plate dissipation (max.) 4,000 watts
screen dissipation (max.) ---
grid dissipation (max.) 150 watts
frequency for max. rating (cw) 75 mhz
amplification factor 20
filament/cathode thoriated tungsten
voltage 7.5 volts
current 51.5 amps
capacitance grounded cathode
input 35.0 pf
output 0.9 pf
feedthrough 20 pf
capacitance ---
input --- pf
output --- pf
feedthrough --- pf
cooling forced air
base flexible leads
air socket ---
air chimney ---
boiler ---
length 18.44 in; 468.40 mm
diameter 4.16 in; 105.70 mm
weight 7.5 lb ; 3.4 kg
