  • 13308阅读
  • 53回复
八木八木还是八木 [复制链接]
离线mr7
只看该作者 20楼 发表于: 2006-10-05
刚才下载了yagicalc的计算软件,觉得很有意思,可以计算swr。
离线mr7
只看该作者 21楼 发表于: 2006-10-05
swr计算截图和下载文件(含yagi、swr、巴伦............计算)
附件: Yagimr7计算.zip (0 K) 下载次数:921
离线mr7
只看该作者 22楼 发表于: 2006-10-05
yagi readme!
yagi calculator by john drew
yagi calculator is used by amateur radio enthusiasts to generate data for the
construction of long yagi antennas for vhf and uhf use.
it produces yagis that meet the design criteria developed from the work of
gunter hoch as described in vhf communications 3/82.
installation
unzip the archive into a suitable directory.
using explorer drag a short cut of yagi.exe to the desktop (rename to "vk5dj's yagi calculator"), and run the program. no installation is needed, nor does it mess up your registry.
if you don't want it anymore just delete it.
have fun.
john drew
vk5dj
version information
* version 2.0.0 first released windows version of this program.
* version 2.0.1 various adjustments to the yagi design printout screen,
hopefully less ambiguous and includes boom drilling points rather than boom length.
* version 2.0.2 includes a differentiation between the close box and the 'back' button.
* version 2.0.3 fixes a minor bug in the save and recover data.
* version 2.0.4 provides for elements that are insulated from a metal boom but pass through it. in addition the entry box of boom metal has been error protected. a blank box would have crashed the program. a method of choosing beam spacing has been added and helpful diagrams to clarify vertical and horizontal spacing.
* version 2.0.5 final adjustment to stacking and update help file. release date 20/3/03
* version 2.0.6 minor fix in "save yo file" screen (now defaults to current directory and has option to see *.yag or *.*), some more info in the help file especially about the construction and feed of dipoles. adjusted defaults to press the point that the design is for long yagis.
version 2.0.7 has introduced a capacity to calculate the resonant frequency of a measured beam. it assumes some features of the dl6wu design but would give at least a realistic indication of frequency for all yagis. it also has the capacity to convert a beam from one kind of construction to another (e.g. insulated elements style to through boom elements). yagi calculator can now read in .yag files created by yo. there is an ability to convert beams of differing construction to and from insulated construction and use yo to optimise a through boom design by utilising it in insulated form, then bring it back in and reconvert. (long winded but i hope you get the idea.)
version 2.0.8 minor changes include a dbi indication in the design yagi output. alternative gain algorithms are offered in the gain page. some mods to the help file.
version 2.0.9 add facility to calculate the length of a 4:1 balun using choice of coax or user input of velocity factor. further updates to help file. a gif picture of a 4:1 coax balun has been added to the zip file.
version 2.1.0 provides for a screen that shows the construction of a 4:1 balun
version 2.3.0 now includes swr calculations and coax losses and has been changed to full screen operation. the program was compiled in 1024*768 (my definition of choice). it will autosize to other definitions but i notice that some of the images can look a bit scruffy under lower definition. this does not affect operation in any significant way other than affecting my pride. to avoid multiple screens active at once i have adopted a different strategy to change from feature to feature. as a result it is now only possible to change to another major function from the opening screen, but the help file is available from each of them as before.
离线ba4jk
只看该作者 23楼 发表于: 2006-10-05
楼长,谢谢
离线bd3af
只看该作者 24楼 发表于: 2006-10-05
好资料,楼主辛苦了!
离线weed
只看该作者 25楼 发表于: 2006-10-05
上传的文件损坏!不能打开
离线bg4tvk
只看该作者 26楼 发表于: 2006-10-05
吊阿 这个你都能找到阿
离线bg7mh
只看该作者 27楼 发表于: 2006-10-05
软件很好用.电压.电流.功率.可换算为驻波比...........哈哈方便.
离线mr7
只看该作者 28楼 发表于: 2006-10-05
上传的文件损坏!不能打开 [表情]
你再试试这个链接下载:http://www.hellocq.net/forum/attachment.php?attachmentid=201085
离线bg2sv
只看该作者 29楼 发表于: 2006-10-05
谢谢楼主,全抄收了.
离线bg1nky
只看该作者 30楼 发表于: 2006-10-06
厉害!!!!!!!!!!!!!
离线bd7oi
只看该作者 31楼 发表于: 2006-10-06
亲手做一条成功的八木可不是一件简单的事情,看来要再努力!~
离线weed
只看该作者 32楼 发表于: 2006-10-06
ok,软件很好用。
离线mr7
只看该作者 33楼 发表于: 2006-10-06
ok,软件很好用。 [表情]
swr测试很好,具有参考价值!
离线BG4LBI
只看该作者 34楼 发表于: 2006-10-19
好资料!已收藏!
离线bg7jwf
只看该作者 35楼 发表于: 2006-11-04
好资料!已收藏
离线BG7OVI
只看该作者 36楼 发表于: 2006-11-04
路过要留名!
离线BG6QAM
只看该作者 37楼 发表于: 2007-01-04
好资料要经常看 。
离线bg4tvk
只看该作者 38楼 发表于: 2007-01-04
好东西啊   支持一下
离线BG1URY
只看该作者 39楼 发表于: 2007-01-04
抄收 vy 73
