  • 13413阅读
  • 37回复
我喜欢的背负式电台,最赞! [复制链接]
离线关则勇
只看该作者 20楼 发表于: 2012-01-27
两万?想都不用想,再加几个两可还差不多
离线电离层
只看该作者 21楼 发表于: 2012-01-27
这种军机为啥这么贵呀。。。。。。
离线BG7FBI
只看该作者 22楼 发表于: 2012-01-28
lz有没有兴趣收个prc148之类的玩一玩
离线BG7YMX
只看该作者 23楼 发表于: 2012-01-28
离线chinasoldier
只看该作者 24楼 发表于: 2012-01-28
[quote=电离层]这种军机为啥这么贵呀。。。。。。[/quote]
不贵了,国产军机的电池一块装备部队的价还好几千大元呢~~
离线bd7cv
只看该作者 25楼 发表于: 2012-01-28
军工比房地产还好
离线BH4WHN
只看该作者 26楼 发表于: 2012-01-28
很不错的背负机,话说国内有吗?
离线BG7FBI
只看该作者 27楼 发表于: 2012-01-29
网上有山寨的吧,淘宝上见到了,真品没有见过,就是见到恐怕也买不起吧,呵呵 [表情]
山寨148就是一坨正经的垃圾 卖100块的话 可以考虑买一个玩玩
离线liuyao73
只看该作者 28楼 发表于: 2012-03-20
我军的122,不就是短波0-10兆,超短波30-80兆。
离线BA1AK
只看该作者 29楼 发表于: 2012-03-20
我军用的南京熊猫山寨机还要10几个大万一台。
离线BG7YMX
只看该作者 30楼 发表于: 2012-03-21
离线BG4NFK
只看该作者 31楼 发表于: 2012-03-21
prc-525 combat net radio
the prc-525 represents a revolution in the digital battlefield, enabling maximum flexibility in terms of frequency bands, waveforms and functions. the radio is instrumental in building complex systems that provide data routing, switching capability and interfacing to tactical analogue and digital networks, lan and wan networks, as well as computers and other data terminal equipment connectivity. it is therefore the ideal choice for multiple roles, such as network functions and mobile stations for command and control systems.
the tactical radio can be used in portable, vehicular and stationary applications including installations in mobile shelters; the radio front panel can be detached either to be worne on the soldier’s wrist while the manpack is still transported on his back or be installed in cds-525s and cdd-525 vehicular remote consoles.
the prc-525 high-performance digital combat net radio covers hf, vhf and uhf bands with a single piece of equipment. thanks to different high-speed data modes (including 72kbps ofdm) and protocols as well as different anti-jam modes, it perfectly integrates into secure and high performance tactical communications networks.
this software-defined radio enables new features and releases to be simply downloaded, even when deployed in the field; furthermore, covering the three radio bands with the same equipment, a common logistic concept with identical human-machine interface is used over the battlefield, dramatically reducing logistic efforts and costs. the rugged hardware complies with the relevant environmental mil standards.
a full line of accessories is available, including radio docking stations with linear power amplifiers, remote consoles, hf antenna tuning units (atu) and wire antennas.
technical information
general
frequency range                  1.5 to 512 mhz
channel spacing
hf                  1 hz
vhf/uhf                  1 hz, 5, 6.25, 8.33, 12.5, 25, 50 khz
frequency stability                  ± 1 ppm
preset pages                  100 (10 available on rotary switch)
modulations                  a1a (cw), a3e (am), j3e (usb, lsb), j2d, f3e (fm), f3e wb, f1d, a3e wb
available waveforms
frequency hopping                  secom h, secom v, have quick ii (optional)
data transmission                  stanag 4285, stanag 4539, stanag 4529 (hf), ofdm 72 kbps (vhf, uhf, ff)
ale (hf)                  2g: fed-std-1045/1046/1049
                 3g: mil-std-141b, stanag 4538
operation modes
           fixed frequency (ff), secure frequency hopping (hf, vhf and uhf) and dff, gps mode (time, position), ale
built-in test (bite)                  power-up bit, manual bit, continuous monitoring
power supply                  16 to 30 vdc
                 19 to 30 vdc (full spec)
manpack
battery                  li-ion (rechargeable)
autonomy                  >20 h (5 w, fm, 18 at 25 ºc)
receiver
sensitivity                  (for 10 db sinad)
hf-ssb                  -115 dbm
vhf-fm                  -115 dbm
uhf-fm                  -112 dbm
squelch                  syllabic squelch, 150 hz tone squelch, signal squelch, rssi (relative signal strength indication)
transmitter
rf power output
hv version                  hf   1mw, 500mw, 1, 2, 5, 10, 20 w
                 vhf   1mw, 500mw, 1, 2, 5, 10 w
vu version                  1mw, 500 mw, 1, 2, 5, 10 w
environmental                  mil-std-810e
temperature                  -40 ºc to +70 ºc (operating)
                 -25 ºc to +55 ºc (fully specified)
vibration                  method 514.4
shock                  method 516.4
leakage                  method 512.3
                 1 m immersion during 2 h
emc                  mil-std-461e
                 ce102, ce106, cs101, cs103, cs104, cs105, cs114, re102, rs103, rs105
mechanical                  (manpack with battery pack)
dimensions (wxhxd)                  199 x 74 x 309 mm
weight                  5.9 k
离线BG7YMX
只看该作者 32楼 发表于: 2012-03-22
离线DG2IMD
只看该作者 33楼 发表于: 2012-03-24
民兵背的是国产的电台,不是荷兰的电台
离线bg7jn
只看该作者 34楼 发表于: 2014-10-30
   1.5 - 512 Mhz,   hf, vhf,uhf
离线bg7jn
只看该作者 35楼 发表于: 2014-10-30
     hf   20w   ;u/v    15w
离线电离层
只看该作者 36楼 发表于: 2014-11-01
太沉太大
BG2ALB
离线bg9dpy
只看该作者 37楼 发表于: 2014-11-02
bg9dpy    电话13325380568
