  • 32240阅读
  • 203回复
好消息!!!超级补品!!!铷模块,高精度频率基准接受预定!!切勿错过!! [复制链接]
离线slka
只看该作者 60楼 发表于: 2005-08-01
因为今天去济南出差,明天汇款,要两个。
离线BD4SEQ
只看该作者 61楼 发表于: 2005-08-01
谢谢二位老师了!!!
离线BG2VO
只看该作者 62楼 发表于: 2005-08-01
嘿嘿,原来我有些多虑了。我们这里有一个中科院声学所的同事,以前搞计量和算法的,他说他以前用过铷钟,没有担心过有辐射,仪器就摆在实验室里,谁都可以用,哈哈。我想可能是俘虏客生产的频率计之类。 [表情] [表情]
回头我也测一下铷振荡器的短稳,尝试一下。也没准俺们同事也买这玩意儿,看他挺馋的, [表情] [表情]
俘虏客?也许就是思源的那种,好像我国对俘虏客品牌很钟情。另外那个铯钟的警告估计是因为铯金属太活跃见空气就自燃的原因。
dana频率计的9位好像测不出这个短稳,赶快升级频率计吧。
初步测量了我的sr625的秒稳是3e-11,不知为什么比指标的2e-11还大,也许是因为是老货?trimble晶振实际测量大约为4e-12,很不错。测到这个量级上,hp53131a也不够了(测量的结果是8e-12,因为也有本底噪音),是用sr620测量的。
补充:铷钟秒稳最新结果:7e-12,比指标高。
假如你只有8位9位的频率计,你根本就看不出来,10位的也没问题,要11位频率计才能在最后一位有轻微影响。
[quote=ba7kw ]发货名单:
2vo 10pcs(8个没字,2个有字)
[/quote]
抄收了!
离线liu4ic
只看该作者 63楼 发表于: 2005-08-02
铷同位素 rb87有放射性吗
对人有危害吗?请知到的朋友解答
rubidium was discovered in 1861 by bunsen and kirchoff in the mineral lepidolite by use of the spectroscope. the element is much more abundant than was thought several years ago. it is now considered to be the 16th most abundant element in the earth's crust. rubidium occurs in pollucite, carnallite, leucite, and zinnwaldite, which contains traces up to 1 %, in the form of the oxide. it is found in lepidolite to the extent of about 1.5 %, and is recovered commercially from this source. potassium minerals, such as those cound at searles lake, california, and potassium chloride recovered from brines in michigan also contain the element and are com- mercial sources. it is also found along with cesium in the extensive deposits of pollucite' at bernic lake, manitqba. rubidium can be liquid at room temperature. it is a soft, silvery-white metallic element of the alkali group and is the second most electropositive and alkaline element. it ignites spontaneously in air and reacts violently in water, setting fire to the liberated hydrogen. as with other alkali metals, it forms amalgams with mercury and it alloys with gold, cesium, sodium, and potassium. it colors a flame yellowish violet. rubidium metal can be prepared by reducing rubi- dium chloride with calcium, and by a number of other methods. it must be kept under a dry mineral oil or in a vacuum or inert atmosphere. seventeen isotopes of rubidium are known. natural-occurring rubidium is made of two iso- topes rb85 and rb87. rubidium47 is present to the extent of 27.85% in natural rubidium and is a beta emitter with a half-life of 5 x loll yrs. ordinary rubidium is sufficiently radioactive to expose a photographic film in about 30 to 60 days. rubidium forms four oxides: rb2o, rb2o2, rb2o3, rb2o4. because rubidium can be easily ionized, it is being considered for use in ion engines" for space vehicles; however cesium is somewhat more efficient for this purpose. it is also proposed for use as a working fluid for vapor turbines and for use in a thermoelectric generator using the magnetohydrodynamic principle where rubidium ions are formed by heat at high temperature and passed through a magnetic field. these conduct electricity and act like an armature of a generator and cause electricity to be generated. rubidium is used as a getter in vacuum tubes and as a photocell component. it has been used in making special glasses. rbag4i5 is important as it has the highest room conductivity of any known ionic crystal. at 200c its conductivity is about the same as dilute sulfuric acid. this suggests use in thin film batteries and other applications. the present cost in small quantities is about $10/gm. (99.9%), or $300/lb.
离线BG2VO
只看该作者 64楼 发表于: 2005-08-02
很多同位素都是有轻微放射性的,自然界放射性是普遍存在的。我有个放射性(盖革)计数器,经常偶尔会有计数。
组成我们身体的重要成分以及在大自然广泛存在的碳元素,主要是c12,但也有少量c14是放射性的,半衰期是5000多年,因此可以用来确定生物的年代:http://www.homestead.com/davidgoliathministries/carbon14.html
刚才查了一下,rb87的确有很微弱的放射性,半衰期为4800万年(半衰期越长放射性越小)。
这样,也有用rb87做长时间尺度来确定岩石的年代的,参考:http://www.astro.washington.edu/larson/astro150u/coursepak/cp15_radioactivedecay.pdf
另外,rb87衰变后发射电子(能量只有0.275mev),而电子很容易被吸收,不会产生什么影响。
要知道,常见的pc显示器里面都是大量的电子击打荧光粉才发出光来。有人说显示器有放射性,是由于crt管会产生微量的x射线,而不是由于电子。
感兴趣的可以参考一篇文章《铷放射化学》:http://library.lanl.gov/cgi-bin/getfile?rc000003.pdf
另外铷的特性可参考这里:http://en.wikipedia.org/wiki/rubidium
其中的使用警告只有防止与水反应发生火灾,并没有提及注意放射性。
铷与碳一样,是自然界广泛存在的,不是人造的。至于上面说:
这个我也是头一次看到。也许c14占c12的比例少,而rb87占整体rd比例高?
离线BA7KW
只看该作者 65楼 发表于: 2005-08-02
关于模块的插头
今天问过一家卖台湾产品的公司,说可以定制,周期是2到3周,明天去下单,这样用起来要方便得多。
离线BG2VO
只看该作者 66楼 发表于: 2005-08-02
7kw:我的带了几个头?免费随模块送吧。
刚才龙邦来电话,说广州的货到了,晚些时候给送来,真快!
回去测测放射性,但估计测不出来,两层金属壳,就是有电子早就被吸收了。而且里面的铷很少,甚至不足几毫克。
0.275mev就是27.5万伏特电压下电子被加速的能量,并不大。电视机的电子大约有0.02mev。
离线BA7KW
只看该作者 67楼 发表于: 2005-08-02
我手上只有1个
7kw:我的带了几个头?免费随模块送吧。 [表情]
货主答应到货场拆回插头给我的,但估计不一定能找到,我想再订一些新的回来,这几天您先拿插针凑合着试验一下,等插头(旧的或新的)到了,我马上发给您。
离线BG2VO
只看该作者 68楼 发表于: 2005-08-02
好的,但最好是老的。新定做的插头担心中间的那个射频接口做不好。
离线bd1es
只看该作者 69楼 发表于: 2005-08-02
ba7kw,我的汇款应差不多到帐了,是940元。麻烦查证一下以便发货。
谢谢!
离线BA7KW
只看该作者 70楼 发表于: 2005-08-02
您的地址??
谢谢!
请发悄悄话,明天发给您!
离线liu4ic
只看该作者 71楼 发表于: 2005-08-02
看下面连接:
http://www.bjpu.edu.cn/focus/dynamic.jsp?articleid=706
阴极是电子管的心脏器件,中大功率电子管广泛应用于广播、军事通讯、电子对抗、雷达、工业应用、医疗、科学设备和宇航等各个领域。目前在中大功率电子管中普遍使用的是已有百年历史的钍钨阴极,而这种阴极虽然发射稳定性好,但具有工作温度高、难以加工成型、存在放射性污染三项致命缺陷。急需研制可以替代钍钨的环保新型阴极材料。
我家还有几百只电子管呢,哪天仍到山沟里,免的放射污染,哈哈
离线bg2ihr
只看该作者 72楼 发表于: 2005-08-02
货已收到,多谢!!!
离线liu4ic
只看该作者 73楼 发表于: 2005-08-02
http://www.ben.com.cn/bjrb/20050413/gb/bjrb%5e18947%5e14%5e13r14a02.htm
http://sc.info.gov.hk/gb/www.epd.gov.hk/epd/tc_chi/environmentinhk/waste/prob_solutions/radioactive_waste.html
你有空测试一下这些东西
离线bg2ihr
只看该作者 74楼 发表于: 2005-08-02
上传一些100323-001的芯片资料1
离线bg2ihr
只看该作者 75楼 发表于: 2005-08-02
上传一些100323-001的芯片资料2
离线bg2ihr
只看该作者 76楼 发表于: 2005-08-02
上传一些100323-001的芯片资料3
离线bg2ihr
只看该作者 77楼 发表于: 2005-08-02
上传一些100323-001的芯片资料4
离线BG7KH
只看该作者 78楼 发表于: 2005-08-02
kw:今天下午我汇了479.9元。应该到账了,我再等你的接头。
打算diy一个频率基准,用倍频出 270.0000mhz 呵呵。机壳,电源等都买齐了,就等接头了。
离线bd1es
只看该作者 79楼 发表于: 2005-08-03
请发悄悄话,明天发给您!
哦,我真糊涂,地址:
100086
北京市海淀区知春路111号 理想大厦3层 科技部
穆新宇
电话:13801169177
谢谢!
