  • 8658阅读
  • 57回复
还有一个月就要到AATEST了。全亚洲通讯赛了。大家准备好了么? [复制链接]
离线BD7IS
只看该作者 20楼 发表于: 2010-08-22
今年继续搞14兆的低功率。去年跟qh后面。被他抛得太远了,不爽啊。
在线husy
只看该作者 21楼 发表于: 2010-08-23
鹏鹏,让个位比你过来做21兆,如何?
离线BD4HZ
只看该作者 22楼 发表于: 2010-08-23
白天没时间,晚上打酱油,哈哈哈哈
离线BD4QK
只看该作者 23楼 发表于: 2010-08-23
今年我们常州的计划还在规划中,预计会带一批新人出来练手,到时候,让他们跟在您后面吧!
离线BG1TPD
只看该作者 24楼 发表于: 2010-08-23
有没有人试试160m的。。呵呵。
在线husy
只看该作者 25楼 发表于: 2010-08-25
日本那边,160米不准用话务,只准报务使用。
离线BH4SKP
只看该作者 26楼 发表于: 2010-08-25
不知道今年昆山协会参不参赛,想去观摩学习学习~~
离线熊伟
只看该作者 27楼 发表于: 2010-08-27
先把第51届 aacontest dx contest的规则发出来吧
the 51st. all asian dx contest - 2010
supported by the ministry of internal affairs and communications, japan.
the purpose of this contest is to enhance the activity of radio amateures in asia and to establish as many contacts as possible during the contest periods.
contest period
bands
entry classification
power, type of emission and frequencies
contest call
exchange
restrictions on the contest
points and multipliers
scoring
instructions on the summary and log sheet
awards
reporting
disqualifications
announcement of results
list of asian entities
01.contest period:
(1) cw: from 00:00 utc the third saturday of june to 24:00 utc the next day <48 hours> (june 19-20,2010)
(2) phone: from 00:00 utc the first saturday of sept. to 24:00 utc the next day <48 hours> (sept. 4-5, 2010)
02. bands:
amateur bands 160m(cw only), 80m, 40m, 20m, 15m, 10m
03. entry categories:
(1) single operator single band
a: asian stations.................high power, low power
b: non-asian stations.........high power only
(2) single operator multi band
a: japanese(ja) stations........high power, low power, junior, silver
b: asian stations.......................high power, low power
c: non-asian stations...............high power only
(3) multi-operator single transmitter(all bands only)
(4) multi-operator multi transmitter(all bands only)
note1: single operator stations means that one person performs all concerned operations during contest period. use of packetcluster is permitted.
2: low power stations are limited 100w output or less. no limitation on high power stations.
3: junior stations' operator age must be 19 years old or younger, and silvers operators must be 70 years old or older.
4: 10 minutes rule(cq ww method) is applied to single transmitter stations. the 10 minutes rule means that only one transmitter and one band are permitted during any 10 minutes period, defined as starting with the first logged qso on a band. however, one-and only one other band may be used during any 10 minutes period if and only if the station worked is a new multiplier. this rule is spplied to not only running stations, but multi-stations respectively.
04. power, type of emission and frequencies:
within the limits of own station license.
05. contest call:
(1) cw ........... "cq aa"
(2) phone......... "cq aa contest"
06. exchange:
(1) for om stations: rs(t) report plus operators' age
for example (if operator is 25 years old): phone........5925, cw..........59925
(2) for yl stations: rs(t) report plus operators' age, but if the operator does not want to send her age, rs(t) report plus "00" (zero zero) can be sent.
for example (the operator is 25 years old): phone........5925(or 5900), cw..........59925(or 59900)
07. restrictions on the contest:
(1) no cross band contacts.
(2) no change of operating site.
(3) for single operator nad multi-operator single transmitter entry:
transmitting two signals or more at the same time, including cases of different bands, is not permitted. (except transmitting two signals to get new multiplier under the 10 minutes rules)
(4) for multi-operator's entry: transmitting two signals or more at the same time within the same band is not permitted.
(5) no operation from two sites or more for multi-operator's entry.
(6) no contact made through repeaters.
08. points and multipliers:
(1) for asian stations:
a: points........perfect contact will be scored as follows. contact among same entities will neither count as a point nor a multiplier. duplicate contact with the same station on same band will not count as a point.
160m band.......3 points per asian qso. 9 points per non-asian qso.
80m band.......2 points per asian qso. 6 points per non-asian qso.
10m band.......2 points per asian qso. 6 points per non-asian qso.
other bands........1 point per asian qso. 3 points per non-asian qso.
b: multipliers........the total number of different entities (according to the dxcc list) worked on each band.
(2) for non-asian stations:
a: points.......perfect contact with asian stations (excluding u.s. auxiliary military radio stations in the far east, japan) will be counted as follows:
160m band................3 points
80m band...............2 points
10m band...............2 points
other bands.................1 point
b: multipliers.......the total number of different asian prefixes(according to the wpx contest rules) worked on each band.
(3) jd1 stations.
a: jd1 stations on ogasawara (bonin and volcano) islands belong to asia.
b: jd1 stations on minami-tori shiama(marcus) islands belong to oceania.
(4) maritime mobile stations
for all maritime mobile stations at any location (no matter outside or inside asia), perfect contacts with only asian stations can be counted. the total score will be published in the contest results. but, they will not be ranked. contacts points with maritime mobile stations will be considered as same as contacts among asian stations. but, it will not count as multiplier.
09. scoring:
(the total of the contact points on each band) x (the total of the multipliers on each band)
10. instructions on the summary and log sheet:
it is recommended to use jarl a.a. contest log and summary sheet which are available from jarl hq for one irc and sae. (summary and log are available as "pdf files" from the jarl web site)
(1) each summary sheet must include your dxcc entity, callsign used, entry class, multipliers by band, points by band and total score. it should also include a signed declaration indicating that you have observed the rules and regulations of the contest.
(2) log sheet must contain band, date, time in utc, call of station worked, exchange sent, exchange received, multipliers and qso points. use a separate sheet for each band.(for single transmitter entry:in order of the time contacted). multipliers should be clearly marked by entities or asian prefixes, first time worked on each band.
(3) for japanese (ja) multi-operator's stations:log sheet must contain operator's name/hundle in each qso.
(4) e-mail submission
guidlines for the acceptable electronic file format are introduced in the "guidelines for e-mail submission of jarl contests"
11. awards:
(1) for both cw and phone, certificates will be awarded to those having the highest score in each entry in proportion to the number of participants from each entity and also those from us cq zone 3, 4, and 5 in the united states.
a: if the number of participants are under 10 there will be an award only to the highest scorer
b: from 11 to 20 ............ awards only to the runner-up
c: from 21 to 30 ............ awards to the top three
d: from 31 or more ........ awards to the top five
(2) the highest scorer among jarl members of category in each area of japan,under the condition having a ranking of half and more,will receive a certificate from jarl. however,this rule doesn't apply to those who received an above-mentioned certificate.
(3) the highest scorer on each continent of the single operator multi band entry will receive a medal from jarl and a certificate from the minister for internal affairs and communications, japan.
(4) the highest scorer of the multi-operator single transmitter and multi transmitter entry on each continent will receive a medal from jarl.
(5) all jarl members who submit a log and summary will receive a "entry certificate" from jarl through the qsl card bureau.
(6) special plaques will be awarded to the stations in the categories mentioned in a separate page.
(7) the contest award will be issued to whom fulfill the certain requirements during the contest period. the detailed information will be appeared in a separate page.
12. reporting:
(1) submit a summary sheet and logs of only one entry classification. e-mail submission will be welcomed.
(2) the log and summary should be postmarked by the following dates, addressed to:
jarl, all asian dx contest, 170-8073, japan
indicate cw or phone on the envelope.
e-mail submissions to:
a: cw...................aacw@jarl.or.jp
b: phone...............aaph@jarl.or.jp
deadlines for submissions:
a: cw...................july 31, 2010
b: phone................october 31, 2010
13. disqualifications:
(1) taking points for duplicate contact on the same band in excess of 2% of the total.
(2) false statements in the report.
(3) violations of the contest rules.
14.announcement of results:
results will be published in the spring, 2010 issue of jarl news and also will be appeared on jarl's web site (http://www.jarl.or.jp).
for those wishing to receive contest results by post, please enclose one irc with your log
离线BG1TPD
只看该作者 28楼 发表于: 2010-08-27
[quote=熊伟]先把第51届 aacontest dx contest的规则发出来吧
[/quote]
楼上已经有了。。呵呵呵
离线BD2VBB
只看该作者 29楼 发表于: 2010-08-27
这次没有时间比赛了。
离线ba4ta
只看该作者 30楼 发表于: 2010-08-28
请教个问题:单机多人怎样报年龄?报当时操作者的年龄吗?
离线冒号
只看该作者 31楼 发表于: 2010-08-28
楼上好早!
离线BD4QK
只看该作者 32楼 发表于: 2010-08-28
ta老大,这取决于参赛所用的呼号了,如果多人用集体台呼号,那么可以报00。
如果是用各自个人的呼号,就报各自的年龄了。
只要参赛呼号报的年龄至始至终不变,并与提交的成绩一致即可。
离线BA7JS
只看该作者 33楼 发表于: 2010-08-28
00还是留给yong ladies专用吧。我以前听过om玩ms,报的是99。
其实无所谓的,信号报告内容抄错了应该不影响成绩。
离线BG4KLA
只看该作者 34楼 发表于: 2010-08-28
有时间也想参与一下!
离线ROBOT
只看该作者 35楼 发表于: 2010-08-30
这个比赛必须是亚洲电台联络非亚洲电台才记分,这个有点难度的,我没有八木天线,没有1500w的功放,是否可以参加比赛。
离线BG1TXU
只看该作者 36楼 发表于: 2010-08-30
2楼好像是这样翻译的:[/
08. 得分与乘数 points and multipliers:
(1) 亚洲电台:
a: 得分:与自己国内的电台通联没有分数也不可记为乘数。与同一电台在同一频段 多次通联只能算一次分数。通联的得分如下
1.8mhz band : 与亚洲电台通联得 3 分,与非亚洲电台通联得 9 分。
3.5mhz band : 与亚洲电台通联得 2 分,与非亚洲电台通联得 6 分。
28mhz band : 与亚洲电台通联得 2 分,与非亚洲电台通联得 6 分。
other bands : 与亚洲电台通联得 1 分,与非亚洲电台通联得 3 分。
b: 乘数:以不同的 dxcc 为乘数,不同频段分别计算。
离线BA1AJ
只看该作者 37楼 发表于: 2010-08-31
JARL竞赛频段-参考
周末的aa竞赛中,日本的参赛电台遵循下述操作频段划分,请各位大虾注意:
附件: Frequency.pdf (0 K) 下载次数:130
离线child@BY1QH
只看该作者 38楼 发表于: 2010-08-31
这个是日本对aa contest的建议频率?
离线BA1AJ
只看该作者 39楼 发表于: 2010-08-31
[quote=child@by1qh]这个是日本对aa contest的建议频率?[/quote]
是对日本国内参加jarl主办比赛电台的要求。
