  • 15125阅读
  • 91回复
这个国庆注定要搞定:BD4WN的K3安装日记! [复制链接]
离线关则勇
只看该作者 60楼 发表于: 2011-09-30
又一个聪明的傻瓜!!花那么多钱买k3,国内的套件那么好都不买,还可省一大笔钱。
离线ba4ta
只看该作者 61楼 发表于: 2011-09-30
相信楼主是被陈大官人忽悠才买的K3...
离线ba4ta
只看该作者 62楼 发表于: 2011-09-30
就看了前面的贴下的结论,细看不对,原来楼主是帮别人装的.算我没说
离线bd7cx
只看该作者 63楼 发表于: 2011-10-01
我差点动心了,最后还是忍了
离线BH4RLO
只看该作者 64楼 发表于: 2011-10-01
哈哈,动作真快
离线BH4RLO
只看该作者 65楼 发表于: 2011-10-01
忘记说了,本产品的进口代理商是邻家ham,她要是有空在边上帮助递个螺丝什么的,今天晚上应该就可以搞定。
近来很忙哦!让5rv给你打工去
离线BH4RLO
只看该作者 66楼 发表于: 2011-10-01
居然是散件?
k3可以是套件也可以是厂装整机,价格略有不同,套件便宜些。
离线BH4RLO
只看该作者 67楼 发表于: 2011-10-01
不要假慈悲了!你要有心,就给我搞一套好些的工具,清单如下:
tools and test equipment required
1.   #0 and #1 size phillips screwdrivers. to avoid damaging screws and nuts, do not use a power
screwdriver. use the screwdriver that best fits the screw in each step.
2. soft cloth or other surface to lay cabinet panels on to avoid scratching. a clean static-dissipating mat is
ideal (see below). if using cloth, do not lay circuit boards on it. see preventing electrostatic
discharge damage on page 3.
3. pliers or suitable wrenches for tightening 1/4”, 3/16” and 1/2” nuts. the 1/2” size is used to tighten nuts
on the front panel controls. if available, a deep socket or nut driver is recommended. pliers or an
ordinary wrench can be used, but requires care to avoid damaging the front panel paint.
4. long nose pliers.
5. diagonal cutters.
6. small rule capable of measuring lengths up to 1” (2.5 cm) with an accuracy of at least 1/16” inch
(1.6 mm).
7. digital multimeter (dmm) for resistance checks.
8. rf 50-ohm, 5 w (minimum) dummy load with low vswr from 160 meters through 6 meters.
(r)
9. power supply 13.8 vdc nominal (11-15 v) with a cable and anderson powerpole connector. a power
cable kit is provided with your k3 if you do not have a suitable cable with the required anderson
powerpole connector. the power supply must be capable of providing at least 3 amperes for a k3/10
and 20 amperes for a k3/100. (see specifications in your owner’s manual for more information on
power supply recommendations).
the following tools are strongly recommended:
1. esd wrist strap.
2. static dissipating work mat.
optional equipment:
1. rf power meter with accurate readout from 1 mw to 5 watts, minimum.
2. signal generator with calibrated 50 uv output at 20 or 40 meters.
in addition, two allen wrenches, 5/64” (2mm) and .050”, are supplied with your kit.
工具很重要,要不要来一套?
离线BH4RLO
只看该作者 68楼 发表于: 2011-10-01
竟然不用动烙铁。。
设计如此
离线BG4XVF
只看该作者 69楼 发表于: 2011-10-01
这不是diy,是装配! 哈哈
离线bg4ffm
只看该作者 70楼 发表于: 2011-10-01
既然有了中频板,别忘了弄套sdr
离线chengrc
只看该作者 71楼 发表于: 2011-10-01
装完不要统调一下吗???真是神鸡!!!!
离线haog131
只看该作者 72楼 发表于: 2011-10-01
感谢楼主直播!
我有两个问题要问:
1…k3套件收到就是焊好的版子,模块化插接吗?小元件需要焊吗?
2…k3套件现在最简配什么价格?
离线bg2aue
只看该作者 73楼 发表于: 2011-10-01
中毒ing。。。。
离线BG7KBH
只看该作者 74楼 发表于: 2011-10-01
看完了,灰常过瘾,期待下文。。。
离线BH4RLO
只看该作者 75楼 发表于: 2011-10-01
感谢楼主直播!
我有两个问题要问:
2…k3套件现在最简配什么价格?
答1.整个安装过程不需要任何焊接。
2.k3最简配的价格参见 elecraft k3
离线VR2VTA
只看该作者 76楼 发表于: 2011-10-01
可看看http://www.elecraft.com/
基本装置 :
k3/10套件 : 1,549.95美完
这个在9月中加价了....
离线BG8SIT
只看该作者 77楼 发表于: 2011-10-01
在等kx3啊
离线BG7RN
只看该作者 78楼 发表于: 2011-10-01
好机,好价格……对了,还有好民工
离线BG4XNG
只看该作者 79楼 发表于: 2011-10-02
既然有了中频板,别忘了弄套sdr
这个也是买中频板的原因,想想用软件sdr在24寸显示器上看频谱和瀑布,是多么爽的一件事,什么kp3,kp30也靠边站。
