  • 15283阅读
  • 49回复
IC7000 黄岩岛唯一选用设备!!! [复制链接]
离线BA0BZ
只看该作者 40楼 发表于: 2007-05-15
ic7000用什么电源?
acom1000是什么样的功放?
请顺便简单介绍几句
acom 1000 specifications
• frequency coverage: all amateur bands 1.8-54mhz; extensions and/or changes on request.
• power output: 1000w pep or continuous carrier, no mode limit.
• intermodulation distortion: better than 35db below rated output.
• hum and noise: better than 40db below rated output.
• harmonic output suppression:
  -1.8-29.7mhz - better than 50db below rated output;
  -50-54mhz - better than 66db below rated output.
• input and output impedances:
  - nominal value: 50 ohm unbalanced, uhf (so239) type connectors;
  - input circuit: broadband, vswr less than 1.3:1, 1.8-54mhz continuously (no tunings, no switching);
  - bypass path vswr less than 1.1:1, 1.8-54mhz continuously;
  - output matching capability: better than vswr 3:1 or greater at reduced output levels.
• rf gain: 12.5db typically, frequency response less than 1db (50 to 60w drive power for rated output).
• primary power: 170-264v (200, 210, 220, 230 & 240v nominal taps, 100, 110 & 120v taps on request, +10%-15%tol.), 50-60hz, single phase, 2000va consumption at rated output.
• complies with ce safety and emc requirements, as well as fcc-regulations (6,10 & 12m bands lock provided).
• size & weight (operating):
  -wxdxh: 422x355x182mm, 22kg.
  -(16.6x14x7.2 inches, 48.5lbs)
• operating environments:
  - temperature range: 0...+50 degs.celsius;
  - humidity: up to 75% @ +35 degs.celsius.
  - height: up to 3000m above sea level without output deterioration
离线cqht
只看该作者 41楼 发表于: 2007-05-15
本次使用过程中,如果使用功放,ic7000功率一般开65~70%,感觉还好,没有出问题。
rtty那天,使用3dp的接口,用13针线连接到ic7000,使用fsk,但是由于ic7000没有单独的控制功放的莲花头输出,因此在rtty的时候,没有办法使用功放(否则就要临时改13针接口了),这种情况下ic7000输出100w工作了3、4个小时,在白天的阳光下工作,当时我们很担心,机器确实也很烫,不够它总算是挺过来了。
陈老师 你们的电源是如何解决的 有没有用特别的东东
七三
离线BA4RF
只看该作者 42楼 发表于: 2007-05-15
七三 [表情]
在那种情况下,唯一的选择是发电机 ;)
离线BA7NQ
只看该作者 43楼 发表于: 2007-05-15
这样头脑清醒还行,一旦配合不好那可是要惹麻烦出来的。
记得第一天在rock3架台的时候,老外居然没有给rock3准备控制功放的ptt控制接口,vhf上问,号称找不到了,我跟1aax说,实在不行就用脚踏开关控制(脚踏开关有两个头输出),1aax说这样不好吧,虽然设备不是我们自己的:d,之后想了想,用cw的时候肯定还是要解决这个问题,只好老老实实动手做了一根线出来,可怜当时现场没有剥线工具,还是用牙剥的线。
是的是的,老大们受委屈了。
离线BA5AG
只看该作者 44楼 发表于: 2007-05-15
是的是的,老大们受委屈了。 [表情]
你捂着嘴做什么,又没要你咬线
离线BD3RJ
只看该作者 45楼 发表于: 2007-05-15
下次能改用psk31吗?
只看该作者 46楼 发表于: 2007-05-15
事实证明,7000的发热对使用没有影响。
离线BG7JPT
只看该作者 47楼 发表于: 2007-05-15
好機器,好機器
离线jiffz
只看该作者 48楼 发表于: 2007-09-11
有关dx&ic-7000 的好贴,收藏学习中...
离线BD7PA
只看该作者 49楼 发表于: 2007-09-22
使用中,不管 ic-7000 發熱,風扇自動變速配合處理,有預提速方式的:散熱 提前量 設計。
中頻 dsp 產生 “如水中的信號”,操作者對 ic-7000 nr 閥值設定過度導致,經驗值爲 4,nb 用於 am 調製。
數字dsp帶通濾波器作用明顯,經驗值:1.8--2.4khz (可變)。
