  • 13702阅读
  • 50回复
FT8 Roundup Contest 12月1日-2日 [复制链接]
离线hamly
只看该作者 20楼 发表于: 2018-11-23
回 BD0AAI 的帖子
BD0AAI:感谢楼主翻译,
5.2.2  美国和加拿大互通不能作为DXCC实体计分,和我们没关系。
但这句,我理解是美国和加拿大是按州或者省算系数分的, 所以作为整体国家的DXCC分就不另行计算了,貌似 .. (2018-11-23 15:32)
感谢指正,看错一个字了
DE BH6KWC OM64
只看该作者 21楼 发表于: 2018-11-23
离线BA9BF
只看该作者 22楼 发表于: 2018-11-26
大家把WSJT-X 2.0.0的版本都安装测试好了吗?
竞赛时间快接近倒计时了!
Email: ba9bf@163.com
离线VR2UPU
只看该作者 23楼 发表于: 2018-11-27
A fifth candidate release ("RC5") of WSJT-X 2.0 is now available for
download and use by beta testers.  RC5 is stable, works well, and fixes
the known problems in RC4.  It is likely that the General Availability
(GA) release of WSJT-X 2.0, scheduled for two weeks from today, will be
nearly identical to RC5.
Changes in RC5 relative to RC4 include the following:
  -  Make the "Auto Seq" checkbox sticky, again
  -  Remove the 5-minute mouse timer
  ->>>  Correct the "worked before" logic for color highlighting
  -  Add "No own call decodes" checkbox in WSPR mode
  - >>> Display and log UTC (not local time) in contest operations
  - >>> Validate contest QSO details before allowing logging
  -  Force Aqua theme on macOS to avoid issues with Mojave dark theme
  -  Move Fox log Reset action to Fox log window context menu
  -  Improve layout of Working Frequencies and Station Information tables
  -  Allow deletes and editing in Fox and Contest log windows
  -  Add Tool Tips for Fox and Contest log windows
  -  Fix a bug causing false AP decodes in JT65 VHF+ operation
  -  Fix a bug that could switch unexpectedly from JT65 to JT9 mode
You may need to invoke "Settings | General | Colors | Reset
Highlighting" on your first program start with this version.
The "Quick-Start Guide to WSJT-X 2.0" has been updated. Be sure to read
this entire guide before using RC5:
http://physics.princeton.edu/pulsar/k1jt/Quick_Start_WSJT-X_2.0.pdf
We recommend using RC5 (and therefore the v2.0 FT8 protocol) in the
conventional FT8 sub-bands at audio Tx frequencies 2000 Hz and higher.
Inevitably the necessary transition from v1.x to v2.0 protocols for FT8
and MSK144 will cause some confusion and cross-protocol interference.
Users of v1.9.1 and earlier are unable to decode transmissions from
users of RC4 and later, and vice-versa.
As more users upgrade their software to WSJT-X 2.0 -- and particularly
after the General Availability (GA) release on December 10 -- the new
protocol should start to dominate the conventional FT8 sub-bands.  As
soon as possible after December 10, everyone should upgrade to WSJT-X 2.0.
Download links for RC5 on Windows, Linux, and macOS can be found on the
WSJT-X web page http://physics.princeton.edu/pulsar/k1jt/wsjtx.html
A final FT8 "practice contest" will be held on Saturday, December 1,
0200-0300 UTC (that's Friday evening, Nov 30, NA time).  Watch for a
separate announcement with more details.
If you find any unexpected behavior with WSJT-X 2.0-rc5, please send a
detailed report to the wsjt-devel email list,
wsjt-devel@... You must subscribe to the list in
order to post there.
The first serious FT8 contest is scheduled for the weekend of December
1-2.  See https://www.rttycontesting.com/ft8-roundup/ for full details
and contest rules.  The ARRL RTTY Roundup (January 5-6, 2019) permits
and encourages FT8 as well as traditional RTTY operation.
ONCE MORE: As soon as possible after December 10, and certainly by
January 1, 2019, everyone should be using WSJT-X 2.0 or a compatible
v2.0 version of derivative programs such as JTDX or MSHV.  As of today,
PSKreporter statistics show roughly 3000 users of WSJT-X versions older
than v1.9.1, 9500 users of v1.9.1, and 3000 users of v2.0-rc#.  Please,
everyone, help us to spread the word that upgrading to v2.0 after
December 10 is very important.
-->>> There will be no looking back!
     -- 73, Joe, K1JT (for the WSJT Development Group)
QQ 群 : 308532243  FT8 数据通信俱乐部
离线BD7MYM
只看该作者 24楼 发表于: 2018-11-29
最新版2.0 RC5中文翻译版已经有VR2UPU出版。需要的加群308532243暗号:59973
BD7MYM
19902459973(有事先短信确认)
QQ:107704229
439.950
QTH:快乐之都-东莞欢迎您!
离线ba4sd
只看该作者 25楼 发表于: 2018-11-29
意思是V1.9.1的用戶,必須升級到V2.0 RC5,否則無法通信。
RC5有人用過嗎?
徐建华
13806264735
ba4sd@163.com
离线bg2kaj
只看该作者 26楼 发表于: 2018-11-29
觉得如果JTDX等不能及时跟进77Bit,最终77Bit FT8很有可能会出现很尴尬的局面。
离线hamly
只看该作者 27楼 发表于: 2018-11-29
回 ba4sd 的帖子
ba4sd:Users of v1.9.1 and earlier are unable to decode transmissions from
RC5有人用過嗎?
 (2018-11-29 17:46)
在约人测试中
DE BH6KWC OM64
离线VR2UPU
只看该作者 28楼 发表于: 2018-11-29
回 bg2kaj 的帖子
bg2kaj:觉得如果JTDX等不能及时跟进77Bit,最终77Bit FT8很有可能会出现很尴尬的局面。 (2018-11-29 18:11)
放心, 在整合中, 第3方軟件亦有77位元版本, 將來3套軟件都是77位元的FT-8
离线BI1EIH
只看该作者 29楼 发表于: 2018-11-30
2.0-rc5开了一天,已经能收到10几个台了
de BI1EIH (ex. B1/BG6ICN)
https://radiopi.club/
离线ba4sd
只看该作者 30楼 发表于: 2018-11-30
今晚用2.0-RC5 試聽了一下,就解碼了一個J臺。
用1.9.1 聽好多好多臺啊
徐建华
13806264735
ba4sd@163.com
离线BD7MYM
只看该作者 31楼 发表于: 2018-12-01
回 ba4sd 的帖子
ba4sd:今晚用2.0-RC5 試聽了一下,就解碼了一個J臺。
用1.9.1 聽好多好多臺啊 (2018-11-30 20:21)
对时很重要,不然解码不到
BD7MYM
QQ:107704229
439.950
QTH:快乐之都-东莞欢迎您!
离线bg6tti
只看该作者 32楼 发表于: 2018-12-01
喜闻乐见 77bit已经和两个测试信号通联过了
按照现在2.0-rc5的使用率来说,我觉得此次局面会很尴尬
呼号:  BG6TTI ( QRT )
离线hamly
只看该作者 33楼 发表于: 2018-12-02
参赛中,信号还可以,早上美洲,上午日本,印尼
DE BH6KWC OM64
离线BG4XWE
只看该作者 34楼 发表于: 2018-12-02
欧洲通了10几个,澳洲通了一个。美洲台信号很强。。通了10几个。。。要上班了。。。。。停
江苏盐城市
一个没地方架天线的火腿
离线BG6BB
只看该作者 35楼 发表于: 2018-12-02
哪里能下载RC5版本?之前的RC4版本好像不能用了,
呼号:BG6BB
地址:AnHui,China(中国·铜陵·244000)
设备:FT-897D、FT-450D、KG-UV920R
天线:LOOP天线、 温顿天线、U V  双段
常用软件:JT65、RTTY、SSTV、EasyPal、
数据通讯&网络电台交流群:71135658
离线bg6tti
只看该作者 36楼 发表于: 2018-12-02
今天这传播服了
早上6点起床,40米还勉勉强强通了几个欧洲。
然后现在20米全是印尼台,下午再碰碰运气吧。
呼号:  BG6TTI ( QRT )
离线hamly
只看该作者 37楼 发表于: 2018-12-02
回 BG6BB 的帖子
BG6BB:哪里能下载RC5版本?之前的RC4版本好像不能用了, (2018-12-02 11:13)
官网,WSJT
DE BH6KWC OM64
离线hamly
只看该作者 38楼 发表于: 2018-12-02
回 bg6tti 的帖子
bg6tti:今天这传播服了
然后现在20米全是印尼台,下午再碰碰运气吧。[表情]  (2018-12-02 12:59)
7-9点 14M不少美洲
DE BH6KWC OM64
离线bg6tti
只看该作者 39楼 发表于: 2018-12-02
回 hamly 的帖子
hamly:7-9点 14M不少美洲 (2018-12-02 13:09)
我天线不行,我这通美洲只能夜里走40米波段过去
呼号:  BG6TTI ( QRT )
