  • 11221阅读
  • 54回复
ic-703 和 ft-857 我正在艰难得选择 [复制链接]
只看该作者 40楼 发表于: 2006-10-06
不要等857的中文说明书了!!!!!!和897差不多!!!!!897和857之间我已经选择了857!!!!!!857(虽然897只贵200元还代温补)好!!!!!
离线bd7sx
只看该作者 41楼 发表于: 2006-10-06
如果重在使用和性能还是703.
如果大而全亮骚还是857
离线wangchun
只看该作者 42楼 发表于: 2006-10-06
897的u/v段不好使,hf听感我觉得也不如jst145舒服。
离线BA2IE
只看该作者 43楼 发表于: 2006-10-08
青菜、萝卜各有所爱,关键是适合自己。
离线BG1CEP
只看该作者 44楼 发表于: 2006-10-08
703的天调是选件,不便宜。还有xxx也是选件,比较价格的时候要算上啊。。。
选配件
bp-228 battery pack
ni-cd 2800mah/9.6v. provides 7 hours of operating time. (approx.)
lc-156 multi-bag
carrying case for field operation. controller case and rain cover are attached.
mb-63 mobile mounting bracket
for mounting the detached front panel.
mb-72 carrying handle
convenient for carrying in the field, etc.
opc-581/opc-587 separation cables
opc-581: 3.5m (11ft) opc-587: 5m (16ft)
ut-106 dsp unit
provides dsp functions such as noise reduction and auto notch. already built-in to some versions.
ut-102 voice synthesizer unit
provides audible confirmation of frequency and mode in english.
ps-125 dc power supply
compact power supply. use with opc-1248. output: 13.8v dc (25a max.)
ah-2bantenna element
2.5m (8ft) antenna element for mobile operation with the ah-4. all bands between 7-54mhz can be matched.
ah-4 hf+50mhz automatic antenna tuner
for use with the long wire antenna matches 3.5-54mhz.
at-180 hf+50mhz automatic antenna tuner
ct-17 ci-v level converter
fl-52a 455khz cw/rtty narrow filter 500 hz/-6db
fl-53a 455khz cw narrow filter 250 hz/-6db
fl-222 455khz ssb narrow filter 1.8khz/-6db
fl-257 455khz ssb wide filter 3.3khz/-6db
hm-103 hand microphone
same as supplied.
mb-62 : mobile mounting bracket
for mounting the ic-703 main unit or the at-180.
mb-65 : mounting base
for mounting the detached front panel in a vehicle. optional mb-63 is required.
opc-589 : modular 8-pin cable adapter
opc-598 : acc 13- pin long cable for at-180 (7m; 22ft)
opc-599 : acc 13- pin cable adapter
opc-1248 : power supply adapter cable
sm-20 : desktop microphone
(optional opc-589 is required.)
sp-7/sp-10 : external speakers
离线BD3SE
只看该作者 45楼 发表于: 2006-10-08
我也买了857,但是没有中文说明书不敢用,谁有中文说明书啊?发我邮箱好吗?谢谢!zhaoyj6009@yahoo.com.cn
俺也刚买了ft-857d一起我也要中文说明书.bd3se@163.com
离线bg2sv
只看该作者 46楼 发表于: 2006-10-08
我使用的ic-703所配置的自动天调,不是选件,是内置的,很好用.dsp也是内置的.仅供参考.
离线bd2fw
只看该作者 47楼 发表于: 2006-10-09
多少钱买的?是4500元吗?
离线bg2sv
只看该作者 48楼 发表于: 2006-10-09
不是,我是成套买的,ic-703主机一台,钻石rhm-5天线一支,5安时电池一组,专用背包一个7800元,今年2月份在东北icom总代理处订购的.
离线VR2ZUY
只看该作者 49楼 发表于: 2006-11-05
请问这个组合通联效果如何?我看还有一款天线ah-703,不知和rhm-5相比如何?
离线bg2sv
只看该作者 50楼 发表于: 2006-11-06
效果还可以,rhm-5的天线总长为1.6米(7.14.21.28.50)5段,am-703没看见过不知如何.
离线VR2ZUY
只看该作者 51楼 发表于: 2006-11-06
ah-703大概1.4m长。
用上面的组合你试过最远能通多远?一般能在什么范围内通连?
谢谢!
关键是过几天想买台机器,很想搞qrp,可是不清楚qrp的难度有多大。
有人说初学者用qrp会很受打击,我不知道这个打击会有多大
离线bg2ob
只看该作者 52楼 发表于: 2006-11-06
qrp最需要的恰恰就是越大越好的高增益定向天线。
1.4米长的天线肯定能把信号发出去,也肯定有机会联络dx电台,但是效率肯定也是很低的,特别是在低波段,还不如一根长导线(当然不应该只有两三米长),但是一根导线才多少钱。
天线的好坏不能用通联过多远的电台来衡量,传播好的时候在室内用一米长的线也能把信号发到很远。天线的效果应该是用某一种类型天线(比如全尺寸dp、全尺寸gp)来做对比,yagi的增益也是基于半波长dp的辐射强度来做基准的,从来不会用通联过那里、得到过什么样的信号报告来做表征天线性能的一个参数。
当然,如果不追求通联距离,只是希望能过通联、而不管通联概率、通联效率等等,只考虑方便携带性,那么就另当而论。
离线VR2ZUY
只看该作者 53楼 发表于: 2006-11-06
多谢!我主要是想在便携性、性能和架设方便方面找个平衡点。
我当然不会指望用qrp并且在天线不好的条件下取得好的效果,
只是想知道这样的效果能有多差。
离线bg2ob
只看该作者 54楼 发表于: 2006-11-06
如果不考虑价格可以看看buddipole, www.buddipole.com
