  • 10133阅读
  • 36回复
想入手KX3了,只买主机套件+手咪+修平滤波器 [复制链接]
离线BH1IEO
只看该作者 20楼 发表于: 2013-08-11
不久等收楼主的二手KX3
燕  巴  虎  开 始 玩 户 外 了
E-mail:1162846706@qq.com
QTH :未来火星人
Echolink Links Node:15668
WiRES-X Node ID:14231
WiRES-X Room:24231
ALLSTAR Links Node:28559
Echolink brought us into the 21st century
APRS:BH1IEO Home IGATE/Yaesu 1DR-5/Kenwood D72E-6/LM3G Mobile-7/GPRS APRS Mobile car-8/Yaesu 400DR Jeep Mobile-9/Mobile phone-12
离线浙江HAM
只看该作者 21楼 发表于: 2013-08-11
回 BH1IEO 的帖子
BH1IEO:不久等收楼主的二手KX3[表情]  (2013-08-11 12:12)
好坏。
BG5GAG 13757821288
E_mail:13757821288 a 139.com
QTH:OL98NB
喜欢短波通信
离线浙江HAM
只看该作者 22楼 发表于: 2013-08-11
After you are comfortable with setting up and
using the spectrum display, you can connect the
USB/serial cable between the PC and the KX3.
 Typically, some spectral noise will appear in
the display in the form of “spikes” or
modulation sidebands. These can arise from
several sources, including nearby power
supplies, ground noise, or the computer and its
peripherals. You can often use isolation
transformers, improve grounding, and use
shielded cables to reduce the amplitude of these
signals.
 The HDSDR program can also display the
actual frequency range in use if it is set up to
communicate with the KX3. To do this, set up
the program to use KX3, K3, or Kenwood
protocol, and connect the KX3’s ACC1 jack to
a USB or RS232 port on the computer (see pg.
5). The program should then correctly display
the actual signal frequencies as you tune the
KX3. You may also be able to tune the KX3
from the program, depending on the program’s
features.
原来神机kx3 的SDR也是要接串口线的对吗?
BG5GAG 13757821288
QTH:OL98NB
喜欢短波通信
离线浙江HAM
只看该作者 23楼 发表于: 2013-08-11
常见HDA高清声卡规格一览
RealTek 瑞昱
型号 最大声道 输出分辨率/采样率/信噪比 输入分辨率/采样率/信噪比
ALC662 5.1 24bit / 96kHz /98dB  20bit / 96kHz / 90dB
ALC887 7.1 24bit / 192kHz / 97dB  24bit / 192kHz / 90dB
ALC888 7.1+2 24bit / 192kHz / 97dB  24bit / 86kHz / 90dB
ALC889 7.1+2 24bit / 192kHz / 108dB 24bit / 192kHz / 104dB
ALC892 7.1+2 24bit / 192kHz / 97dB  24bit / 192kHz / 90dB
ALC898 7.1+2 24bit / 192kHz / 110dB  24bit / 192kHz / 104dB
VIA威盛
VT1705 5.1 24bit / 192kHz / 100dB  24bit / 192kHz / 93dB
VT1708B 5.1 24bit / 192kHz / 95dB  24bit / 192kHz / 98dB
VT2020 7.1+2 24bit / 192kHz / 110dB  24bit / 192kHz / 100dB
详细出处参考:http://www.jb51.net/hardware/xianka/59102.html
BG5GAG 13757821288
QTH:OL98NB
喜欢短波通信
离线浙江HAM
只看该作者 24楼 发表于: 2013-08-11
评测报告不是挺好的机器嘛!
BG5GAG 13757821288
QTH:OL98NB
喜欢短波通信
只看该作者 25楼 发表于: 2013-08-11
离线浙江HAM
只看该作者 26楼 发表于: 2013-08-11
你别毒害我了,我现在emu0404 都在犹豫了,不知现在的笔记本声卡采样率有没有192KHZ.有就省了。
BG5GAG 13757821288
QTH:OL98NB
喜欢短波通信
只看该作者 27楼 发表于: 2013-08-11
只看该作者 28楼 发表于: 2013-08-11
只看该作者 29楼 发表于: 2013-08-11
只看该作者 30楼 发表于: 2013-08-11
离线浙江HAM
只看该作者 31楼 发表于: 2013-08-12
终于找到EMU-0202,离kx3 SDR又进了一步。
BG5GAG 13757821288
QTH:OL98NB
喜欢短波通信
离线BG7YMX
只看该作者 32楼 发表于: 2013-08-12
离线BH4rrg
只看该作者 33楼 发表于: 2013-08-12
楼主动作真快,中毒不浅啊
BH4RRG       CSKC#219
常用DX信息网站:
http://new.dxsummit.fi/
http://www.425dxn.org/
http://dx-world.net/
离线浙江HAM
只看该作者 34楼 发表于: 2013-08-12
回 BG7YMX 的帖子
BG7YMX:[表情]  等我混到级别了,上老师的1K乌龟 (2013-08-12 20:10)
主要的不是级别,而是钱。嘿嘿!
BG5GAG 13757821288
QTH:OL98NB
喜欢短波通信
离线BG7YMX
只看该作者 35楼 发表于: 2013-08-12
离线电离层
只看该作者 36楼 发表于: 2014-05-29
KX3有轻小的优势啊
BG2ALB
