  • 50707阅读
  • 138回复
IC-706 vs FT-897 [复制链接]
离线ergotro
只看该作者 60楼 发表于: 2003-01-24
我认为买706mk2g好,经过多次的改进已经逐渐走向成熟!
ft-897,属新型号到底性能如何,还要靠各位用时间去检验!:d :d :d
离线admin
只看该作者 61楼 发表于: 2003-01-24
最初由 bg3rj 发布
不过706机器上的显示图看起来象是中频频率偏移,可以左右移动。对邻频干扰有抑制作用,如7mhz人多的时候挺明显的。我习惯右手操作,总感觉有些别扭。
shift的功能很多机器都有。在ssb下用shift,会影响音质,只能用一点点,cw下则比较有效。最好是有if dsp,实现low cut或high cut。
离线BD3RJ
只看该作者 62楼 发表于: 2003-01-24
我一般只在7mhz人多的时候使,对邻频干扰有抑制作用。
离线BG4IHP
只看该作者 63楼 发表于: 2003-02-06
最初由 ergotro 发布
我的观点是:研制897的肯定也熟悉706,也一定会学习706的优点,改进706的不足。这就是新产品的优势 。
离线gb5bbb
只看该作者 64楼 发表于: 2003-02-06
那位老腿能否具体介绍一下FT-897
那位老腿能否具体介绍一下ft-897。
离线BA4VE
只看该作者 65楼 发表于: 2003-05-28
up
离线zha173
只看该作者 66楼 发表于: 2003-05-29
事实上在功能上706根本不能和897比,仅凭897中频dsp标准配置就可以把706打扁。玩过897的人才知道它的dsp功能有多强,不是706可比拟的。不过个人感觉897在使用稳定性和线路保护这方面似乎要比706差些。
离线topgun
只看该作者 67楼 发表于: 2003-05-29
ic-706miig compared to ft-857
the 706 has a really big display and a big tuning knob and relatively easy to use buttons and menus. the 706 is easier to use in some ways than any of the yaesu radios due to buttons for often used functions that are menu items on yaesu radios. in other ways it's more difficult due to the multiple menu scheme. the 706 is
taller wider but has less depth than the 857. the control head is much bulkier. the 706 has a single cable for remoting the head whereas the 857 requires two. the dsp on the 706 is nearly useless except the notch filter which is excellent. the noise blanker is very weak. if the 857 dsp operates as expected (because it's the same as the 897) it blows my 706 away in this area. the receive on the 857 seems somewhat better in terms of sensitivity (the 100d seems to be even better by the way) the 706 is still a good radio however after over 3 years i"m swapping it out for the 857 because of the superior dsp, filters, noise blanker and other features. the 706 is definitely due for a modernization workover. it will become a remote base on my repeater
from eham.com reviews
离线ADSL
只看该作者 68楼 发表于: 2003-07-15
离线chengrc
只看该作者 69楼 发表于: 2003-07-15
我有第一代的706也有7O6Mk2g
我支持6bf对706的评价!:o
离线BA7GM
只看该作者 70楼 发表于: 2003-07-16
用一代706一年多了,感觉不错大热天在户外.车上都很好!!
离线BG5BDB
只看该作者 71楼 发表于: 2003-12-06
FT897现在价格多少?
看了上面的讨论的帖子,都过去挺长时间了,今天把这个帖子捞上来,想问一下:
1、有没有新的对ft897的测试报告
2、价格现在多少?最近有点想在香港买一台
谢谢各位老ham啦!
离线BG2VO
只看该作者 72楼 发表于: 2003-12-07
ft897的体积比706mkiig大一倍还多,不便于携带。
离线BG5BDB
只看该作者 73楼 发表于: 2003-12-08
最初由 bg2vo 发表
尺寸:
ft897: 200*80*262 (mm) 3.9kg
i706m2g: 167*58*200(mm) 2.45kg
好像不是大一倍多吧?
另外 ft897可以里面可以装2个电池,可以野外操作,大一点可以理解吧
离线BG2VO
只看该作者 74楼 发表于: 2003-12-08
我是说体积大一倍多呀。当然,可以装电池的确是携带优势。
ft897: 200*80*262 (mm)=4.19立方分米
i706m2g: 167*58*200(mm)=1.94立方分米
一个大于4,另一个小于2,倍数为2.16
还有一个类似机器(100w短波+6m+u/v),ft857,体积为1.88立方分米
体积最小的类似机器应该是ft-100d了,只有1.77立方分米
离线huashao128
只看该作者 75楼 发表于: 2003-12-08
刚在深圳买8300。正在作电池。感觉。。。。。。单边带。。。。。。可能天线不好
离线BG7FT
只看该作者 76楼 发表于: 2003-12-08
最初由 huashao128 发表
8300?
706还是897?
离线BD8GA
只看该作者 77楼 发表于: 2003-12-08
楼上的说:“正在作电池”,我想应该是897吧。
嗬嗬
离线bd5ir
只看该作者 78楼 发表于: 2003-12-08
有哪位大虾知道ic-706mk2g的开频方法?否则“驻波检测功能”发挥不了作用。这里先谢谢啦!另外这款机器发热也实在厉害,经常吓得我不敢cq。
离线BG2VO
只看该作者 79楼 发表于: 2003-12-08
开频资料到www.mods.dk里找,非常全。
