09-21
真羡慕他门前的一片绿地,如果我有那个条件,一定会做一个W5UN的那种天线,呵呵。。。
BA7KW  张建华
BA7KW"at"163.com
离线BA7KW
只看该作者 66楼 发表于: 2012-09-21
关于EME 回波测试的记录
分别是:编号,每6秒一个周期一次,电平,信号(dB),频率偏差,宽度,质量(这个最重要,0为不可靠,10为非常可靠)
记录时间约25分钟,可以看到反射的信号从-20的幅度,10的质量进过30个周期月180秒的时间变为没有了反射波被检测出来的-34,而再回到10的质量时,用了约300个周期即半小时,和前人总结的20分钟到1小时相符。其中也有部分时间能回到5-8的水平。对月反射通信,受法拉第旋转等影响,信号的飘忽还是很大的,但等一段时间也是有可能改善。其中规律我还在继续探索中。
071000  Transmitting: Echo
NO.LEVEL SIGNAL DF  Q
  56   4.9  -20.0     0.7   0.7  10
  57   4.9  -20.6     0.7   0.7  10
  58   4.9  -21.1     0.7   0.7  10
  59   5.0  -21.3     0.7   0.7  10
  60   5.3  -22.0     0.7   0.7  10
  61   4.9  -21.9     0.3   0.7  10
  62   4.9  -22.4     0.3   0.7  10
  63   5.0  -22.9     0.3   0.7  10
  64   4.9  -23.0     0.3   0.7  10
  65   5.0  -23.6     0.3   0.7  10
  66   5.1  -23.9     0.3   0.7  10
  67   5.1  -24.0     0.3   0.7  10
  68   5.2  -24.5     0.3   0.7  10
  69   6.9  -25.3     0.3   0.7  10
  70   5.8  -26.0     0.3   0.7   9
  71   5.7  -26.4     0.3   0.7   8
  72   5.6  -27.0     0.3   0.7   7
  73   5.3  -27.3     0.3   0.7   6
  74   5.2  -27.8     0.3   0.7   6
  75   5.5  -28.4     0.3   0.7   6
  76   5.4  -28.9     0.3   0.7   5
  77   5.8  -29.5     0.3   0.7   4
  78   5.5  -29.9     0.3   0.7   3
  79   5.4  -30.6     0.3   1.0   2
  80   5.4  -31.2     0.3   1.0   2
  81   5.5  -31.6     0.3   1.0   2
  82   5.4  -31.5     0.3   1.0   2
  83   5.3  -31.9     0.3   1.0   2
  84   5.5  -32.6     0.3   1.0   1
  85   6.0  -32.1     0.3   1.0   2
  86   5.3  -32.4     0.3   1.0   1
  87   5.4  -32.7     0.3   1.0   1
  88   5.4  -33.0     0.3   1.0   1
  89   6.0  -34.0     0.3   1.0   0
  90   5.8  -34.7     0.3   1.3   0
  91   5.7  -35.0     0.3   1.3   0
  92   5.6  -34.8   -81.4   0.3   0
  93   6.9  -34.7   -81.4   0.3   0
  94   5.4  -34.7     0.0   0.7   0
  95   6.6  -34.7   -81.4   0.3   0
  96   5.4  -34.9    86.8   0.3   0
  97   5.3  -35.4    86.8   0.3   0
  98   5.8  -36.0   -81.4   0.3   0
  99   6.0  -34.7    94.5   0.3   0
100   6.4  -35.3    94.5   0.3   0
101   6.2  -36.1    94.5   0.7   0
102   6.2  -35.9    94.5   0.7   0
103   6.1  -35.9   -66.6   0.3   0
104   6.2  -35.6   -92.9   0.3   0
105   6.1  -34.9    40.4   0.3   0
106   5.3  -35.4    40.4   0.3   0
107   5.4  -36.1    40.4   0.3   0
108   5.2  -36.2    40.4   0.3   0
109   5.3  -36.2    99.3   0.7   0
110   5.7  -35.7   -20.9   0.3   0
111   6.2  -35.7   -91.2   0.7   0
112   5.4  -35.4   -91.2   0.3   0
113   5.4  -35.6    59.6   0.3   0
114   6.1  -36.5   -97.6   0.3   0
115   5.9  -35.2    14.5   0.3   0
116   5.3  -35.6    14.5   0.3   0
117   6.8  -35.5    97.2   0.3   0
118   5.0  -35.6    97.2   0.3   0
119   5.2  -36.1    97.2   0.3   0
120   5.3  -36.1    14.5   0.3   0
121   5.2  -36.5    14.5   0.3   0
122   5.4  -37.0    14.5   0.3   0
123   6.2  -35.7   -97.6   0.7   0
124   5.3  -35.8   -75.4   0.3   0
125   5.3  -35.8   -75.4   0.3   0
126   5.6  -35.3   -97.6   0.3   0
127   7.0  -33.4   -20.9   0.3   1
128   6.2  -34.1   -20.9   0.3   0
129   5.2  -34.3   -20.9   0.7   0
130   7.4  -33.0   -44.7   0.7   0
131   6.8  -33.9   -44.7   0.7   0
132   6.0  -34.4   -44.7   0.7   0
133   6.4  -33.9   -88.5   0.7   0
134   5.3  -34.1   -88.5   0.7   0
135   5.8  -34.6   -88.5   0.3   0
136   5.8  -34.3   -88.5   0.3   0
137   5.4  -34.7   -88.5   0.7   0
138   5.3  -35.1   -88.5   0.7   0
139   6.4  -34.9   -46.1   0.7   0
140   5.7  -35.6   -46.1   0.7   0
141   5.1  -36.0   -75.4   0.3   0
142   5.2  -35.9    16.1   0.3   0
143   5.6  -36.3    16.1   0.7   0
144   5.7  -35.9     5.7   0.3   0
145   6.0  -36.4   -46.1   0.7   0
146   5.2  -35.7     0.3   1.0   0
147   6.4  -34.9   -49.8   0.3   0
148   5.6  -34.9   -43.7   0.3   0
149   5.2  -34.6   -43.7   0.3   0
150   6.3  -34.6   -80.4   0.3   0
151   6.4  -35.6   -80.4   0.3   0
152   8.7  -33.6   -82.4   0.3   0
153   5.3  -34.1   -82.4   0.3   0
154   6.1  -34.5    88.2   0.7   0
155   6.2  -34.2   -82.4   0.7   0
156   5.3  -34.7   -82.4   0.7   0
157   6.6  -34.1   -21.5   0.3   0
158   5.1  -34.4   -21.5   0.3   0
159   5.7  -35.0   -21.5   0.3   0
160   5.3  -34.8   -21.5   0.7   0
161   5.2  -35.4   -21.5   0.7   0
162   5.5  -35.6     0.7   0.7   0
163   5.4  -36.0     0.7   0.7   0
164   5.3  -36.1     0.3   0.7   0
165   5.2  -35.2     0.3   0.7   0
166   5.2  -35.6     0.3   0.7   0
167   6.2  -35.4   -27.6   0.3   0
168   6.2  -35.0   -21.5   0.3   0
169   5.0  -35.0   -27.6   0.3   0
170   5.9  -35.0   -80.7   1.0   0
171   5.8  -35.1   -97.6   0.3   0
172   5.2  -35.5   -21.5   0.3   0
173   5.0  -35.9   -21.5   0.3   0
174   5.1  -35.6     0.7   1.0   0
175   5.4  -36.1     0.7   1.0   0
176   5.3  -35.0     0.7   0.7   0
177   5.1  -35.5     0.7   1.0   0
178   5.0  -36.0     0.7   1.0   0
179   5.0  -32.3     0.3   0.7   2
180   5.5  -32.7     0.3   0.7   1
181   5.0  -32.6     0.3   0.7   2
182   5.1  -32.9     0.3   0.7   1
183   5.9  -33.6     0.3   1.0   1
184   5.2  -31.6     0.3   0.7   2
185   5.2  -31.8     0.3   0.7   2
186   5.5  -31.4     0.3   0.7   2
187   5.0  -31.6     0.3   0.7   2
188   5.1  -31.9     0.3   0.7   2
189   6.1  -31.8     0.7   0.7   3
190   5.3  -31.7     0.7   0.7   2
191   5.1  -31.5     0.7   0.7   2
192   5.3  -31.5     0.3   0.7   2
193   6.0  -32.4     0.3   0.7   2
194   5.1  -32.2     0.7   0.7   2
195   5.1  -32.8     0.7   1.0   1
196   5.1  -31.5     0.3   0.7   2
197   6.6  -32.9     0.3   1.0   1
198   6.0  -32.7     0.3   1.0   1
199   6.2  -31.3     0.3   0.7   2
200   5.3  -31.7     0.3   0.7   2
201   5.5  -32.0     0.3   0.7   2
202   5.1  -32.5     0.3   0.7   1
203   5.3  -30.5     0.3   0.7   4
204   5.6  -29.7     0.3   0.7   4
205   5.3  -28.6     0.3   0.7   7
206   5.1  -28.8     0.3   0.7   6
207   5.1  -28.6     0.3   0.7   7
208   5.9  -28.8     0.3   0.7   6
209   5.3  -29.2     0.3   0.7   5
210   5.2  -29.5     0.3   0.7   5
211   5.1  -29.4     0.3   0.3   5
212   5.2  -29.8     0.3   0.3   4
213   5.3  -29.2     0.3   0.3   6
214   6.1  -29.9     0.3   0.3   4
215   6.9  -30.9     0.3   0.3   2
216   7.4  -31.8     0.3   0.3   1
217   5.6  -32.2     0.3   0.3   1
218   5.1  -32.6     0.3   0.3   1
219   5.1  -32.2     0.3   0.3   1
220   5.2  -32.4     0.3   0.7   1
221   5.1  -32.7     0.3   0.7   1
222   5.3  -32.9     0.3   0.7   1
223   5.2  -31.8     0.7   0.7   2
224   5.1  -31.9     0.7   0.7   2
225   5.3  -32.0     0.7   0.7   2
226   5.2  -31.8     0.7   0.7   2
227   5.4  -32.1     0.7   0.7   2
228   5.2  -31.9     0.7   0.7   2
229   5.4  -32.1     0.7   0.7   2
230   5.1  -32.5     0.7   0.7   2
231   5.1  -32.4     0.7   0.7   2
232   5.1  -31.9     0.7   0.7   2
233   5.0  -32.4     0.7   0.7   2
234   5.1  -32.6     0.7   0.7   1
235   5.1  -32.3     0.7   0.7   2
236   5.0  -29.1     0.3   0.7   6
237   5.1  -29.4     0.3   0.7   5
238   5.1  -29.7     0.3   0.3   5
239   5.1  -29.7     0.3   0.7   5
240   5.2  -29.8     0.3   0.3   4
241   5.1  -30.0     0.3   0.7   4
242   7.5  -31.7     0.3   1.0   1
243   6.1  -31.3     0.3   0.7   1
244   5.1  -31.8     0.3   0.7   1
245   5.2  -31.7     0.3   0.7   1
246   5.1  -32.1     0.3   1.0   1
247   5.1  -32.1     0.3   0.7   1
248   5.1  -32.6     0.3   1.3   1
249   5.0  -33.0     0.7   1.3   1
250   5.4  -33.5     0.7   1.3   1
251   5.0  -33.1     0.7   1.0   1
252   5.0  -32.6     0.7   0.7   1
253   5.1  -33.0     0.7   1.3   1
254   5.2  -33.0     0.7   1.3   1
255   5.1  -30.3     0.7   0.7   3
256   5.6  -31.0     0.7   1.0   3
257   5.1  -31.4     0.7   1.0   3
258   5.5  -31.2     0.7   1.0   3
259   5.1  -31.7     0.7   1.3   2
260   5.5  -32.2     0.7   1.3   2
261   5.0  -32.6     0.7   1.3   1
262   5.1  -32.1     0.7   1.0   2
263   7.1  -32.4     0.7   2.4   1
264   5.0  -32.6     0.7   1.7   1
265   5.1  -33.3     0.7   2.0   0
266   5.0  -32.6     0.0   1.7   1
267   5.5  -32.4     0.0   1.3   1
268   5.0  -31.6     0.0   1.3   2
269   5.5  -32.3     0.0   1.3   1
270   5.0  -32.7     0.0   1.3   1
271   5.0  -33.1     0.0   1.7   1
272   5.0  -32.9     0.3   1.7   1
273   5.1  -31.6     0.3   1.3   2
274   5.4  -30.8     0.3   0.7   3
275   7.4  -31.6     0.3   1.0   1
276   5.1  -31.4     0.3   0.7   1
277   5.1  -31.3     0.3   0.7   1
278   5.1  -31.8     0.3   0.7   1
279   5.0  -32.1     0.3   1.0   1
280   5.0  -32.3     0.3   1.0   1
281   5.0  -30.7     0.7   0.7   3
282   5.0  -30.9     0.7   0.7   3
283   6.2  -31.3     0.7   0.7   2
284   5.1  -31.6     0.7   0.7   2
285   5.1  -30.8     0.3   0.7   2
286   5.1  -30.7     0.3   0.7   3
287   5.0  -30.2     0.3   0.7   3
288   5.3  -29.8     0.7   0.7   3
289   5.0  -29.6     0.7   0.7   3
290   4.9  -29.7     0.7   0.7   4
291   5.6  -30.4     0.7   0.7   3
292   5.1  -30.6     0.7   0.7   3
293   5.0  -30.2     0.7   0.7   4
294   5.0  -29.4     0.7   0.7   5
295   5.0  -28.9     0.7   0.7   5
296   5.1  -29.5     0.7   0.7   5
297   5.7  -29.8     0.7   0.7   3
298   5.9  -30.1     0.7   0.7   3
299   5.0  -30.4     0.7   0.7   3
300   5.0  -30.7     0.7   0.7   3
301   6.2  -30.5     0.7   0.7   3
302   4.9  -30.6     0.7   0.7   2
303   5.3  -30.8     0.7   0.7   3
304   5.6  -31.3     0.7   0.7   2
305   5.2  -31.5     0.7   0.7   2
306   5.0  -31.4     0.7   0.7   2
307   5.3  -28.4     0.3   0.3   6
308   5.0  -27.0     0.3   0.7   9
309   4.9  -27.3     0.3   0.7   9
310   5.0  -27.3     0.3   0.7  10
311   4.9  -27.0     0.3   0.7   9
312   5.0  -27.4     0.3   0.7   9
313   5.0  -27.2     0.3   0.7   8
314   5.0  -27.7     0.3   0.7   8
315   5.6  -27.9     0.7   0.7   7
316   4.9  -27.6     0.3   0.7   8
317   4.8  -27.5     0.3   0.7   8
318   6.2  -28.4     0.3   0.7   5
319   6.2  -29.2     0.7   0.7   3
320   6.5  -30.1     0.7   0.7   2
321   7.1  -31.2     0.7   1.7   1
322   5.0  -30.6     0.7   0.7   2
323   5.5  -31.1     0.7   0.7   2
324   5.8  -31.2     0.7   0.7   2
325   5.2  -31.3     0.7   0.7   2
326   5.1  -29.7     0.3   0.7   3
327   5.0  -29.7     0.3   1.3   4
328   4.9  -28.7     0.7   0.7   5
329   6.1  -28.3     0.3   1.0   5
330   5.9  -28.9     0.3   1.0   5
331   4.9  -28.5     0.3   1.0   6
332   4.9  -27.4     0.3   1.0   8
333   5.7  -25.8     0.3   0.7  10
334   5.0  -26.2     0.3   0.7  10
335   5.4  -26.6     0.3   1.0   9
336   5.3  -26.3     0.3   0.7  10
337   5.6  -26.7     0.7   0.7  10
338   6.5  -27.5     0.3   1.0   7
339   7.3  -28.3     0.3   1.0   5
340   5.2  -28.1     0.3   0.7   5
341   5.7  -26.6     0.3   0.7   8
342   6.0  -27.1     0.3   0.7   7
343   6.2  -27.4     0.3   0.7   7
344   4.9  -26.4     0.3   0.7   9
345   4.9  -26.2     0.3   0.7  10
346   4.9  -25.8     0.3   0.7  10
347   4.9  -25.8     0.3   0.7  10
348   7.2  -26.7     0.3   0.7   7
349   5.4  -26.1     0.3   0.7   9
350   5.2  -26.3     0.3   0.7   8
351   5.9  -26.6     0.3   0.7   8
352   6.1  -26.7     0.3   0.7   8
353   5.3  -26.8     0.3   0.7   9
354   5.3  -27.0     0.3   0.7   8
355   6.3  -27.4     0.3   0.7   7
356   5.0  -27.3     0.3   0.7   7
357   5.4  -26.4     0.7   0.7   9
358   6.2  -26.4     0.7   0.7   9
359   4.8  -26.3     0.7   0.7  10
360   4.9  -26.1     0.7   0.7  10
361   4.9  -26.2     0.7   0.7  10
362   4.8  -26.2     0.7   0.7  10
363   5.8  -26.7     0.7   0.7   8
364   5.4  -26.7     0.7   0.7  10
365   7.4  -27.4     0.7   0.7   6
366   5.3  -26.5     0.7   0.7   9
367   4.9  -26.7     0.7   0.7   8
368   5.0  -26.8     0.7   0.7   9
369   8.2  -25.5     0.7   0.7   9
370   4.9  -25.6     0.7   0.7   9
371   5.0  -25.1     0.7   0.7  10
372   7.9  -26.3     0.7   0.7   7
373   4.9  -26.5     0.7   0.7   6
374   5.3  -26.9     0.7   0.7   6
375   5.0  -26.5     0.7   0.7   8
376   6.9  -26.6     0.7   0.7   7
377   7.3  -27.5     0.7   0.7   5
378   4.9  -27.4     0.7   0.7   6
379   5.7  -27.7     0.7   0.7   6
380   6.3  -27.5     0.7   0.7   6
381   6.0  -27.9     0.3   0.7   6
382   5.5  -27.2     0.7   0.7   7
383   6.9  -26.5     0.3   0.7   9
384   5.8  -26.8     0.3   0.7   8
385   6.4  -26.5     0.3   0.7  10
386   7.2  -27.4     0.3   0.7   8
387   6.0  -27.0     0.3   0.7   9
388   6.9  -26.9     0.3   0.7   9
389   6.8  -27.3     0.3   0.7   8
390   5.7  -27.4     0.3   0.7   8
391   5.2  -26.6     0.3   0.7  10
392   5.5  -26.5     0.3   0.7  10
393   6.1  -26.8     0.3   0.7  10
394   5.9  -26.9     0.3   0.7  10
395   4.9  -26.9     0.3   0.7  10
396   5.7  -26.7     0.3   0.7   9
397   5.0  -26.3     0.3   0.7  10
398   5.0  -26.5     0.3   0.7  10
399   5.6  -25.2     0.3   0.7  10
400   5.7  -24.8     0.3   0.7  10
401   6.9  -25.6     0.3   0.7  10
402   6.0  -25.9     0.3   0.7  10
403   5.4  -26.2     0.3   0.7  10
404   5.1  -25.8     0.3   0.7  10
405   5.8  -25.9     0.3   0.7  10
406   5.1  -25.7     0.3   0.7  10
407   7.4  -26.2     0.3   0.7   9
408   5.2  -26.3     0.3   0.7  10
409   8.3  -27.8     0.3   1.0   5
410   6.0  -28.0     0.3   1.0   5
411   5.0  -27.2     0.3   1.0   7
412   6.0  -27.3     0.7   1.0   6
413   6.6  -26.7     0.7   0.7   7
414   8.0  -27.5     0.7   0.7   6
415   8.5  -28.5     0.7   0.7   3
416   7.8  -28.2     0.3   0.7   4
417   4.9  -27.3     0.3   0.7   5
418   5.4  -27.1     0.3   0.7   7
419   4.9  -27.1     0.3   0.7   7
420   6.7  -26.9     0.7   0.7   7
421   6.7  -27.2     0.7   0.7   8
422   5.0  -27.2     0.7   0.7   8
423   6.7  -27.0     0.7   0.7   8
424   7.0  -27.6     0.7   0.7   6
425   6.0  -26.8     0.3   0.7   8
426   6.3  -27.5     0.3   0.7   8
427   5.3  -27.3     0.7   0.7   8
428   6.2  -27.7     0.3   0.7   8
429   4.9  -26.7     0.7   0.7  10
430   4.8  -26.9     0.7   0.7  10
431   7.9  -27.6     0.7   0.7   7
432   6.8  -27.6     0.7   0.7   7
433   8.2  -28.3     0.7   0.7   5
434   5.0  -28.3     0.7   0.7   5
435   4.9  -28.4     0.7   0.7   5
436   5.0  -28.2     0.7   0.7   6
437   7.2  -28.6     0.3   0.7   5
438   5.1  -28.1     0.3   0.7   6
439   6.5  -28.4     0.3   0.7   6
440   6.2  -28.6     0.3   0.7   5
441   7.6  -29.4     0.3   0.7   4
442   7.3  -29.5     0.3   0.7   3
443   7.2  -28.9     0.3   0.7   4
444   6.6  -28.6     0.3   0.7   4
445   7.0  -28.5     0.3   0.7   5
446   5.1  -28.5     0.3   0.7   5
447   8.3  -28.7     0.3   0.7   4
448   7.3  -29.1     0.3   0.7   4
449   5.3  -29.1     0.3   0.7   4
450   5.3  -28.7     0.3   0.7   5
451   5.7  -28.7     0.3   0.7   5
452   5.8  -28.4     0.3   1.0   5
453   7.0  -28.2     0.3   1.0   6
454   5.4  -28.3     0.3   1.0   6
455   5.5  -28.3     0.3   1.0   6
456   4.9  -27.8     0.3   1.0   7
457   7.2  -28.5     0.3   1.0   6
458   5.8  -28.6     0.3   1.0   6
459   7.6  -28.1     0.3   0.7   5
460   8.2  -29.1     0.3   0.7   3
461   8.0  -29.6     0.3   0.7   3
462   7.8  -29.2     0.3   0.7   4
463   5.2  -29.4     0.3   0.7   4
464   5.5  -29.6     0.3   0.7   4
465   5.7  -29.5     0.3   0.7   4
466   5.4  -29.7     0.3   0.7   4
467   5.5  -29.9     0.3   0.7   4
468   7.0  -30.3     0.3   0.7   3
469   7.9  -29.8     0.3   0.7   4
470   5.5  -29.3     0.3   0.7   4
471   5.1  -28.7     0.3   0.7   5
472   7.9  -29.7     0.3   0.7   3
473   6.5  -29.9     0.3   0.7   4
474   6.8  -30.5     0.3   0.7   4
475   5.0  -30.3     0.3   0.7   4
476   7.1  -30.5     0.3   0.7   3
477   6.4  -30.9     0.3   1.0   3
478   6.4  -29.0     0.7   0.7   5
479   7.1  -29.7     0.7   1.0   4
480   6.4  -29.5     0.7   1.0   4
481   5.9  -29.8     0.7   1.0   4
482   7.3  -30.3     0.7   1.0   3
483   6.4  -30.8     0.7   1.0   3
484   5.4  -30.1     0.0   1.0   4
485   7.7  -29.6     0.3   1.0   4
486   7.4  -29.8     0.3   1.0   4
487   5.3  -28.8     0.3   1.0   5
488   7.4  -28.9     0.3   0.7   5
489   4.9  -29.0     0.3   1.0   5
490   6.2  -28.6     0.3   0.7   5
491   7.9  -29.2     0.3   1.0   4
492   7.2  -29.7     0.3   1.0   4
493   7.6  -30.4     0.3   1.0   3
494   5.6  -30.1     0.3   1.0   3
495   6.6  -30.2     0.3   1.0   3
496   5.3  -29.6     0.3   0.7   4
497   4.9  -29.7     0.3   0.7   4
498   5.0  -29.9     0.3   0.7   4
499   7.4  -30.0     0.3   0.7   3
500   5.0  -29.5     0.3   0.7   4
501   7.1  -30.2     0.3   0.7   2
[ 此帖被BA7KW在2012-09-21 16:24重新编辑 ]
BA7KW  张建华
BA7KW"at"163.com
离线BA7KW
只看该作者 67楼 发表于: 2012-09-21
转帖NQ贴过的文章:
这是一篇在互联网上广泛流传的文章,不知道是哪位老大翻译的。
尽管月面反射eme自二战以来就开始应用,但成功的完成业余无线电的日常通信却是近期的事。1960年第一次完成了业余的双向月面反射通信,直到美国规定最高输出功率可以达到1500w及八十年代gaasfet(砷化馈场效应管)前置放大器的出现,月面反射通信才变得流行起来。
在vhf/uhf波段,144mhz是使用最广泛的月面反射通信频率,尽管在50mhz上进行月面反射通信已经非常成功,但庞大的天线阵列以及天空的背景噪声对大多数人来说都足难以解决的困难,不过仍有许多狂热的爱好者在此波段上操作。由于频率越高,通路的损耗越大,因此要想成功的完成144mhz以上的eme通信,就要求有非常复杂的天线阵及输出功率尽量接近合法的最大发射功率。因此,大多数爱好者都从144mhz开始,一旦他们对eme很感兴 趣,他们就会在更高的频率进行试验。
为了搜集vhf段以上dx方面的信息,我和五位144mhz eme通信方面的专家:lance collister,waljxn;bev caveeder,w4zd;san hutson,k5yy;john carter,k0ifl和dave blaschke,w5un进行了探讨,以下是他们关于2米波段月面反射通信的一些观点。
影响eme通信的因素包括以下几种:轨道抖动衰减,极大的路径损耗,噪声(包括太阳及空间背景的噪声),法拉第旋转及由于空间位置的变化引起的极化方向的改变。
由于地球和月亮在沿其自身轨道运行时存在抖动,故从地球上发射的信号触及到月球表面的一定区域而不是象牛眼那么小的一块面积。同时,由于月球表面很不规则,反射回来的信号也就呈不现则的形状。这样你的电台接收到的信号就会有畸变,就象站在哈哈镜前看到镜中变形的影像类似。轨道抖动和不规则的信号都可以引起信号的衰弱和两个试图联通的电台之间的多谱勒频移。这就是轨道抖动衰减。当在两米上进行操作时,你会感到有长时间的波峰和波谷出现,这佯就只能听清呼号的一部分,接着就是很弱的信号。这些影响并不仅在144mhz上反映出来、在1296mhz上甚至可以有高达20db的衰减并有10hz的频移。
月球距地球在近地点的距离为221000英里,远地点的距离为282000英里。由于月面形状的影响,发射到月球的信号只有7%可以被反射回来。其余的93%则被吸收和损耗掉了。路径损耗和通信频率成正比,频率越高,路径损耗越大。因此在144mhz上,反射回近地点的路径损托为252db、远地点为254db。对于低功率的电台,近地点和远地点2db的差别并不影响做一次成功的qso。
由于太阳和背景空间产生的噪声,会影响电台接收弱信号的能力。对于处于北半球的电台,当月亮呈新月状时(除了月食以外,肉眼无法看到月亮),或月亮在空中位于远南端时,通常通信效果不理想;当月亮更加更近南方时,通信效果最不理想。这不仅足由于在这种情况下南方的星座引起的背景噪声的增加,还由于天体的运行规律。当月球位于远南的位置时,纬度越高的欧洲台看到的月亮越小,通常他们很难在空中联通。对于位于北半球的电台来说,一个月中最理想的通信时间是当月亮从其向北倾斜角度最大的位置转向天空南方时。
法拉第旋转是由于地球电离层对信号的影响而产生的一种极化旋转。也有人说是由于信号通过电离层时地球磁场对其造成的影响(dave指出伴随法拉第旋转所发生的一些现象和hf传播中的一些现象有某种关系,这保留了月面反射的神秘性,值得深入研究)。法拉第旋转使信号有一个深的周期性衰减,在一定时间间隔内这个周期会有所改变,随着频率的增加而变长。估计在144mhz上,这个时间间隔约为20分钟。dave说,这个周期在某些时候非常明显。在此时安排进行qso效果不错。这个周期在144mhz上一般会持续半个到—个小时,通常这一个小时用于安排随意的通信,半小时用于安排比赛。尽管有些比赛的qso都事先预约,(尤其是低功率电台想和高功率电台联通),但大多数的联通是随意的。
由于空间位置的变化引起的极化方向的改变简单地说就是在地球上不同位置的两个电台都把天线对准月面,再用镜子做—个比喻,如果我们用镜子从某一个角度看物体,由于你的头倾斜的角度不同,物体可能看起来右边转到了上面,或者上下颠倒。如果其中一个电台的天线可以在水平和垂直方向之间的立面中旋转,则由上述位置变化引起的某些影响就可以解决。但是同时在这个立面中旋转几个天线,还要保持每个天线间的相位关系,从机械的角度上讲简直太可怕了。因此由空间位置的变化引起极化方向的改变经常通过强力来解决。给天线阵列增加更多的单元以提高天线阵的db增益,以此减小这种影响。同时dave指出至少在2米qso的部分预约时间间隔内法拉第旋转有压倒这种极化改变的趋势。
有关eme通信有两点要牢记。首先,在月亮升起时会产生高于你的频率300~500hz的多普勒频移;当月亮落下时会产生低于你的频率300~500hz的多普勒频移;当月亮在头顶上时无多普勒频移。对于利用卫星进行通信的人都很熟悉多普勒频移,并且会一直把手放在频率旋钮上。其次,要经过2.3~2.7秒的延时,才知道是否可以听见反射回来的自己的信号。这是由于月球距地球非常远,信号来回需要一定的时间。
cw是eme通信中非常好的一种方式。由于信号很微弱,这种方式最为可靠。发送速度一般在10~15wpm。低于这个速度将会由于衰减和颤动导致通信中断,而速度过快又会导致字母丢失。
eme通信在某方面类似于流星散射:二者都是对微弱、无规律的信号进行处理。因此,与流星散射一样,eme通信也有自己的联络规程方法,但是由于eme信号的特点,其联络过程又和流星散射有很大的区别。
对于已经安排好的联络,比较好的操作频率为高于144.030mkz,而对随意进行的qso,则在144.000~144.030mhz较为合适。如果信号足够大并能进行ssb qso,最合适的频率为144.150mhz及以上。
有些网络你可以收听,以得到有关的情况和通信安排方面的信息。其一为144mhz eme通信。它由ve7bqh主持,于每周六及周日的1700utc在144.345mhz上相聚,或是等432mhz的网络一结束就开始。每周一0230utc(当地时间周日晚)在3.818mhz(加或减qrm),有vhf/uhf情报交换网络,大家交流信息,设定联络时间表。在星期二0130utc(当地时间周一晚),另有—个vhf/uhf交换网络在3.843mhz,目的同上。
现在我们来看—个简单的qso。德国的dl8dat和美国圣地亚哥布市的n6cw预先安排好一次qso。这次qso预计持续1小时,并于0000utc开始。东部的电台(相对于他在地球上的位置)先发射,即dl8dat先发射,发射持续2分钟,dl8dat将发射接收台的呼号及自己的呼号,即:n6cw de dl8dat,n6cw de dl8dat,…。在0002utc,n6cw开始发射相同的内容:dl8dat de n5cw,dl8dat de n6cw。两个爱好者每两分钟轮流发射一次,直到一个电台听到另一个电台发射的完整的呼号。
一旦接收台秒录下完整的呼号,他就开始下—个阶段的工作。在2分钟发射时间的前90秒,他还象以前那样发送呼号,但在余下的30秒内,他加上一个信号报告,字母“o”。
信号报告每次为“t”,“m”或“o”。“ t”表示呼号仅可勉强检测到;“ m”表示抄下部分呼号;“ o”表示完全抄收。由于收听台都渴望抄收到完整的呼号,故对于完成qso来说其它任何报告都是浪费时间。因此,按惯例,信号报告就发展为字母“o”。
假设n6cw成功抄收了呼号并且已经开始了第二阶段的联络。现在由dl8dat来收听qso中的信号报告的内容(假设他已经听到完整的交换的呼号)。一旦他听到了信号报告,就在他发射的2分钟内始终发送“ro”,告诉n6cw,dl8dat已经听到了信号报告(“r”)并且正在发送他自己的信号报告(“o”)。如果他的国家要求他在每次发射后报告自己的呼号,他就要在2分钟结束时,发送一次n6cw de dl8dat,否则就不用发送呼号。
当n6cw最终听到“ro”时,他就在他发射的2分钟内发送“r”,dl8dat听到“r”时,就在他发射的2分钟内发射“73”或“73/sk”,在发射结束时发送他的呼号dl8dat(根据国家规定区分电台)。当dl8dat听到n6cw发送的“r”时,qso就结束了。在此过程中,所有的人都必须是诚实的,因为只有你知道你听到了什么。
在其它vhf+频率上的eme:eme也曾在美国的135cm业余波段上实现过,但近年由于这个频段的前景不稳定,导致人们在此波段的兴趣有所下降。但现在,fcc(美国联邦通信委员会)划出部分频段供弱信号使用(按fcc的话说,即为试验),人们的兴趣又有所回升。135cm上的eme通信能否流行起来还有待观望。
70cm是eme通信中第二个常用的波段。它比起2米来说既容易又困难。安装一个天线阵是较容易的工作之一。由于频率较高、就相同数量的振子单元来说,70cm的天线更小巧。70cm波段上信号传播也相对容易,但仍需要较高的功率使其能到达月球。影响2米段上eme通信的因素,如法拉第旋转和空间背景噪声对70cm的影响要小得多。这样,天线就是需要考虑的事了。由于用于此段的天线阵列较小,把旋转极化设计到天线中就很实际了。这有助于消除法拉第旋转和校正由于联络远距离台而引起的交叉极化。
但在70cm上工作也存在一些问题尽管可以买到70cm的收发信机,有经验的eme操作者通常采用一个合适的hf短波机加上变频器。由于同轴电缆上有馈线损耗,通常都使用硬电缆。同时,必须使用合适的低损耗分配器,以给阵列中的多路八木天线馈入信号。
在33cm波段上也有一些eme活动,另一个较流行的波段为23cm。这时所选用的天线是抛物面天线。由于是园极化馈入,天线的交叉极化和法拉第旋转变得几乎察觉不到。另外空间噪声也比70cm段要小。
高于23cm的大多数emf都是试验性的,只有少数人定期在13cm上工作,更少的人工作在9、5、3cm波段。尽管此时法拉第旋转和空间噪声都不是什么问题了,但又有其它问题出现。合适的设备是首要的困难;学会如何在多普勒频移高于几十khz时进行操作则是另一个问题。
值得注意的是,在这些较高频率的通信中,工作程序稍有不同。发射时间不是持续2分钟而是2.5分钟,最后半分钟用于信号报告或什么也不发,这取决于你从另一个台听到了什 么。
信号报告的方式也不一样,所用字母t、m、o是一样的,但含义略有不同。t为“我能听到某些东西。”;m为“我能听到部分呼号”;o为“抄收到完整呼号”。m用于2米已经足够,高于135cm就要求有o。通常,当你在135cm上与他人约定一次联络时,同时要商量好通信的程序。
BA7KW  张建华
BA7KW"at"163.com
离线bg7mnv
只看该作者 68楼 发表于: 2012-09-22
今晚试了EME 回波测试质量只有1,不好玩的.BD4SY说得对EME这玩意确实不是人玩的....
125254  Transmitting: Echo
   1  -6.1  -26.7   -52.2   0.3   0
   2  -6.3  -29.4   -52.2   0.7   0
   3  -6.3  -30.6    85.5   0.3   0
   4  -6.6  -32.2    85.5   0.3   0
   5  -6.7  -33.2   -35.7   0.3   0
   6  -6.5  -33.7   -35.7   0.3   0
   7  -6.3  -34.1   -91.5   0.3   0
   8  -6.4  -34.0   -86.1   0.3   0
   9  -6.5  -34.7   -86.1   0.3   0
  10  -5.7  -35.1   -91.5   0.3   0
  11  -5.1  -35.3   -91.5   0.3   0
  12  -5.4  -34.2    92.9   0.3   1
  13  -5.2  -34.2    92.9   0.3   1
  14  -6.4  -34.9    92.9   0.3   0
  15  -6.8  -34.9    92.9   0.3   0
  16  -6.7  -35.4    92.9   0.3   0
  17  -6.1  -35.6   -42.4   0.3   0
  18  -6.3  -35.6   -42.4   0.3   0
  19  -6.3  -34.9    37.0   0.3   0
  20  -6.4  -35.3    37.0   0.3   0
  21  -6.2  -35.7   -29.6   0.3   0
  22  -6.6  -34.2    37.0   0.3   1
  23  -6.9  -34.9    37.0   0.3   0
  24  -6.4  -35.3    37.0   0.3   0
  25  -6.7  -35.4   -53.8   0.7   0
  26  -6.8  -35.6   -53.8   0.7   0
  27  -6.5  -35.1   -53.8   0.7   0
  28  -6.9  -34.7   -45.1   0.3   0
  29  -6.9  -35.1   -45.1   0.3   1
  30  -6.7  -35.4   -45.1   0.3   0
  31  -6.9  -34.5    37.0   0.3   1
  32  -7.3  -35.2    37.0   0.3   1
  33  -7.3  -35.8    37.0   0.3   0
  34  -7.0  -36.4    37.0   0.3   0
  35  -7.5  -36.7    38.7   0.3   0
  36  -7.3  -35.9   -83.4   0.3   0
  37  -7.2  -34.4   -83.4   0.3   1
  38  -7.3  -34.7   -83.4   0.3   0
  39  -7.3  -34.4    95.9   0.3   1
  40  -6.9  -35.1    95.9   0.3   0
  41  -7.2  -34.9    95.9   0.3   0
  42  -7.3  -34.8    95.9   0.3   1
  43  -6.6  -33.8    95.9   0.3   1
  44  -6.5  -34.5    95.9   0.3   1
  45  -7.3  -35.2    95.9   0.3   0
  46  -7.6  -35.7    95.9   0.3   0
  47  -7.1  -36.1    81.4   0.3   0
  48  -7.3  -36.3    95.9   0.3   0
http://www.qrz.com
离线BA7KW
只看该作者 69楼 发表于: 2012-09-22
时间太短,做几个小时才准。
有反射时也不一定能QSO,相反无反射也可能通到他台。
你的设备不必比利时的那个ham差了,有机会做到QSO的。
BA7KW  张建华
BA7KW"at"163.com
离线bm2caj
只看该作者 70楼 发表于: 2012-09-25
回 BA7KW 的帖子
BA7KW:时间太短,做几个小时才准。
你的设备不必比利时的那个ham差了,有机会做到QSO的。 (2012-09-22 22:09)
請教前輩 BA7KW OM,
前一陣子我對 EME 有很多興趣, 但試驗沒有成功, 而且發現適合 EME 的時機與時間並沒有很多,
後來發現 JT65-HF 幾乎每天 24小時全球都通, 比 EME 容易多了,
這樣, EME 除了那 38萬公里來回的成就感之外, 還有什麼特別可以激起熱情的嗎?
謝謝!
73 BM2CAJ
离线BA7KW
只看该作者 71楼 发表于: 2012-09-25
虽然WSJT的应用大大降低了EME的门槛,但是EME还是不会像短波一样容易通上DX电台,它对硬件有要求,对通联时机和运气也有关系。不确定因数很多。正因为这样,所以才吸引人去挑战,如果只是要联络,Internet的QSO不是更简单?
想想你的电波通过76万公里去到友台那里被解读,当然兴奋。我是DIY派,试验到我自制的功放和天线工作得很好,甚至不比上万元的成品差,那有多兴奋?
如果喜欢交换卡的,还可以去交换,每一张卡都来之不易,有的EMER在追DXCC呢。
其实有地方的话,144MHZ EME不难实现的,DIY的话,天线和功放花不了很多钱。最需要的是EME的激情!
BA7KW  张建华
BA7KW"at"163.com
离线BA7KW
只看该作者 72楼 发表于: 2012-09-25
在WSJT软件出来前,主要是靠CW和SSB,说实在的,在我完成的qso中,可能只有10分一可以隐约听到声音,真不敢想像前人是如何实现EME QSO的,真的太难了!
那时候要求天线系统有更高的增益,更好的通联时机和更高的操作技巧,多谢K1jt为我们所做的一切!
BA7KW  张建华
BA7KW"at"163.com
只看该作者 73楼 发表于: 2012-10-04
每次看到这种振奋人心的热帖都很感动!~~为楼主的激情,执着,坚持所感动!~~也是只有长期DIY的朋友才能深刻理解~!~~强烈祝贺一下!为楼主加油,~~希望在某年某月的一天,我也能用EME模式于大佬们通上,自己也是在谋划DIY天馈,旋转器,功放,几年了,放下又拾起,反反复复,没能坚持下来。长夜路漫漫,有老大们在前方指引,我想还是会有很多人跟上的!~~73!~BD1OKL
离线m6sig
只看该作者 74楼 发表于: 2012-10-10
没场地架天线的路过,楼主已经是大台了!
CS: M6SIG   LOC: OL63
新浪微博已停用
不再更新的旧数据: http://t.cn/RhrIAYe
离线BD7OXR
只看该作者 75楼 发表于: 2012-10-10
回 BA7KW 的帖子
BA7KW:在WSJT软件出来前,主要是靠CW和SSB,说实在的,在我完成的qso中,可能只有10分一可以隐约听到声音,真不敢想像前人是如何实现EME QSO的,真的太难了!
那时候要求天线系统有更高的增益,更好 .. (2012-09-25 13:51)
7KW那天来你那里感受下 eme 通联!设备天线是在广州 还是 大良?
呼号:BD7OXR (EX  BH7OXR)
电话:幺山漆幺幺山山吾林吾酒
地址:QRZ.cn qrz.com
Q Q:1885639
WX:BD7OXR
邮箱:bd7oxr@126.com
离线BA7KW
只看该作者 76楼 发表于: 2012-10-10
回 BD7OXR 的帖子
BD7OXR:7KW那天来你那里感受下 eme 通联!设备天线是在广州 还是 大良? (2012-10-10 10:55)
广州萝岗,开发区广州新港附近。过了中旬我就回国内了。到时可以约时间去玩玩啊。
BA7KW  张建华
BA7KW"at"163.com
