  • 7373阅读
  • 23回复
问个问题?短波静噪的 [复制链接]
离线BH4JQR
只看该作者 20楼 发表于: 2013-12-05
内容到底说的什么静噪?QSL?
FT-180A的静噪很有意思!
BH4JQR
山东.东营
QQ:346198156
16725117@163.com
离线无号小鸟
只看该作者 21楼 发表于: 2013-12-20
亲身CODAN 的“语音静噪”超好用,和主流业余机完全不一样。
呼号:BG5TKK
MAIL:bg5tkk@gmail.com
离线bg8tbb
只看该作者 22楼 发表于: 2013-12-21
宝丽短波电台也有“Voice Mute”功能。
没事就想打开短波听听,这是病,得治!
离线BG2BHC
只看该作者 23楼 发表于: 2013-12-27
查了一下原理
Voice squelch control function This function is useful when you don't want unmodu- lated signals. When the voice squelch control function is activated, the receiver checks received signals for voice components. If a receiver signal includes voice components, and the tone of the voice components changes within 1 sec., squelch opens. If the received signal includes no voice components or the tone of the voice components does not change within 1 sec., squelch closes. ➥ While is selected with [MENU], push [F5 to switch the VSC (Voice Squelch Control) function ON and OFF. • "VSC" appears when the function is activated. • The VSC function activates for phone modes (SSB, AM and FM). • The VSC function can also be used for scanning operation in AM or FM mode (p. 70)
http://www.manualslib.com/manual/281866/Icom-Ic-746pro.html?page=67
[ 此帖被BG2BHC在2013-12-27 21:56重新编辑 ]
有些梦想一直会在。
------“火腿”是业余无线电爱好者的意思吗?听上去很好吃。
------我的呼号后缀是BHC,意思是“不好吃”…
