Dear Fellow Radio Amateurs,
The Russian Digital Radio Club has the honour to invite the radio amateurs all over the world to participate in the 1st Russian WW Digital Contest 2014. The objective of the contest is to establish as many contacts as possible between radio amateurs around the world and radio amateurs in Russia.
We invite all fans of digital modes to take part in contest from 12.00 UTC on Saturday 4th October till 11:59 UTC on Sunday 5th October, 2014. Types of modulation: RTTY45, BPSK63. The repeated contacts are permitted on different bands and different modes providing that a contact will be made not earlier than in 3 minutes. The output power should not exceed 10 watts on 160 meters and 100 watts on other bands. The outpout QRP power should not exceed 5 watts. The operator may change the bands no more than 10 times within calendar hour (with zero on 59-th minute of each hour). Only one transmitted signal is permitted at any time. Bands: 160 m, 80 m, 40 m, 20 m, 15 m, 10 m.
For more info please visit Russian WW Digital Contest 2014 Rules:
http://www.rdrclub.ru/news-radio/russian-ww-digital-contest/51-rus-ww-digi-rules You should send your log upload via the Web interface
http://ua9qcq.com/en/submit_log.php?lang=en All logs must be sent no later than 5 days after the contest (23:59 UTC on 10th October 2014).
73! de Russian Digital Radio Club
我们邀请所有数字模式的粉丝参加比赛从UTC星期六10月4日的12.00到12 UTC周日10月5日,2014年。类型的调制:RTTY45 BPSK63。反复接触允许在不同的乐队和不同模式提供一个联系人将不早于3分钟。输出功率不应超过10瓦在其他乐队在160米和100瓦。的生产QRP功率不应超过5瓦。操作员可能改变乐队不超过10倍日历小时内(零59-th分钟每小时)。只有一个传输信号是允许在任何时间。乐队:160米、160米、40米,二十米,15米、10米。
更多信息请访问俄罗斯WW数字2014年比赛规则:
http://www.rdrclub.ru/news-radio/russian-ww-digital-contest/51-rus-ww-digi-rules 你应该把你的日志上传通过Web界面
http://ua9qcq.com/en/submit_log.php?lang=en所有日志必须不晚于5天后发送比赛(2014年10月10日23:59 UTC)。
73年!俄罗斯数字无线电俱乐部
