  • 8952阅读
  • 74回复
库雷岛--我的DXCC HONOR ROLL胜利在望 [复制链接]
离线BD6AHP
只看该作者 40楼 发表于: 2005-09-25
k7c now on air~!
离线BY4CYL
只看该作者 41楼 发表于: 2005-09-25
应该出来了,刚才在dx summit 查到的,祝各位好运!
b0zo-@   14000.0 k7c wkg ja becuz k7c wanted eu 2 bitch   0748 25 sep
pd2sle   14251.0 so9l     only scandinavia stations   0748 25 sep
ru3at   21102.2 h2e       rtty-ww               0748 25 sep
dl5ww   21088.4 bg0aai                         0748 25 sep
n9bx     14025.0 k7c       now qrv working ja and ua0   0748 25 sep
ru3at   21099.2 ra9yah     rtty-ww               0747 25 sep
hb9dtm   14094.4 un8lf                         0747 25 sep
f8cks-@   7970.0 f5pjq/p   dfcf08016 charbogn?       0746 25 sep
ea1du-@   7075.0 ea5akl/p   eab-020 dme 02029         0746 25 sep
ea2ec   14252.0 ea8/ea9cp   ref?dle-109             0746 25 sep
ua1akj   14022.0 k7c       qsx 14026.70 oc020 only ja/ja0746 25 sep
iv3jcc   14128.0 ru4wg     galina artica 59         0746 25 sep
ru3at   21095.1 zc4li     rtty-ww               0745 25 sep
ea7nc     7078.9 ea4td/p   mm-372                 0745 25 sep
ra6ydx   28091.0 ua0agi     very strong             0745 25 sep
dk5ir   18130.0 ra9mx     cq                   0744 25 sep
ru3at   21090.5 ea1aks     rtty-ww               0744 25 sep
f5xl     7080.0 f5nmk/p   new is difi-57024l         0743 25 sep
dl0as-@   14022.0 k7c       why ja now?             0743 25 sep
离线BD6AHP
只看该作者 42楼 发表于: 2005-09-25
看看谁是第一个by.
离线VR2KW
只看该作者 43楼 发表于: 2005-09-25
最新消息。
先不要管dxa,先出来再说啊。上岛都两天多了吧!
25 sept 2005
the k7c team is behind schedule in getting on the air due to the challenges of unloading equipment because of heavy seas. the cw and ssb stations are nearly complete and the team expects to be qrv this evening. we are also experiencing difficulties with our isp and are working to resolve those issues. we regret that we will, for the time being, remove some of the higher bandwidth material (audio and images) from dxa, but hopefully will be able to replace this material soon. whether these isp issues are resolved or not, as soon as the stations are complete, they will go on the air! again, hopefully this evening. it is 0400z as of this writing. we will keep you posted as new information comes in.
dxa真的很有问题,明明听到他确认了我的callsign,但page就偏没有。
离线BA4DW
只看该作者 44楼 发表于: 2005-09-25
让人欢喜让人忧的dxa。
和你一样,早在下午5点多的时候就qso了,明明确认了,可dxa上就是不跳出来!心里就是不爽。1个多小时以后,同一个波段,同一个方式,再通一遍,这次跳出来了,看到自己ba4dw的呼号在dxa上跳出来,真是高兴啊!
偶看这个dxa会造成很多dupe qso,索性关关掉算了。
离线VR2KW
只看该作者 45楼 发表于: 2005-09-25
让人欢喜让人忧的dxa。
我叫了一个多小时才通上的,不爽。
另外20米上一点声音也没有,奇怪!!
离线BA4DW
只看该作者 46楼 发表于: 2005-09-25
我叫了一个多小时才通上的,不爽。
另外20米上一点声音也没有,奇怪!!
我叫了1个半小时才通上,从下午3点40分开始,到5点10分通到。
日本电台铺天盖地,这堵墙推都推不开!
20米在最开始的时候听得到,很清晰。后来就一点都听不到了。
估计k7c搞个8波段没有问题,争取9波段!!!
离线VR2KW
只看该作者 47楼 发表于: 2005-09-25
20米cw信号很弱,ssb一点也没有。
刚才又在30米辛苦的叫通了一次,这回清清楚楚地的听着k7c回应我的呼号了,dxa也确确实实的“没料到”,不管了。
离线BA4DW
只看该作者 48楼 发表于: 2005-09-26
20米cw信号很弱,ssb一点也没有。
呵呵,这个dxa累人啊。我和你在通第二遍30米的时候想法一样,清楚地听到自己的呼号(虽然第一次也是非常清楚地听到),如果dxa还是不跳出来我的呼号,那就不管了。问题是,这k7c每通一次,目前所需要花费的时间都是以小时计。。。。。。
看到dxa上有刚刚自己qso的记录跳出来,固然令人高兴。可如果dxa不能稳定可靠地工作,那就快成“鸡肋”了。
看看最新消息。
25 sept 2005
k7c is on the air! however, we are having difficulties with our isp over the operation of dxa. we have slimmed down dxa to focus only on the logging functions due to excessive server loads. after talking a few hours to sleep and catch their breath this morning, k7c will be back on the air around 2000-2100z. we will be adding the lost qso's to the dxa log. please rest assured that if your contact was confirmed by a k7c operator over the air, and it currently doesn't show up on dxa, it is in the log and it will appear on dxa in the near future after we have resolved these issues. thanks so much for all the wonderful emails of support we have been receiving.
我估计上岛后迟迟不开呼,昨晚又停了n个小时,可能还是为这个dxa所累。
离线VR2KW
只看该作者 49楼 发表于: 2005-09-26
网上可以即时查log这个想法很好,但要顾及的技术太多了,搞不好的话就好像现在的情况变成了负累,但他们留在岛上的时间是有限的,总不能为了迁就这个烂dxa系统而减少on air的时间。
离线BA5CW
只看该作者 50楼 发表于: 2005-09-26
坚持了三个小时,在15m cw搞定第一个波段,我都快睡着了,机械地发呼号,朦胧中听到bd4alc,哈哈,终于轮到我了,马上发5nn tu,过一会儿dxa上就有确认了。从来没有围绕一个电台等了那么长时间。接着去17m,听到ba4rf被点中。
离线BA4DW
只看该作者 51楼 发表于: 2005-09-26
情况的确是这样。
今天下班回来,花了不少时间搞定40米波段cw,可dxa又出问题了,10分钟反复跳的是
w4dxx和jr5vhu这两个呼号。不去管他了。
目前所有的波段上,现在竟然只有一个40米cw的k7c在那里,看来一定是dxa的麻烦--
可能仅仅因为dxa又出问题了!
离线BD6AHP
只看该作者 52楼 发表于: 2005-09-26
刚在dx summit上看到你了,恭喜4dw。
离线BD4SDB
只看该作者 53楼 发表于: 2005-09-26
今天搞定12m和17m
离线BA5CW
只看该作者 54楼 发表于: 2005-09-26
今天搞定12m和17m
你老实交待,17m上怎么搞定的,我跟在你和bd4sw后头上的好轻松哦。
离线BA4DW
只看该作者 55楼 发表于: 2005-09-27
祝贺各位b电台。
我还没有通过ssb呢,并且30米波段以上的高波段还是空白,看来白天的高波段
都要留到周末了?
看看k7c的照片吧。。。。。。。http://www.cordell.org/htdocs/kure/kure_pages/kure_pictures.htm
离线BG1DRJ
只看该作者 56楼 发表于: 2005-09-27
应付这么多波段要单独做天线太辛苦了,准备还是拿天调+垂直10米导线+1*10米地网的天线+十一长假来捉这个k7c了,争取各段均拿下!
刚看了相片,没看明白用的什么天线
离线得趣轩主
只看该作者 57楼 发表于: 2005-09-27
在18.145上我应该是通到的(bd4si可证明)。
可是k7c的dxa上只有我的24mhz的通联记录。
搞不懂!
离线BA4DW
只看该作者 58楼 发表于: 2005-09-27
今天早上上班前,通到17米ssb,用我的dipole一嗓子叫到--因为他刚刚出现在这个
频率上。
那些照片是第一批照片,还会有后续照片。他们的天线群肯定很壮观。
不用太在意dxa,这个dxa不稳定,过两天他们会补上的。
as k7c comes on the air again, we are seeing emails about missing calls in the dxa log. if you do not see your call in the log, and you have been given a report from the operator, your call is in the log and will appear on dxa in a few days after we have uploaded a fresh copy from the official log. if, in a few days, you do not see your call on dxa, then please email us with "busted qso?" in the subject line of your email (to k7c @ cox.net) and we will search for it. be sure to include date/time/frequency/mode in your email. without at least a few of those items we may not be able to locate your call.
离线BA4RF
只看该作者 59楼 发表于: 2005-09-29
dxa这个东西本来就是个辅助性的东西,只要自己有把握就行了。
昨天晚上lp恩准晚上联台,一个晚上通了做了6个qso,有4个能够显示,有2个没有显示,不过在网络上发spot的各个台都没有出现在dxa上,说明确实是dxa有问题。
