  • 8550阅读
  • 30回复
2006 IARU HF World Championship CRSA HQ operation and award infomation announcement [复制链接]
离线BA1RB
只看该作者 20楼 发表于: 2006-07-02
官员出现的比较少,偶只通到过两次r2的
r3的9v1uv近年来是非常活跃的。
抽查了一下,去年20m ssb b7hq就有和他的qso记录。
离线BD6AHP
只看该作者 21楼 发表于: 2006-07-02
r3的9v1uv近年来是非常活跃的。
回头看了一下log,我在20m ssb也通联过r3的9v1uv,没有r2。
离线BA4DW
只看该作者 22楼 发表于: 2006-07-02
r2在美洲区,通到过两次。
离线BA7JC
只看该作者 23楼 发表于: 2006-07-03
2006 IARU HF World Championship Contest Rules
organized and administered by the arrl on behalf of the iaru
1. eligibility: all licensed amateurs worldwide.
2. object: to contact as many other amateurs, especially iaru member society hq stations, around the world as possible using the 160, 80, 40, 20, 15 and 10 meter bands.
3. date and contest period: the second full weekend of july, beginning 1200 utc saturday and ending 1200 utc sunday (july 8-9 2006). both single and multi operator stations may operate the entire 24-hour period.
4. entry categories:
4.1. single operator
4.1.1. categories
4.1.1.1. phone only -- high, low and qrp power levels
4.1.1.2. cw only -- high, low, and qrp power levels
4.1.1.3. mixed mode -- high, low and qrp power levels
4.1.2. one person performs all operating and logging functions.
4.1.3. use of spotting nets or packet is not permitted.
4.1.4. all operators must observe the amateur radio regulations of their country at all times.
4.1.5. single operator stations are allowed only one transmitted signal at any given time.
4.2. multi operator, single transmitter, mixed mode only
4.2.1. must remain on a band and mode for at least 10 minutes before changing bands or modes.
4.2.2. only one transmitted signal is allowed at any given time.
4.2.2.1. you are not allowed a second radio that works only multipliers.
4.2.3. all operators must observe the amateur radio regulations of their country at all times.
4.2.4. violation of the band change rules will reclassify the entry as a checklog.
4.3. iaru member society hq station
4.3.1. may have only one transmitted signal per band mode (160 cw, 160 phone, 80 cw, 80 phone, 40 cw, 40 phone, 20 cw, 20 phone, 15 cw, 15 phone, 10 cw, 10 phone) at the same time.
4.3.2. all stations involved in an hq operation must be in a single itu zone.
4.3.3. only one hq station callsign per member society per frequency band is permitted.
4.3.4. all operators must observe the amateur radio regulations of their country at all times.
5. contest exchange:
5.1. iaru member society hq stations send signal report and official iaru member society abbreviation. iaru international secretariat club station nu1aw counts as a hq station. members of the iaru administrative council and the three iaru regional executive committees send "ac," "r1,""r2," and "r3" as appropriate.
5.2. all others send signal report and itu zone.
5.3 a complete exchange must be logged for each valid qso.
6. valid contact:
6.1. the same station may be worked once per mode per band for qso credit.
6.1.1. mixed-mode entries may work a station once per mode per band.
6.2. a station may only be worked for credit in the portion of the band that is generally accepted for the mode used.
6.2.1. on any band, a station may be worked once on phone (in the phone segment) and once on cw (in the cw segment).
6.2.2. cross mode, cross band and repeater contacts are not valid qsos.
6.3. where contest-preferred segments are incorporated into regional band plans, participants must observe them.
6.4. the use of non-amateur radio means of communications (e.g. telephone or the internet) for the purpose of soliciting a contact (or contacts) during the contest period is inconsistent with the spirit and intent of these rules.
6.5. use of self-spotting techniques on packet or other mediums are inconsistent with the spirit and intent of these rules.
7. qso points:
7.1. contacts within your own itu zone, as well as qsos with any iaru-member society hq station or iaru official (counting as the special multiplier), count one point each.
7.1.1. contacts with a station in the same itu zone but on a different continent count one point.
7.2. contacts within your continent (but different itu zone) count three points.
7.3. contacts with a different continent and iaru zone count five points.
8. multipliers: the total number of itu zones plus iaru member society hq stations worked on each band (not mode). iaru officials represent a maximum of four multipliers per band (ac, r1, r2 and r3).
8.1. iaru member society hq stations and officials do not count for zone multipliers.
8.2. to qualify as the special multiplier, administrative council and regional executive committee stations must only be operated by the individual station licensee as single operator entry.
9. scoring: the total number of qso points times the total number of multipliers worked.
10. reporting:
10.1. entries must be postmarked or emailed no later than 30 days after the end of the contest (august 9, 2006). no late entries can be accepted. entries that are received after mid-october, 2006, even if mailed in time, may not be received in time to be included in the official results.
10.2. electronic entries must conform to the cabrillo file format.
10.2.1. the cabrillo file format and specifications may be found at http://www.kkn.net/~trey/cabrillo/ or in the november 1999 issue of qst magazine.
10.2.2. any entry which has been generated using a computer (either during the contest or after the contest) must be submitted either as an attachment to an email or on a 3.5" diskette.
10.2.3. electronic files must use the entrant's callsign as the file name.
10.2.4. the log file must be a chronological list of qsos as made not separated by band or mode.
10.2.5. entries sent as attachments to email must be sent to iaruhf@iaru.org
10.2.5.1. email entries must include the callsign used during the contest on the subject line of the email.
10.2.6. entries sent on diskette should be mailed to: iaru hf championship, iaru international secretariat, box 310905, newington, ct 06111-0905 usa.
10.2.6.1. diskettes must be clearly labeled with the station call sign, contest name, entry class and date.
10.3. participants may submit their entry using the web applet found at www.b4h.net/cabforms
10.4. paper logs must be in chronological order, not separated by bands, and clearly indicate for each contact: band, mode, date, time (in utc) callsigns, complete exchanges sent and received, multipliers and qso points.
10.4.1. multipliers should be marked in the paper log only the first time they are worked on each band.
10.4.2. paper logs with more than 500 qso's must include dupe sheets (an alpha-numeric list of all callsigns worked, broken down by band and mode.)
10.4.3. all contacts in paper logs must be in chronological order, not separated by bands.
10.4.4. paper logs must be mailed to iaru international secretariat, box 310905, newington, ct 06111-0905 usa and postmarked no later than august 9, 2006.
10.5. all paper entries must include an official summary sheet or reasonable facsimile thereof with complete contest information.
11. awards:
11.1. a certificate will be awarded to the high scoring entry in each category in each itu zone, each dxcc country and each arrl section.
11.2. a certificate will be awarded to the high scoring iaru member society hq station.
11.3. achievement level awards will be issued to those making at least 250 qsos or having a multiplier total of 75 or more.
11.4 additional awards may be made at the discretion of each country's iaru member society.
12. conditions of entry: each entrant agrees to be bound by the provisions of this announcement, by the regulations of his/her licensing authority, and by the decisions of the arrl awards committee, acting for the iaru international secretariat.
13. disqualification: any entry may be disqualified if the overall score is reduced by more than 2%.
for paper log entries: (1) score reductions do not include correction of arithmetic errors; (2) any entry may be disqualified if more than 2% of duplicate qsos are left in the log and claimed for credit; and (3) a three-qso reduction will be assessed for each duplicate qso found during log checking or for miscopied callsigns.
for electronic logs, a one-qso penalty will be assessed for a miscopied callsign.
14. for contest information, contact contest@iaru.org or iaru hf contest information, po box 310905, newington, ct 06111-0905 usa.
14.1. contest forms may be downloaded at: http://www.iaru.org/contest.html
离线BD6AHP
只看该作者 24楼 发表于: 2006-07-05
为方便各台区分总部电台和普通电台,特提供一个包含部分总部电台呼号的模板,供使用wl的同志们参考.
记住报成绩的时候要把这些模板电台删掉哦.
老大,这个文件怎么用啊,我尝试了能想到的所有扩展名也没能让我的writelog认识。开赛在即,急~!!!
离线BA7JC
只看该作者 25楼 发表于: 2006-07-05
扩展名是rar
离线BD6AHP
只看该作者 26楼 发表于: 2006-07-05
我晕,原来是zip压缩包里还有个rar压缩包啊!
已经顺利搞定,谢谢bg7jlr老兄~!
离线BA1RB
只看该作者 27楼 发表于: 2006-07-06
恩,鉴于澳门协会arm总部电台今年用xx9a出来,请各位自行把文件里面的xx9arm改成xx9a。
切记:这个只是以前的参考,一切都以竞赛时实际听到的为准。
离线BA7JC
只看该作者 28楼 发表于: 2006-07-06
还有这些补充吗?
op0hq uba hq station
3da5hq   swaziland (rss)
4l0narg   georgia (narg)
5z4rs   kenya (arsk)
jt3t     mongolia (mrsf)
          lu4aa   argentina (rca)
          ly0hq   lithuania (lrmd)
9k9hq   kuwait (kars)
        lz7hq   bulgaria (bfra)
9m4shq   malaysia (marts)
        nu1aw/3   iaru hq
          oe50a   austria (ovsv)
          oo175b   belgium (uba)
          oz1hq   denmark (edr)
          pa6hq   the netherlands (veron)
          s580hq   slovenia (zrs)
          sn0hq   poland (pzk)
cx1aa   uruguay (rcu)
      ti0hq   costa rica (rccr)
da0hq   germany (darc)
    tm0hq   france (ref)
ei0hq   ireland (irts)
  ye0hq   indonesia (orari)
gb5hq   u.k. (rsgb)
  yr0hq   romania (frr)
hg0hq   hungary (mrasz)
  w1aw/5   usa (arrl)
hs0ac   thailand (rast)
t70hq   arrsm
yr0hq   frr
5c8a
离线BA1RB
只看该作者 29楼 发表于: 2006-07-06
还有这些补充吗?
这有什么好问的,赶紧补充进去传上来呀!
离线BA7JC
只看该作者 30楼 发表于: 2006-07-06
2005 iaru
b1hq       iaru hq               dx     117135
b2hq       iaru hq               dx     6
b3hq       multi-multi 10m high cw     dx     5278
b4hq       single-op all high mixed   dx     7202
b7hq       iaru hq               dx     156840
bd7ihn     single-op all low mixed     dx     2964
bg1drj     single-op all low mixed     dx     4170
bg1fbv     single-op all low mixed     dx     6762
bg1nal     single-op all low ssb     dx     3927
bg4wyv     single-op all high mixed   dx     1125
bg6ahp     single-op all low ssb     dx     43815
bg7kfy     single-op all low ssb     dx     5
bg7klo     single-op all low mixed     dx     17408
bu2ai       single-op all low mixed     dx     1680
bv0hq       multi-multi             dx     657450
vr2bg       single-op all high cw     dx     687632
vr2hk       multi-multi all high mixed   dx     2096572
vr2xll     single-op all low ssb     dx     2180
vr2xln     single-op all low mixed     dx     105830
vr2xmt     single-op all high ssb     dx     282150
各bxhq今年的成绩要比去年好,更多的by台来参加比赛,大家加油!
