  • 20247阅读
  • 69回复
建议用钢丝 [复制链接]
离线BG5BLW
只看该作者 40楼 发表于: 2008-09-30
觉得还是铜的好
离线bg6qbu
只看该作者 41楼 发表于: 2008-10-01
铜包钢是不错的选择,可是难找啊
离线BG6QCG
只看该作者 42楼 发表于: 2008-10-07
钢丝没用过,但我用的是装潢用不锈钢管,和铜线没区别。但钢丝怎么和馈线焊接?
用氧焊在钢丝上焊一个铜焊点,就可以用锡焊了.
离线BG9TX
只看该作者 43楼 发表于: 2008-11-09
刚从部队要了一卷被覆线250m,很细,3根铜丝、4根钢丝,准备搞一个80m的loop,不知道是否太细了
离线jnwysh
只看该作者 44楼 发表于: 2008-11-20
从大家的讨论中学到不少东西。不知同样截面积下,用单股铜线好还是多股铜线好,普通电线的塑胶外皮对收发信号有多大影响?
离线jnwysh
只看该作者 45楼 发表于: 2008-11-21
Antenna Wire Considerations
antenna wire considerations
characteristics and suitability of various types of antenna wire
many types of wire can be used to construct wire antennas. some of the choices include copper, copper-clad steel, copper-plated steel, aluminum, aluminum-clad steel, aluminum-plated steel, steel, hard-drawn, soft drawn, solid, stranded, bare, and insulated. none of those options are universally best in all circumstances. different mechanical, chemical, electrical, convenience, visibility, aging, cost, local-availability, and other considerations are associated with each choice. users of these various types of wire often post information about their experiences and opinions in various internet forums. that information can be very useful, but some statements are overbroad, based on technical misunderstandings, or made with insufficient knowledge of alternatives. complicating this situation, some antenna wire suppliers make outrageous claims that viewed most-favorably expose embarrassingly-shallow technical knowledge or viewed-least favorably expose attempts to willfully deceive and defraud naive antenna wire buyers.
离线soom
只看该作者 46楼 发表于: 2008-12-16
有没说是那种天线啊,我发现做装饰的那种软钢丝很适合做便携式天线啊,抗折
离线bd2bh
只看该作者 47楼 发表于: 2008-12-20
1/8 nothing else
离线shoulei
只看该作者 48楼 发表于: 2009-04-19
厉害啊~44米啊~就是高度有点遗憾~
离线chnsat0009
只看该作者 49楼 发表于: 2009-05-11
前几天买了盘0.494平方的橡皮裹麻布的被覆线,不知道能不能用到发射上。
离线BD2VBB
只看该作者 50楼 发表于: 2009-05-12
我记得高频只用外皮。铜包钢线我想是最好的
这叫趋肤效应,也就是高频电流只走导线的表皮。
不锈钢的高频特性不好。
离线bd2bh
只看该作者 51楼 发表于: 2009-05-13
顶。。。。。。。。。
一直不主张用钢丝,它不是不能用,任何导体都可以做天线电线,如果你不讲究效率的话,你也可以用电阻丝做天线。
我没见过任何国家专门发帖建议用钢丝做天线,相反国内好的人在推波助澜,想用钢丝,而且诱导新手用钢丝做天线,我不是说那个人,我觉得我们发帖的目的,是把好的经验和技术共享,奉献给大家,让大家少走弯路,这个帖子还有人顶的话,就事论事说,有点不负责任,或者说方向性错误,引导人犯错误,特别是低级的错误!
玩无线电的,搞自然科学的,还是一句话,按规律办事,讲究实事求是!
离线BD2VBB
只看该作者 52楼 发表于: 2009-05-13
话说得到位。
离线BG2WAC
只看该作者 53楼 发表于: 2009-05-13
在紧急的情况可以用,我曾经用红箭73导弹的信号线做短波天线,那是一种很细的芯线看似像钢丝外面缠绕纤维的,外径包括缠绕的纤维能比头发丝稍微粗那么一丁点,我就用这种线也通了很多电台。
现在部队不少的短波天线是那种多股钢丝和铜丝混合型的,但是钢的比例大于铜。
离线chnsat0009
只看该作者 54楼 发表于: 2009-05-18
哦,领教了。看来我想用0.49-0.5平方毫米的3铜4钢被覆线做天线有希望了。
离线bd2fw
只看该作者 55楼 发表于: 2009-08-29
学习不锈钢.
离线BG3MKZ
只看该作者 56楼 发表于: 2009-08-29
当然是铜包钢丝好了。
离线阿枪
只看该作者 57楼 发表于: 2009-09-03
铜的电导最好,但是机械强度差些。要是只是到v之类的用漆包线都可以好几年没问题,成本也不是太高。要是选用不锈钢丝,尽量选择低磁/无磁的不锈钢。
离线bg1iwk
只看该作者 58楼 发表于: 2009-09-06
顶起来。。。。。
离线BG5TAI88
只看该作者 59楼 发表于: 2009-09-11
我看用便宜易购的双屏蔽或四屏蔽的铜镀锌-5/75欧的馈线不错!
