  • 13582阅读
  • 111回复
————【紧急求助】关于底噪和天线的问题———— [复制链接]
离线BH4RKH
只看该作者 60楼 发表于: 2010-01-07
tdk磁环 掏宝上有卖,真假不知道,价格相差很大,不知道,你买的是多少钱一个的?
2元-3元 因大小价格不同
离线BH4RKH
只看该作者 61楼 发表于: 2010-01-07
今天拍的电台底噪情况,已经降到了5-7,原来都是在9以上
离线fuyunfan
只看该作者 62楼 发表于: 2010-01-07
馈线加上的话 估计还可以降低~!
恭喜恭喜~!!
离线BH4RKH
只看该作者 63楼 发表于: 2010-01-07
馈线加上的话 估计还可以降低~!
恭喜恭喜~!!
哈哈 感谢付兄支持啊!!!
离线BH4SKP
只看该作者 64楼 发表于: 2010-01-07
淘宝有家6毛一个的(2手),大佬们买了不少~~,我之前买了50个,准备再买100个~~
道理什么的,其实下面这个帖子里大佬们都讨论过的
http://www.hellocq.net/forum/showthread-t-217768.中了版主的毒.html
离线BH4RKH
只看该作者 65楼 发表于: 2010-01-07
这个6毛的是小的吧 我买的内径是13mm 大的
离线BH4SKP
只看该作者 66楼 发表于: 2010-01-07
first,
• on a coaxial feedline near the feedpoint of any antenna; or, if you run balanced line
from the feedpoint of a balanced antenna to a balanced tuner and balun (or balun and
unbalanced tuner) at, say, the point of entry to your house, on the coax at this point;3
• on a coaxial feedline on both sides of any point where the coax shield is connected to
a rod or pipe driven into the ground, or to a counterpoise;4
• on a coaxial feedline in your shack, where the coax first reaches your tuner, amp, or
transceiver;
• on a long coaxial feedline, at intervals of one-quarter wavelength;5
• on any other cable that goes near your antennas, e.g., to a rotator, to a remote tuner or
relay/switchbox, to steppir motors, to tower lights or utility outlets, …;
• on the power cable at an outdoor compact fluorescent lamp if this cable runs
anywhere near your antennas, and also where this cable enters your house;
• on both the high- and the low-voltage sides of any solid-state transformer that feeds
low-voltage lighting near your antennas;
• at the ground-fault circuit interrupter (gfci) of any ac power circuit that goes near
your antenna.6
second,
• on every 60-hz ac power cable that feeds your shack;7
• on every other cable (antenna-rotator, telephone, tv, computer network, etc.) that
comes into your shack;
• on every cable of every computer, peripheral, keyer, tnc, switching power supply
(including wall warts and battery chargers, especially laptop-computer power adaptors)
and other device connected to your radio that oscillates, switches, or digitates;
• on the ac line cable/cord of any compact fluorescent lamp or any incandescent lamp
with a dimmer and/or solid-state transformer that is plugged into your shack circuits.8
third,
• at any identified qrn source in or around your house;9
• on the cables of an intrusion / fire / other alarm system, at panels, multiplexers,
telephone-line interfaces, radio-telemetry interfaces, 60-hz power supplies, standby
battery charger / supplies, etc.;
• on tv cables, both where they enter your house and where they reach tv sets,
converters, vcrs, dvrs, cable modems, etc.;
• on 60-hz ac power cables and any audio and video cables connected to tv sets,
music and “home theater” systems, etc.;10
• on telephone cables, both where they enter your house and where they reach telephone
sets, answering machines, cordless base stations, adsl modems, isdn
modems, pots modems, etc.; and on all power cables (e.g., from wall warts)
connected to telephone-line-connected equipment; also on the handset cords of
telephone sets.11
离线liujifeng
只看该作者 67楼 发表于: 2010-01-08
磁环有如此功效 :confused: 我也买几个试试。
离线bg4trf
只看该作者 68楼 发表于: 2010-01-08
只有换住房!ham 买楼要考虑天线。。。。
要和老外以一样住郊外,郊区,最好是海边 :)
这就是为什么比赛都要找一个好的地方
离线liujifeng
只看该作者 69楼 发表于: 2010-01-08
这就是为什么比赛都要找一个好的地方
住郊外郊区好是好,就是贼多难防
离线liujifeng
只看该作者 70楼 发表于: 2010-01-09
今天装了几个磁环,底噪还是7~7.5,基本上维持原状。只得继续启用att。。。。
离线BH4SKP
只看该作者 71楼 发表于: 2010-01-09
今天装了几个磁环,底噪还是7~7.5,基本上维持原状。只得继续启用att。。。。 [表情]
几个没用的,按照nq贴的那个秘籍,自家最起码要用上几公斤。。。。电话线,电源线,网线。。。都要套上磁环
离线BH4RKH
只看该作者 72楼 发表于: 2010-01-09
我用了tdk的兩種磁環 一種內徑9mm 另一種比較大 內徑13mm
小图 | 大图 图片
  • 哈罗CQ火腿社区 - 天线和铁塔 - ————【紧急求助】关于底噪和天线的问题———— - 第4页
离线bg5cic
只看该作者 73楼 发表于: 2010-01-10
晚上在掏宝上买了二手的70个9mm,0.49元一个,全新的40个11mm的,2.5元一个,三天后到货,加上看效果
13mm的,要4元下个,我用的是-7的线,外经是10mm多点,13mm的磁环好像有点浪费。
离线bg5cic
只看该作者 74楼 发表于: 2010-01-10
打算把11mm的40个磁环,在馈线的二端各加20个,另外70个9mm的加在电脑、电源等等能加的地方。
离线bg5cic
只看该作者 75楼 发表于: 2010-01-10
再问一下,磁环离电台太近会不会对电台内部元件有影响?
离线BH4RKH
只看该作者 76楼 发表于: 2010-01-10
bg5cic
谢谢良好的qso
我目前用了大概60个磁环 都在室内 没有在室外的天线馈线上使用磁环
南京今天阴雨天 下午听了一下14兆 底噪大概s6-7 可以抄收国外电台 但是无法通联上
离线bg5cic
只看该作者 77楼 发表于: 2010-01-10
谢谢
因为外面在下雨,我现在只加了20个在室内的馈线端,效果好像不是很明显,今天我这里14m的底噪很低,只有6左右,加了磁环还没感觉。
离线BH4RKH
只看该作者 78楼 发表于: 2010-01-10
谢谢
今天我这边底噪14兆底噪也比以往低 现在14。225兆有西非电台ty5zr
离线bg5cic
只看该作者 79楼 发表于: 2010-01-10
看来我的天线不行呀,没听到声音,我用的是r8天线还不如倒v呀。
