  • 30749阅读
  • 245回复
2006 CQWW CW 参加?成绩?先汇总一下吧 [复制链接]
离线BA5CW
只看该作者 40楼 发表于: 2006-11-21
请教个问题,在10分钟规则下,系数台在其他波段是不是每10分钟只能工作一个新系数。ms新手,问题多多
离线BA1RB
只看该作者 41楼 发表于: 2006-11-21
不是。是如果系数台在一个波段工作了一个系数,在接下来的十分钟内,它不能qsy出这个波段,可以在这个波段内工作其他新系数。
离线VR2KW
只看该作者 42楼 发表于: 2006-11-21
ms规则解析的不够清楚,那位能够去了解一下这个10分钟限制和系数台应用的问题。
离线BA1RB
只看该作者 43楼 发表于: 2006-11-21
加上带通滤波,一个波段一个最好了,如果有那么多天线的话,3个也可以。
再看看b1z现在的操作员,知道为什么不是僧多粥少了吧?只不过大家挑肥拣瘦,显得...,ms是非常体现团队总体水平和团队合作精神的...
不过现在是不是有个每小时改变波段次数的限制,那就需要全面衡量一下了。
ms是十分钟规则,m2才是每小时改变波段次数的限制。
离线BA1RB
只看该作者 44楼 发表于: 2006-11-21
我已经跟k3est和n1nd确认过,并分析过各种情况是否合法。下面举一个例子,请各位大佬看看有没有违反ms规则的地方:
suppose we have 4 transceivers (a,b,c,d), the operations sequences are:
1, at utc 0000, transceiver a call cq at 20m band and make qsos with stations call back. b,c,d listen on 10m, 15m, 40m bands.
2, at utc 0030, transceiver a call cq at 20m band and make qsos with stations call back. b found a new multipiler in 10m, transmitted and make qso with this new multiplier station. c,d listen on 15m, 40m bands.
3, at utc 0031, transceiver a call cq at 20m band and make qsos with stations call back. b found another new multipiler in 10m, transmitted and make qso with this new multiplier station. c,d listen on 15m, 40m bands.
4, at utc 0041, transceiver a call cq at 20m band and make qsos with stations call back. d found a new multipiler in 40m, transmitted and make qso with this new multiplier station. b, c listen on 10m, 20m bands.
5, at utc 0100, transceiver a stop calling cq, and then c start to call cq on 15m band and answer call back station. a, b, d listen on 20m, 10m, 40m bands.
6, at utc 0111, transceiver c continue to calling cq on 15m band and answer call back station. station a found a new multiplier in 20m band, and make qso with this new multiplier station. b, d listen on 10m, 40m band.
what if in step 6, the time changes to utc0105?
离线BA7NQ
只看该作者 45楼 发表于: 2006-11-21
我对ms这个规则10分钟规则也比较模糊,以前都是老老实实地只用1台机器发射,并且在每个波段工作10分钟后再换波段(10分钟已该波段第一个记到log中的qso开始计算)。
下面是k2kw关于如何提高ms成绩的一篇文章,里面也谈到cqww的10分钟规格问题,并提到,cqww的ms规则和arrl的ms规则有不相同的地方,要充分利用规则。
http://www.k2kw.com/ms_tips.html
说实话,我现在还不是很清晰。
我也曾经问过cqww的boss,k3est,他的回复如下:
dear terry,
thank you for your letter concerning the cqww. yes, in the example you describe, both can transmit at the same time. the mult station can only wrk multipliers. if you have any other questions please just ask terry.
have fun this fall!
73
bob, k3est
________________________________
sent: sat 8/12/2006 5:38 am
to: k3est@cqww.com
subject: about ms
dear bob,
i have a question about cqww ms mode:
i have two station, one is calling station, one is multiplier station.
during the calling station transmiting, and the multiplier station find a new multiplier in another band, dose the multiplier station allowed to work the new multiplier? than't mean, my calling station and multiplier are transmiting in same time....
73! de ba7nq terry
离线bd3af
只看该作者 46楼 发表于: 2006-11-21
系数台的日志要单独标注吗?
single transmitter (ms): only one transmitter and one band permitted during any 10-minute period, defined as starting with the first logged qso on a band. exception: ***one—and only one—other*** band may be used during any 10-minute period if—and only if—the station worked is a new multiplier. logs found in violation of the 10-minute rule will automatically be reclassified as multi-multi.
“one—and only one—othe”如何理解?系数台在一个波段内连续出现两个系数不是一个系数了,这个如何操作才能满足规则?
麻烦om给讲讲,谢谢!
离线BG7LKJ
只看该作者 47楼 发表于: 2006-11-21
那就是认可了在十分钟(ms)内如果其它波段有新字头就可以去操作?但是十分钟内一次还是有其它意思?
离线BA7NQ
只看该作者 48楼 发表于: 2006-11-21
我的理解是,大家不用把目标关注在区分自己的“主叫台”和“系数台”上,而只要关心你的log是怎么显示的。
举个例子,加粗的字体表示新字头:
0010 21.300 ba1aa (在15米上,你的log显示,第一个qso是从0010开始的)
0011 21.300 ba1bb
0012 21.300 ba1cc (从10分钟规则,你必须在15米上停留10分钟,但是...你发现了其他波段有个新字头)
0013 28.400 xe1kk (在10米发现xe1kk这个新字头,马上过去联络,不管你用你的“主叫台”还是“系数台”来叫他)
0014 28.410 ja1aa (你要继续在10米上工作10分钟,从与xe1kk的联络时间开始计算)
0015 28.420 ba1aa (继续在10米上qso)
0016 14.200 hc8n (但,如果你又发现其他波段有新字头,你可以马上去和他联络)
0017 14.300 ba7dd (继续在20米上工作,至少10分钟)
0018 14.300 ba7ee
0019 14.300 ba7ff
0020 14.300 ba7gg
0021 14.300 ba7hh
0027 21.300 ba1ham (在20米上停留够10分钟了,没有什么传播,可以qsy到15米了)
离线BA5CW
只看该作者 49楼 发表于: 2006-11-21
真是********啊,解决我想暴了脑袋的事情。
3af是看我dx联盟的帖子的吧,我现在终于理解了英文原意,应该这么断句***one—and only one—other band ***,我原来的翻译错了。哈哈,现在在想1rb的例子了,更复杂。我得好好研究了。
离线BA1RB
只看该作者 50楼 发表于: 2006-11-21
系数台的日志要单独标注吗?
麻烦om给讲讲,谢谢!
我不知道是我们理解英文的方式有问题还是美国人有问题。上次有个美国人,我跟他讲这段话时详细做了主谓宾分析,他才看懂。
“one—and only one—other”修饰的是"band",他的语义到“band”就结束了,不会延长到后面的“multiplier”。
不过最终怎么样还是看cq杂志社的解释吧,毕竟cq杂志社拥有“最终解释权”。
我们2004年玩ms时就是这样玩的,log也没有被reclassify成mm。
离线BA5CW
只看该作者 51楼 发表于: 2006-11-21
这个说法不太对吧,你在28.400工作以后仍然可以回到21兆继续主叫而不违反规则。
离线bd3af
只看该作者 52楼 发表于: 2006-11-21
举个例子,加粗的字体表示新字头:
0011 21.300 ba1bb
0018 14.300 ba7ee
0019 14.300 ba7ff
0020 14.300 ba7gg
0021 14.300 ba7hh
那么可以理解为在某个10分钟内,如果有新的系数就可以换波段。
仅仅一次理解为因为有新的系数就可以波段,但,要持续10分钟。
在刚刚换到波段的记录时间的10分钟内,又发现新的系数,又可以换波段了,换过以后持续10分钟(这10分钟内,在同一波段上可以任意记录,不需新系数)
以上理解的对不对??
问题又来了:在一个波段上工作,两一个波段上发现了一个新系数,进帐,没有持续新的波段10分钟,又回到原来的波段上:
举例:
0012 21.005 ba4rf
0013 21.005 ba5tt
0015 7.003   vr2kw   (新系数,一次)
0016 21.005 ba4alc
0017 21.005 ba。。。。
这样理解,能不能满足10分钟规则?
离线bd3af
只看该作者 53楼 发表于: 2006-11-21
您好rb,谢谢讲解,以前没玩过ms,只是希望能搞明白如何操作这个:)
离线BA7NQ
只看该作者 54楼 发表于: 2006-11-21
呵呵,我都说了,我自己也是很模糊。
继续留在新字头的波段呼叫,肯定没有违反规则,rb上面的说法应该也是这个意思吧。
但按k3est给我回复的邮件,你的说法是对。
离线BA5CW
只看该作者 55楼 发表于: 2006-11-21
不知道这样翻译对不对:
多人单机:在任一10分钟时段内(定义以日记中一个波段的第一个qso开始),只允许在一个波段里发射。例外:在任一10分钟时段内,有且只有一个其他波段上能获得新系数。如果在日记中找到违反10分钟规则的将被视为多人多机组。
其他地方发的贴都改成这样了,一定要搞对啊,不然误导人家了就不好了。
离线BA5CW
只看该作者 56楼 发表于: 2006-11-21
更深的引用你的例子,我在10钟内在28.410上又发现了第二个新系数,我还能去一次。
延续上述情况只有在21兆上呼叫10分钟以后,才能到14兆上获得14兆的新系数或着离开21兆到14兆上去主叫。
下面这个例子有点悬,能不能麻烦仔细看一下,违规了吗?
0011 21.300 ba1bb
0014 21.300 ja1aa (你要继续在15米上工作10分钟,从与ba1aa的联络时间开始计算)
0015 21.420 ba1ab (继续在15米上qso)
0016 28.400 hc8n (但,如果你又发现其他波段有新字头,你可以马上去和他联络)
0017 21.300 ba7dd (继续在15米上工作,至少到0020)
0018 21.300 ba7ee
0019 21.300 ba7ff
0020 14.300 tm4f (10分钟到了,我可以到别的波段找系数了)
0021 21.300 ba7hh
0027 14.300 ba1ham (在15米上停留早够10分钟了,没有什么传播,可以qsy到20米了)
离线BA7NQ
只看该作者 57楼 发表于: 2006-11-21
不知道这样翻译对不对:
请问这个10分钟时段,以什么结束?
是不是当log上显示,出现了一个其他波段的新系数,就意味着一个新的10分钟开始?
那解下来,是继续要在这个波段上,还是可以返回qsy之前的波段,继续工作?
离线BA1RB
只看该作者 58楼 发表于: 2006-11-21
举例:
0012 21.005 ba4rf
0013 21.005 ba5tt
0016 21.005 ba4alc
0017 21.005 ba。。。。
这样理解,能不能满足10分钟规则?
你这个不违反规则。
其实你可以把你所有的台划分成两个组,一个是run台组,另一个是multi台组(可动态划分),每个台组都有十分钟规则,multi台组必须是新系数。
要是嫌麻烦就指定一个台(含有160米-10米天线)做run台,其他所有台都看成一个统一的multi台最保险。
要特别注意的是multi台不能和run台在同一个波段,即使有新系数也不行。
离线BA1RB
只看该作者 59楼 发表于: 2006-11-21
人家在0027才回的15米,应该ok的。
