  • 16105阅读
  • 72回复
除了ft-817外,还有哪些短波qrp电台? [复制链接]
只看该作者 20楼 发表于: 2002-10-02
别急,又不想抢您生意。
原作者 bd9bl
超过5w就不算qrp了.
上icom的网站看吧。用电池是就只有5w。
但估计过一点时间机器的选购件才出齐。
9bl要求厂家把817快降价吧。我也买一台如何?
要不然817会很孤独的,幸好现有ic-703作伴。
离线ba4abc
只看该作者 21楼 发表于: 2003-07-26
8cb,
你好!去成都那么多次也没能有机会在频率上听到你的声音!
不知买了什么qrp机器啊?我刚娶进817,使用感觉相当好!严重建议你也收一房进来!:d
何时有机会到成都的话要来拜访你的w.j.,嘿嘿。
等手上有合适电池的时候,而且体力又支持得了,准备携817到西藏一转,享受享受高原通联的乐趣!
哈哈!
再见羊卓雍!:)
离线雨夜听香
只看该作者 22楼 发表于: 2003-07-26
我在策划组织qrp俱乐部!请ba6bf设计了qrp的套件!很快与大家见面!
离线BA6QH/QRP
只看该作者 23楼 发表于: 2003-07-26
最初由 雨夜听香 发表
哦,策划组织qrp俱乐部是个好主意,支持!!!:d :d :d
离线bg7ipo
只看该作者 24楼 发表于: 2003-07-26
请看ICOM-703
俺目前心目中最理想的qrp机器
qrp hf transceiver
ic-703
this new model is being designed as a portable hf transceiver that utilizes the design excellence and body of the very successful ic-706 series. it will be similar to an ic-706mkiig without the vhf and uhf bands, and is a model in a new genre that has an automatic antenna tuner built-in, low consumption circuit design and large external battery for field use as a portable hf qrp unit.
this new model will appeal to ham user’s who require a convenient portable hf unit, and will be an ideal long distance communications device for sparsely populated territories where set-up of normal communication infrastructure is expensive and impractical.
<features>
relay type antenna tuner unit built-in, 1.9-30mhz coverage
(for 50ohm load antenna. does not match to a wire antenna
new low current consumption circuit design to obtain longer battery life
large capacity external battery pack and antenna suitable for field operation, will be set as options
suitable for not only ham radio operation, but is an excellent unit for long distance communications in remote mountainous or desert areas where effective communications are not readily available. also, is perfect as a communications solution for specialized applications.
quick power set function to make qrp operation efficient
dsp built-in for auto-notch and noise reduction functions
(dsp functions are equivalent to ut-106)
max 10w output. adjustable in 10/5/1/0.5/0.1w steps
(5w when using 9.6v batteries)
memory keyer function built-in
multi-use versatility for the home or shack, mobile dx’ing in your car and as a field unit in the outdoors
specifications
general
frequency range     : refer to version list
mode   : usb/lsb/cw/rtty/am/fm
temperature range     : -10°c to +60°c; +14°f to +140°f
antenna impedance   : 50 ohms(so-239)
frequency stability : less than ±0.5 ppm (0 to 50°c; +32 to +122°f)
no. of memory ch. : 105(99 split, 6 scan edges)
frequency stability : less than ±0.5 ppm (1 min. after powered on/0 to 50°c; +32 to +122°f)
power supply voltage : 9.0 to 15.87 v dc (negative ground)
current drain : tx
rx   10 w
  5 w
standby
max. audio   3.0 a
2.0 a(9.6v)
0.25 a (typ.)
0.45 a (typ.)
dimensions
(projections not included) : 167(w) × 58(h) × 200(d) mm;
6 9/16(w) × 2 9/32(h) × 4 7/8(d) in
weight (approx.) : 2.0 kg; 4 13/32 lb
transmitter
mode usb/lsb/cw/rtty/am/fm
modulation system : usb/lsb   blanced modulation
am     low level modulation
fm     variable reactance frequency modulation
spurious emission : 50 db (hf bands)
carrier suppression : more than 40 db
unwanted sideband
suppression : more than 50 db
spurious emissions : below 30 mhz: less than -50 db
above 50 mhz: less than -60 db
microphone connector : 8-pin modular jack (600 ohms)
output power :usb/lsb/cw/fm/rtty 0.1 to 10 w (at 13.8v)
  am                     0.1 to 4 w (at 13.8 v)
usb/lsb/cw/fm/rtty   0.1 to 5 w (at 9.6v)
  am                     0.1 to 2 w (at 9.6 v)
receiver
receive system : double conversion superheterodyne system
intermediate frequencies : 1st 64.455 mhz (for all modes)
2nd 455 khz (for all modes)
sensitivity (typical) :   frequency range
(mhz) ssb, cw, rtty
(at 2.4 khz bw) am
(at 6 khz bw) fm
(at 15 khz bw)
0.50 - 1.799 __ 13&micro;v*1 __
1.80 - 29.99 0.16&micro;v *1 2&micro;v *1 __
28.0 - 29.7 0.16&micro;v *1 2&micro;v *1 0.5&micro;v *1
10 db s/n for ssb, cw, rtty and am, 12 db sinad for fm
*1 pre-amp is on
squelch sensitivity
(pre-amp: on) : ssb, cw, rtty
fm   less than 5.6 &micro;v
less than 0.32 &micro;v
selectivity
(typical) : ssb/ cw (bw: 2.4 khz)
am /fn-n (bw: 6 khz)
fm (bw: 15 khz)   more than 2.4 khz/-6db
less than 4.5 khz/-60 db
more than 8.0 khz/-6db
less than 30.0 khz/-60 db
more than 12.0 khz/-6 db
spurious response : more than 70 db
af output power : more than 1.0 w with an 8 ohms load
rit variable range : ±9.99 khz
all stated specifications are subject to change without notice or obligation.
supplied accessories
not fixed yet
options
ah-2b : antenna element
ah-4 : automatic antenna tuner
at-180 : automatic antenna tuner
ct-17 : ci-v level converter
fl-52a : 455khz cw/rtty narrow filter-500 hz/-6db
fl-53a : 455khz cw narrow filter-250 hz/-6db
fl-65 : 455khz ssb filter-2.4khz/-6db
fl-222 : 455khz ssb narrow filter-1.8khz/-6db
fl-257 : 455khz ssb wide filter-3.3khz/-6db
hm-103 : hand microphone
mb-62 : mobile mounting bracket
mb-63 : mobile mounting bracket (for controller head)
mb-65 : mounting base
mb-72 : carry handle
opc-581 : 3.5m separation cable
opc-587 : 5m separation cable
opc-589 : microphone adaptor cable (modular to regular 8-pin microphone)
opc-598 : 7m acc cable
opc-599 : adaptor cable (13pin to 7- and 8-pin acc sockets)
sm-20 : stand microphone
sp-7 : external speaker
sp-10 : external speaker
ut-102 : voice synthesizer unit
ut-106 : af dsp unit
请看它的徒步携行的情况
http://www.icom.co.jp/fieldparty703/html/bag.htm
离线ba4abc
只看该作者 25楼 发表于: 2003-07-26
bg7ipo,
ic-703不是一款严格意义上的qrp机器,就像ic-706,ts-50等车载机一样,虽然可以把它们的功率调到5w甚至于5w以下,但qrp界是不会承认这样的qrp的!
离线IDK
只看该作者 26楼 发表于: 2003-07-27
703配件已经基本上出全了。
703用电池的时候是5w,我估计不承认只是时间的问题。
离线bg7ipo
只看该作者 27楼 发表于: 2003-07-27
哈哈!
最初由 bd4abc 发表
bg7ipo,
俺主要是看中它的小体积轻重量,非常小的待机电流和内置自动天调,原装的语音压缩功能(这点对qrp机器非常重要,但817竟没有)这几项对真正用于野外移动的电台来讲非常非常的重要,至于它是否是qrp机器,对于我这类以可靠通联为目的的实用派而言,并不那么的重要;) 俺还嫌的功率小啦,这么大个最好有25w—50w:d
离线ba4abc
只看该作者 28楼 发表于: 2003-07-27
最初由 idk 发表
703配件已经基本上出全了。
这个问题和是否使用电池供电没有关系!
离线火腿蛋
只看该作者 29楼 发表于: 2003-07-27
703的天条不咋样,太窄了,太相信他会出事的.
我不用自动天条,你可以试试z11,他的介绍太牛了.接上大树也能用..........
离线bd8cb/8
只看该作者 30楼 发表于: 2003-07-27
to bd4abc:
俺在vu上很少出来的,现在天线也拆了,短波一般守21400。
再来成都请短信俺,不过w.j的机子不是俺的,是两个朋友的。
上高原其实没太大的难度,5000米以下只要不做剧烈运动和负重,也不会喘不过气来,轻装上阵即可。
我过些天要上青海,借了bd8dl的817,会在常用频率出呼,希望能做qso,817 vs 817,5w vs 5w,呵呵。
关于野外qrp电台:
817一来价格好,二来对野外用途来说,是个电猪——接收2、3百ma,发射最大2a,1800mah的电池也坚持不了多久,还要再背一、两块电瓶或锂电。
俺以为,817是很不错的qrp电台,但还不是完全意义上的野外qrp电台。
俺的梦中情人,波段不必多,7、14、21中有一、两个即可,vu段不是必需的,直接用vu段的对讲机即可。但她一定要节食——13.8v供电时,接收电流不能超过50ma,发射最大5w时电流不能超过1a。
这需要厂商在电路上多下些工夫,但这是野外qrp电台的基本要求——在野外,电池决定一切。
离线ba4abc
只看该作者 31楼 发表于: 2003-07-28
完全赞成!
1、ft-817是我们迄今为止能买到(买得起)的性价比很高的小功率机器,其他厂家的qrp机器,按我们中国人的消费理念来看,是非常不实惠的,毕竟在我们这个环境下,价格因素决定一切!
2、现在锂电池相对来讲价格便宜了很多,合适价格买到的锂电池如果有个4、5千mah的话就很合适用于野外了;虽然还是不能使用很久,但是对于旅途的解闷是足够了,嘿嘿!试想一下,在帐篷搭好,简易倒v天线架起,肚子填饱,抽空喊上一、两个小时,那一块电池还是能用不少时间的,有条件的话不妨带上两块。
3、俺现在缺的是野外用的倒v天线,准备要抓紧时间赶快diy一条,7m,14m,21m能用就行了,份量要尽量轻。
4、根据我的实测,在ssb发射时,电流<1.5a;关键问题倒真是守候电流较大。
5、准备将817背上西藏和稻城,不知能否实现尚不知。
离线ba4abc
只看该作者 32楼 发表于: 2003-07-28
回复: 哈哈!
最初由 bg7ipo 发表
看到网上有n多关于ft-817的原配手唛mh-31加语音压缩的文章,好像主要是以ad公司的ssm-2165为主,如果这个ic方便买到的话,diy一个应该不是一件难事,而且都说效果明显。改天俺应该去电子市场看看,有的话就买个回来试试。如果朋友们都想装的话,还可以去让工厂做pcb,这样可靠性也高了。
如果以可靠通联为目的的话,以ham所能用的功率级别来说是太小太小了。或许你可考虑专业机种,如sgc-2020之类的机器(当然,功率还是不能满足要求的)。
离线BG6IFW
只看该作者 33楼 发表于: 2003-07-28
ic703输出功率从0.5瓦到10瓦可调,灵活满足具体需求.
体积小,重量轻; 更改进了全部电路, 接收耗电量比老款706小了将近十倍!!
机器内部自带天调, 免去外挂天线调谐器的开销, 节约数千元预算.
性能参数:
1-30mhz短波全业余段全模式工作, 内置标准天线调谐器(野外qso的利器!);
9.6v电池供电输出5w功率, 13.8v外接电源供电输出10w功率(工作电压9-15v);
最大工作电流: 3a, 最小工作电流: 250ma;
体积167x58x200mm,重量2kg,工作温度-10度到+60度;
接收灵敏度0.16uv,可选配加装dsp数字信号处理配件.
离线BG6IFW
只看该作者 34楼 发表于: 2003-07-28
上面是转贴,以前再网上看到过,icom即将推出的,带有背包,前面板可拆卸,选配有短波鞭状天线电源盒等等,就是不知道价位怎么样?如果价格4k多,还是和817有竞争力的,毕竟有短波便携天线,野外u/v段是没用的,最适合野驴使用
离线BD2QAB
只看该作者 35楼 发表于: 2003-07-28
703
离线ba4abc
只看该作者 36楼 发表于: 2003-07-28
最初由 bg6ifw 发表
universal radio上现在ic-703的卖价是670美刀,ic-703 plus的卖价是740美刀,不便宜啊!:mad:
离线BG6IFW
只看该作者 37楼 发表于: 2003-07-28
最初由 bd4abc 发表
如果加上税那还不7-8k了,还不如706
离线BA5DX
只看该作者 38楼 发表于: 2003-07-28
下宁可选817,上宁可选706mkiig
离线ba4abc
只看该作者 39楼 发表于: 2003-07-28
最初由 bg6ifw 发表
所以说呢,虽然ft-817不是完美的qrp机器,但性价比高,使得这款机器在国内外都卖得不错。
