cay 0625 多功能工具机
cay 0625 多功能工具机
技术参数(specifications)
车削 床身上最大回转直径 max.swing diameter over bed 250mm
刀架上最大回转直径 max.workpiece diameter over carriage 130mm
最大工件长度 max.length of workpiece between centres 450mm/700mm
最大切削长度 max.cutting length 420mm/660mm
主轴锥孔锥度/通孔 taper of hole in spindle/hole no.4/¢27mm
主轴转速范围 range of spindle speed(6 steps) 6级115-1620r/mm
纵向进给量范围 range of carriage longitudnal feed per reveiution of spindle 0.5-0.1/z/r
车削螺纹范围 (公制/英制) range of screw thread(metric/inch)(20kinds) 20级0.2-3.5/8-56t.p.i
横数 range of screw thread(mod)(10kinds) 10级0.2-1.25
电机 motor 370w/550w
钻削铣削 最大钻孔直径 max.drilling diameter 16mm
最大立铣刀直径 max.diameter of vertical milling cutter 20mm
最大立铣刀盘直径 max.diameter of vertical milling face 63mm
主轴锥孔锥度 taper of hole in spindle nose no.3
主轴箱移动过程 max.distance between spindle box 160mm
主轴套筒移动过程 max.quill movement of spindle 80mm
主轴箱水平回转角度 max.horizontal rotation of spindle box around column ±180°
主轴箱左右倾斜角度 max.inclination of spindle box(left right) ±9°
主轴转速范围 range of spindle speed(4steps) 4级400-1640 r/min
电机 motor 370w
净量 25 machine net weight 135kg,150kg
25-3 machine net weight 210kg,230kg
