  • 116022阅读
  • 720回复
PANDA1 pro 手持式2波段SSB CW套件 [复制链接]
离线BD6RA
只看该作者 200楼 发表于: 2011-05-26
6ra,不如稍为改一下,做成这个样子行吗?
'估计现在的民间技术难达到这个目标
离线bg4kzi
只看该作者 201楼 发表于: 2011-05-26
板子上有两个q7和两个d3,应该都装吧,这样就个少一个。
离线BD6RA
只看该作者 202楼 发表于: 2011-05-26
是的,才发现。两个q7都是9014。这样就少一个。u1边的d3:7v5。c23边的d3:4148
离线BG6JJI
只看该作者 203楼 发表于: 2011-05-26
看到楼上6ra老师发的这个台子,我搜了一下,是个u段台,不过外观可以借鉴,我把图片及相关资料发来看看。
something about an/prc-148
the an/prc-148 multiband inter/intra team radio (mbitr) is the most widely fielded handheld multiband, tactical software-defined radio, in use with the us military and nato forces around the world. the radio is built by thales communications, a subsidiary of the thales group.
the designation an/prc translates to army/navy portable radio used for two way communications, according to joint electronics type designation system guidelines. (source from wikipedia)
toy solider (hong kong) present replica an/prc-148 radio basic set include:
- replica an/prc-148 radio
- replica board band antenna
- replica h-250/u handset
- replica modular antenna cable
features:
excellent ctcss interference clearance code setting
"scan" automatic channels-scan key
lcd screen
end conversation switch
conversation monitor function
multi-channels available with display
battery capacity display
multiple "call" sound selection
voice control launch switch with progression choice (vox) levels
"ptt" key transmission for three-minute-limit automatic safeguard
sound control on/off switch
key-lock on/off switch
"call" transmission function
unit operates with 22 channels under the following frequency:
1. ch1 462.5625
2. ch2 462.5875
3. ch3 462.6125
4. ch4 462.6375
5. ch5 462.6625
6. ch6 462.6875
7. ch7 462.7125
8. ch8 467.5625
9. ch9 467.5876
10. ch10 467.6125
11. ch11 467.6375
12. ch12 467.6625
13. ch13 467.6875
14. ch14 467.7125
15. ch15 462.5500
16. ch16 462.5750
17. ch17 462.6000
18. ch18 462.6250
19. ch19 462.6500
20. ch20 462.6750
21. ch21 462.7000
22. ch22 462.7250
离线BG6JJI
只看该作者 204楼 发表于: 2011-05-26
期待成品机,想当初,买个q7套件,回去没信心,怕自己装不了,然后找朋友装,结果,现在尸体都没见着......
离线BG7IBQ
只看该作者 205楼 发表于: 2011-05-26
features:
lcd screen
1. ch1 462.5625
2. ch2 462.5875
3. ch3 462.6125
4. ch4 462.6375
5. ch5 462.6625
6. ch6 462.6875
7. ch7 462.7125
8. ch8 467.5625
9. ch9 467.5876
10. ch10 467.6125
11. ch11 467.6375
12. ch12 467.6625
13. ch13 467.6875
14. ch14 467.7125
15. ch15 462.5500
16. ch16 462.5750
17. ch17 462.6000
18. ch18 462.6250
19. ch19 462.6500
20. ch20 462.6750
21. ch21 462.7000
22. ch22 462.7250
你查到的是山寨版的,再搜一下原版的,才知道多牛b
离线bg3tk
只看该作者 206楼 发表于: 2011-05-26
严重支持出成品
离线bg4kzi
只看该作者 207楼 发表于: 2011-05-26
拆掉的是l2后面的c54是103.发射极对地是不是c49和c53,好像是33p -- 抱歉,清单写错位了!c52:103,c53:101,c54:33。感谢及时发现清单的这个错误。
换了位置好多了,信号强了不少,但还调不到16.0,调到16.45左右时,扑的一声,频率没了。目前在7045--7095
另外u1的4脚电压调不到1.19v一直在2.2v以上。
离线BD6RA
只看该作者 208楼 发表于: 2011-05-26
'但还调不到16.0,调到16.45左右时,扑的一声,频率没了。 -- 不知u5及其周边元件是否装好?如果没有装,可能会有此现象。
另外u1的4脚电压调不到1.19v一直在2.2v以上。-- bfo频率偏离太多时会有此现象。不过也不影响使用。bfo按照说明书校准后,会再1.3 - 0.7之间可调。
离线bg4kzi
只看该作者 209楼 发表于: 2011-05-26
都装好了,不急,等对照电路图再慢慢研究。
离线BD6RA
只看该作者 210楼 发表于: 2011-05-26
'应该下限到15.990都没有问题,不过这样稳定度就会下降的。建议下限到16.010,这样vxo预热时间会短很多,更加有利于提高稳定性。期末来临,这几天都在折腾出卷子。图纸尽快赶出,看看明天行不行。
离线bg4kzi
只看该作者 211楼 发表于: 2011-05-26
已经能用了。
另外提醒大家,电源插口是外正内负的,虽然外壳上印了,但还要注意一下。
离线bg3tk
只看该作者 212楼 发表于: 2011-05-26
1楼似乎忘记介绍外形尺寸了。
离线hpszsyp
只看该作者 213楼 发表于: 2011-05-26
全分立原件,本底噪音应该很小的,好东西。
离线BD6RA
只看该作者 214楼 发表于: 2011-05-26
'问题解决了?如还没有解决,再坚持一下,今晚图纸估计赶出来了。这个话筒带喇叭,只要接p1 pro航空插座的data out就可以发声了。
离线BD6RA
只看该作者 215楼 发表于: 2011-05-26
1楼似乎忘记介绍外形尺寸了。
是的,忙糊涂了,已添加。
外形尺寸:200×76×45
重量:   650克(不含电池)
带电池重量:920克
离线bh4qyg
只看该作者 216楼 发表于: 2011-05-26
发啦没有呀?能射出去吗
离线KND
只看该作者 217楼 发表于: 2011-05-26
怎么能搞成外正内负?没有电源可以用了。带二极管保护吗?
离线bg4kzi
只看该作者 218楼 发表于: 2011-05-26
还有不少问题,2个波段都能收到信号源的信号但usb和cw声音比lsb小很多。。。。。。
明天开会,今晚要整理资料,过两天再研究。
离线bg4kzi
只看该作者 219楼 发表于: 2011-05-26
没有保护,专门焊接了个正负转换插头。
