  • 11709阅读
  • 65回复
YAESU病人! [复制链接]
离线bg8hl
只看该作者 40楼 发表于: 2010-08-09
他会买ftdx9000 我坚信:)......
离线BA1IO
只看该作者 41楼 发表于: 2010-08-09
放设备下方作为基台美~!
817如果在上面!应该个头差不多!
离线Sullivan
只看该作者 42楼 发表于: 2010-08-09
滤波电容从倍压改成普通滤波就可以把120v的电源改为230v了。当然如果有完善的过欠压保护,可能要调一下。
这个电源看上去的确很朴实,呵呵,就是那个开关太……掉面子了
离线BA1IO
只看该作者 43楼 发表于: 2010-08-09
这个电源看上去的确很朴实,呵呵,就是那个开关太……掉面子了 [表情]
小红灯!听好的!越反三俗越得玩! :d
离线bg8hl
只看该作者 44楼 发表于: 2010-08-11
:).... sp-5
这款sp-5 包含了timewave的dsp套件
dsp-59y digital noise filter
dsp-59
the timewave dsp-59y is the first digital signal filter built to match existing yaesu radios using the sp-5 and sp-6 external speakers. the dsp-59y, using the same highly aclaimed filter set as the dsp-599zx, is designed to fit in the phone patch slot of the speaker. it uses the existing a/b switch and 1/4" stereo phone jack on the speaker cabinet and also allows the existing analog filters to be used.
the timewave dsp module allows the owners of yaesu equipment to maintain the original equipment manufacturer's appearance. this filter gives the ft1000, ft1000d, ft990, ft890, ft900, and frg100 the latest noise reduction and filtering dsp technology.
the speaker mounted dsp-59y can be used with other radios and transceivers made by other manufacturers such as kenwood, icom, ten-tec, and alinco. there are no design limitations in either the dsp-59y or the speaker that prevents their use with other radios or transceivers.
the dsp-59y is part of the latest generation of timewave dsp filters. the dsp-59y has all the digital noise filters found in the dsp-599zx incorporating the newest high speed cpu. running at 36.8 mips, the extra power gives the user unparalleled features and field upgradability for the future. the dsp-59y does not have the test instrument mode.
小图 | 大图 图片
  • 哈罗CQ火腿社区 - 设备 - YAESU病人! - 第3页
离线BA1IO
只看该作者 45楼 发表于: 2010-08-11
:).... sp-5
dsp-59
太高级了!diy的还是yaesu授权的?
离线bg8hl
只看该作者 46楼 发表于: 2010-08-12
yaesu授权的 哈
sp5 右上角有安装孔位哈
离线BG4FYM
只看该作者 47楼 发表于: 2010-08-13
[表情] 太客气了啊! 我今年28岁!
提手是-.-   .--.   .--. 那里买的!160吧好像!跟美国一个价格! [表情]
电源美国邮购的!200刀含运费!关税200元!很轻!
这个电源要200刀,真是病得不轻啊
离线BD1GO
只看该作者 48楼 发表于: 2010-08-14
围观病人。飘过
离线BD6QBQ
只看该作者 49楼 发表于: 2010-08-14
:).... sp-5
这样毒害下去,估计1io受不了。哈哈哈!
离线BA1IO
只看该作者 50楼 发表于: 2010-08-14
这样毒害下去,估计1io受不了。哈哈哈! [表情]
:d :d 太大!太大!
离线bd4sv
只看该作者 51楼 发表于: 2010-08-14
我只能说楼主用情专一
离线虚无散人
只看该作者 52楼 发表于: 2010-08-20
老前辈:你的ft-450加焊电容了吗?看了本论坛的帖子http://www.hellocq.net/forum/showthread.php?t=226087&page=3&pp=30)心里没底,害怕呀.....
只看该作者 53楼 发表于: 2010-08-21
uv机器还是喜欢yaesu的,短波设备中业余机器还是喜欢icom的。
离线BA1IO
只看该作者 54楼 发表于: 2010-08-21
[quote=虚无散人]老前辈:你的ft-450加焊电容了吗?看了本论坛的帖子http://www.hellocq.net/forum/showthread.php?t=226087&page=3&pp=30)心里没底,害怕呀.....[/quote]
不老啊!我的应该是新款!就算是老款也没出现问题!
离线BA1IO
只看该作者 55楼 发表于: 2010-08-25
离线BG1EAO
只看该作者 56楼 发表于: 2010-08-25
http://v.youku.com/v_show/id_xmjaxmtmymdi0.html
开机!
够折腾的,有yaesu的咖啡杯要不?
离线BA1IO
只看该作者 57楼 发表于: 2010-08-26
够折腾的,有yaesu的咖啡杯要不?
只看该作者 58楼 发表于: 2010-08-26
以前还真见过什么展会上yaesu的马克杯还有t恤,但是看样子是代理商自己做的非日本原厂定制。
离线BA1AK
只看该作者 59楼 发表于: 2010-08-26
崔老师跟牙书豁出去了。
