  • 362905阅读
  • 1316回复
DIY高准确度电压基准 [复制链接]
离线BG2VO
只看该作者 460楼 发表于: 2008-03-26
之所以比较失望,是因为堂堂知名的高联,也用老化率为20ppm每千小时的器件做基准,而且结构设计和用料都很不讲究。比如升压电阻还是非密封的,运放的偏流太大,这样就很难保证整体稳定性。
小板的背面,还有电路图。可见就是常规、经典电路。
实际测试下来,4个基准分别偏离-20ppm、-25ppm、-21ppm、-17ppm。
离线BG2VO
只看该作者 461楼 发表于: 2008-03-26
高联的另一个常见基准:4410,左边多了4个1.018v,在以下连接里卖$4995,转过来:
http://www.lehmanscientific.com/calstd2.html#anchor244544
guildline model 4410 portable dc voltage standard. this standard is designed for instrumentation laboratories which must maintain a knowledge of the absolute magnitude of the volt to within a few parts per million of the national standard. features: eight independent outputs, four at 10 volts and four at 1.018 volts, simple and reliable operation, low drift, low noise, minimal leakage and line coupling, easily transported, long battery backup, low temperature coefficient, and it is acceptable for national certification. the output terminals are of gold-plated copper to reduce thermal emfs and also have custom-molded insulators of very high resistance and low moisture absorption. silvered mica capacitors and high loss toroidal inductors are used to minimize rf interference. the precision resistors are wound of "evenohm" wire from a single spool on selected mica cards in a single layer. multiple resistors of a similar value are used to provide coherence of drift and temperature coefficient, even after temperature cycling. the annealing process and stress-relief after mounting ensure great stability with time and temperature. the reference modules are housed in a heavy cast aluminum oven enclosure controlled to 33 deg c. great care is taken in routing the teflon wiring to reduce temperature gradients. the multiple outputs are the most important feature since they provide greatly improved confidence. by a simple intercomparison of the four outputs, any perturbation in an output can be readily detected. in each of the four reference modules, eight precision reference elements are averaged to reduce drift, temperature coefficient and noise.
specifications: outputs: four at 10v, four at 1.018v, influence of battery voltage limit (between the limits of 11.6v and 14v): below noise level, noise (0.3 to 10hz bandwidth): less than 0.1ppm rms, annual drift (each of the eight outputs): first year- less than -3 +/- 2 ppm, second year- less than -2 +/- 2 ppm, temperature coefficient: less than +/- 0.04ppm/deg c, isolation, ac: less than 120na case to guard leakage current, leakage resistance (outputs to guard or case): greater than 10e10 ohms, operation on battery: at least 60 hours. we have two of these superior quality voltage standards in excellent used condition. each is in current calibration with calibration reports (voltages certified to 7 decimal places for the 10v outputs, and 8 decimal places for the 1.018v outputs), and nist-traceable certifications. each has a traceability book, which contains copies of the calibration certifications of each instrument used for for calibration. these units were shipped to us "hot" so the traceability is intact. excellent used condition, checked, guaranteed. price: $4995.00 each
离线funghome
只看该作者 462楼 发表于: 2008-03-26
今天買的電阻到了
其中有一mills電阻
0.01%
100歐母
怎樣?
离线051688
只看该作者 463楼 发表于: 2008-03-26
今天買的電阻到了
其中有一mills電阻
0.01%
100歐母
怎樣?
这个应该是塑封的,我差点买到一只,只晚一步,被别人收了。你这个多少钱个。
楼主的做法让我百思不得其解,就算是玩吧,可是你前头做的那个十个基准并联的基准电源应该已经是极品了吧,你还不断的买这些东西干吗?呵呵,我并不全是玩,一半是玩一半实用。
离线BG2VO
只看该作者 464楼 发表于: 2008-03-26
这0.01%的电阻应该不错,塑封的?还是釉封的?
不断的买就是不断的学,不断的玩。
离线funghome
只看该作者 465楼 发表于: 2008-03-26
5元..
可惜只有100歐母,只買了一顆
也不知出產年份
它的長度超過3顆rx11電阻並排
离线funghome
只看该作者 466楼 发表于: 2008-03-26
不断的买就是不断的学,不断的玩。 [表情] [表情]
是塑封的,
陶封應該更好吧!
剛剛發現國產的rx11密封好像不好
离线051688
只看该作者 467楼 发表于: 2008-03-26
是塑封的,
陶封應該更好吧!
剛剛發現國產的rx11密封好像不好
是淘宝网上买的吗,能告诉我一下店主的名字吗?如果是淘宝上买的我怀疑他是倒买倒卖,这个东西在零件仓库那儿卖过,是三元一支。我就是晚了一步,边最后一支都没买到,但有一个人买了大部分。这个电阻好象是美国产的,虽然是五元一支。但我觉得还是值的,祝贺你,这个阻值的电阻用来作基准还是很好的。
离线051688
只看该作者 468楼 发表于: 2008-03-26
今天在电子市场收了三颗天和的大电容,是22000uf,25v的,准用它做个好的可调稳压电源,然后再把手头的max6350全部测完,到时把测试的结果绘成图发上来。
现在正在测这三只电容的漏电电流。过会把稳定下来的漏电电流数值发上来,大家一起研究一下。为了省事我是把三只电容并到一起测的。
离线funghome
只看该作者 469楼 发表于: 2008-03-26
不是淘寶買的..
本人是在香港的
賣的人這個電阻好像也只有少許
离线BG2VO
只看该作者 470楼 发表于: 2008-03-27
原来你买的是这电阻,开始看照片不清楚没认出来。
我以前也买了一些,价格是3元/只:http://auction1.taobao.com/auction/trade_detail.htm?trade_id=310312205
我就是在零件仓库买的,买的大部分的应该是我吧?测试过感觉不是太好,也就是刚刚能达到0.01%,个别阻值有超过0.01%的变化。
离线051688
只看该作者 471楼 发表于: 2008-03-27
当时我看是塑封的,10w功率,又那么便宜就觉得不是太好,但因为这种电阻很难找才想买它的,当时只有一只了,虽然贴子上显示还有,但我要时正好被他朋友拿去当负载了,没买成。
当时看到楼主手里有很多特别精密的电阻,就觉得这东西楼主是看不上眼的,没想到全被你收去了。这东西外壳看起来是很漂亮。
离线051688
只看该作者 472楼 发表于: 2008-03-27
经过一夜的激活,三只电容的漏电电流稳定在了6微安以下,平均一只的漏电电流不到2微安,不过这应该不是最小值,因为漏电电流还处在不断减小之中,因为时间关系没有继续测下去。
第二张小图是放电实验。
离线funghome
只看该作者 473楼 发表于: 2008-03-27
我這面能買到最好的零售電阻可能只有派睿
vishay電阻130多元
http://www.vishay.com/docs/63001/s.pdf
http://hk.farnell.com/productimages/nio/standard/3749061.gif
  * metal foil resistor
  * series:s102c
  * resistance:50kohm
  * resistance tolerance:+/- 0.01 %
  * power rating:0.6w
  * voltage rating:300vdc
  * temperature coefficient:+/-0.6 ppm
  * resistor terminals:radial leaded
  * mounting type:through hole
离线x5y5
只看该作者 474楼 发表于: 2008-03-29
学到很多,很强大
离线张雄
只看该作者 475楼 发表于: 2008-03-31
bg2vo ,你好,我今天用凌力尔特申请来的lm399ah做了下实验,我是要给我的桥路传感器供电,结果它驱动不了,请问是不是可以用lm399数据手册上提供的那原理图对其进行放大,如果用下面的这个原理图的话,对元器件有特殊的要求吗,而且是不是一定用lt1001运放呢,谢谢哈,实在是菜鸟,不好意思哈
离线张雄
只看该作者 476楼 发表于: 2008-03-31
LM399AH 输出10V
lm399ah 输出10v典型电路
离线张雄
只看该作者 477楼 发表于: 2008-03-31
LM399AH 输出10V
请问是不是用第二个图比较合理稳定呢,如果说用其中一个,是不是对其外围器件也有特殊的要求,一定用lt1001吗,谢谢哈
离线BG2VO
只看该作者 478楼 发表于: 2008-04-01
这两个图是输出不同的电压的,不知道你需要多大电压?
第一图是简化的10v输出,实际上要有微调。
第二图是输出1.018v的而且可微调。
对外围电阻(主要是图中0.1%的)有特殊要求,因为这些电阻直接影响输出。你输出的温度系数和稳定性要求是多少,就应该采用对应的电阻。图中只能保证输出0.1%,并不高。
要求高的话对运放自然有要求,最好采用ad707/ad708或类似运放,要求低失调变化、小ib。
离线张雄
只看该作者 479楼 发表于: 2008-04-01
bg2vo ,谢谢你的回复.
我现在呢做的是一个称重系统,在传感器上的重量(称重平台:有电机传送带等)有10kg左右,然后有物品到传感器平台上,对物体进行称重(要求物体1kg则精确到1g;若物体100g,则精确到0.1g).
现在我是要给图中的传感器供电,请问用lm399可以实现这样的精度吗..是不是adc的的基准与传感器用同一个基准就效果要好一点.....非常难实现呀,你可以给我指点方向啊,谢谢了
