  • 7272阅读
  • 29回复
请问如何选择PIN二极管 [复制链接]
离线songxiang
只看该作者 20楼 发表于: 2009-11-28
团购团购
离线bl7ia
只看该作者 21楼 发表于: 2009-11-28
http://www.alliedelec.com/search/productdetail.aspx?sku=7871225
usd 3.22 each
装了可能收到叫不到,,,
离线songxiang
只看该作者 22楼 发表于: 2010-08-17
http://item.taobao.com/item.htm?id=5587919903
这个请问是正货吗?比1ss53高档还是低档?
离线weed
只看该作者 23楼 发表于: 2010-08-17
這個價格不可能吧?真的這麽便宜嗎?假貨?
离线hocool
只看该作者 24楼 发表于: 2010-08-18
1sv308如何啊?
离线BG1HAS
只看该作者 25楼 发表于: 2010-08-18
wp323不知是否合适使用?
离线老火腿
只看该作者 26楼 发表于: 2010-09-27
我的ft-1000mp v   输入用的是1sv271,输出用1ss356用的是   不知道与输入用 1sss86 输出用1sv157比怎么样?
离线bl7ia
只看该作者 27楼 发表于: 2010-09-27
你的是 mk-v , 应不用更换了
我的 ft-1000mp 是按 mods.dk 上的更换
here is a copy of the orig yaesu ft1000mp service bulletin about the "imd" fix which they put out after i told them about how to fix the noise problem on the original ft1000d. imd is part of the problem, but the main part of the fix is to reduce the reverse flowing electrons in the switching diode by using a pin diode with an intrinsic layer between the "p" and "n" layers.
this reduces the reverse electron flow by a factor of > 1000. the reverse flowing electrons in the original standard switching diodes are amplified (by approx 120 db) by the rf and if and audio stages and manifest themselves as noise in the receiver!! so putting the pins in place of the standard switching diodes really does 2 things... reduces noise as explained above and reduces intermod on strong signals.
you will note that the signals sound cleaner after you do the pin diode mod. yaesu already used pins(1sv196)(surface mount devices) on the leading edge of the front end bandpass filters, so there is not much to be gained by replacing them with the better hp5082-3081 diodes.
i also replace the switching diodes around the various rf amps and the ipo switch to eliminate that source of noise. so.. the diodes to replace on the rf/if board are:
bandpass switching diodes (14):
d1004
d1009
d1010
d1015
d1019
d1026
d1030
d1036
d1040
d1044
d1047
d1049
d1054
d1057
rf amp / ipo switch diodes (8);
d1001, d1002   ipo switch
d1006, d1014   low band preamp
d1032, d1037   mid band preamp
d1041, d1043   high band preamp
i think you will note a big reduction in internally generated noise and the signals will also sound cleaner after you do the mod.
离线BD8GK
只看该作者 28楼 发表于: 2010-09-27
好文章,学习了
离线老火腿
只看该作者 29楼 发表于: 2010-09-28
感谢: bl7ia的热情帮助!
