  • 8909阅读
  • 41回复
赠送液晶屏 [复制链接]
离线段国锋
只看该作者 20楼 发表于: 2006-04-08
芯片是epson e-1330 sed1600f sed1190f.是电信局设备上下来的.
离线xiongjunfeng
只看该作者 21楼 发表于: 2006-04-08
[quote=段国锋]芯片是epson e-1330 sed1600f sed1190f.是电信局设备上下来的.[/quote]
这应该是一个点阵屏,如果容易接口的话,应该有利用的价值
离线BG6SWQ
只看该作者 22楼 发表于: 2006-04-08
关于这两块ic的资料,我上传上来了
离线xiongjunfeng
只看该作者 23楼 发表于: 2006-06-24
还在吗?留着啊,准备研究研究
离线bg4iww
只看该作者 24楼 发表于: 2006-06-25
是128×64的吗?如果是,我想要。我做示波器需要一块。
离线黑衣
只看该作者 25楼 发表于: 2006-06-25
1190与1160配合驱动lcd。23楼bg6swq给的资料有相关的电路图。以下是摘要:
the sed1190 is a dot matrix lcd common (row) driver for driving high-capacity lcd panel at duty cycles
higher than 1/64. the lsi uses two serially connected, 32-bit shift registers to hold the display data, and level
shifter converts the ttl level 64-bit parallel data from the shift registers to levels suitable for use by the lcd
drive circuitry. the sed1190 generates common drive signals using the voltages supplied to lcd drive
voltages pins.
the sed1190 is used in conjunction with the sed1180 (64-bit row driver) to drive a large capacity dot matrix
lcd panel.
the sed1600 is a dot matrix lcd segment (column) driver for driving a high-capacity lcd panel at duty
cycles higher than 1/100 (up to 1/300). the lsi has a wide range of lcd driving voltages. due to the
architecture of the sed1600, the lcd driving voltage, v0, is isolated from the vdd supply. this provides the
ability to adjust the offset bias independently of vdd. these unique features allow the sed1600 to interface
with a variety of lcd panels. the sed1600 does not require a controller to output an enable signal to
implement daisy chain technology. this provides for easy interfacing with the lcd controllers such as the
sed1330, sed1351, sed1335, or the sed1341.
the sed1600 is used in conjunction with the sed1610 (86-row driver), sed1630 (68-bit row driver),
sed1631 (100-row driver), sed1632 (86-bit row driver), sed1633 (100-bit row driver), and sed1634 (100-
bit driver) to drive a large-capacity dot matrix lcd panel.
离线黑衣
只看该作者 26楼 发表于: 2006-06-25
如果是一片1190,四片1600,lcd应是64*320的。
1190是64位的,1600是80位的。图上只能大概看出是五块。
请详细说一下块的数量,弄清楚了,送给有用之人。
离线黑衣
只看该作者 27楼 发表于: 2006-06-25
查到一个lcd:
也是sed出的:lmg-ss24g64dry, 图形lcd,240*64的,无背光
配三个1600,一个1190,再有一个控制片,成一完整电路。
图中应当是一完整带驱动的lcd,写好程序接上就能用了。
离线lxy
只看该作者 28楼 发表于: 2006-06-25
我现在搞明白了,epson p-300013900 和国产tm24064f(天马)是可以通用的.
昨天从两台一样的传呼台设备上拆下两个一样的显屏,连集成电路都基本一样,其中一个是
epson p-300013900,另一个是tm24064f
离线BG7IGJ
只看该作者 29楼 发表于: 2006-06-25
我不虽要,但要点亮他的话,我可以试试,呵呵
离线proc
只看该作者 30楼 发表于: 2006-07-29
这个比较老了,质量不错!现在的集成度高了,质量却不行了.
离线soom
只看该作者 31楼 发表于: 2006-07-29
留给更需要的人。支持lz!
离线龙江月
只看该作者 32楼 发表于: 2006-07-31
嘿!又碰到老乡了哈哈!俺是白城的现在黑龙江qq177172204希望认识楼主!
离线bd7qw
只看该作者 33楼 发表于: 2006-08-03
我也有一块,东西研究了好久,就是不能正常显示,....累倒
离线wt819
只看该作者 34楼 发表于: 2006-12-12
支持楼主
接口片e-1330ba=sed1330ba
离线bg2sn
只看该作者 35楼 发表于: 2006-12-17
我也有一液晶屏
不知能做啥用,需要的拿去玩吧
离线radiolee
只看该作者 36楼 发表于: 2006-12-17
又是一点阵屏…… 只有1块就没什么意思了,多的话可以把cdg2000改成用这种屏的
离线awakening
只看该作者 37楼 发表于: 2006-12-17
小弟无知~cdg2000到底是个什么样的机器?哪里能找到详细的资料?
离线BD4ID
只看该作者 38楼 发表于: 2008-01-05
ed2402s-ar/tm24064f
我也有一块eg2402s-ar ,想学习一下,但是不知道那个二十针的接口是如何定义的
离线灵玉
只看该作者 39楼 发表于: 2008-02-26
留给更需要的人
