  • 2914阅读
  • 6回复
请教电子管8122如何测试好坏(附资料) [复制链接]
离线BD7JAC
只看楼主 倒序阅读 0楼 发表于: 2010-12-05
不带电的情况下用万用表或者lc表能否测试?
离线浦东星
只看该作者 1楼 发表于: 2010-12-05
不带电的情况下,不能测试.
离线浦东星
只看该作者 2楼 发表于: 2010-12-05
reactivaton
to avoid flashover in a new or a long time unused tube, it is prudent to prepare ("reactivate") it for his task. there are various opinions and solutions how to do it, but with a gu-43 it can be relatively simple. a dc of 10 to 15 v is sufficient for the tube to draw 900 ma as the grids are connected to the anode. heat the tube 30 minutes with a filament voltage of 12.6 v. then supply a "high voltage" of about 15 v and set the voltage to a current of 900 ma. if possible use a current limiter, because during reactivate the current can increase suddenly so that continue monitoring could be necessary to maintain 900 ma. usually i will not reactivate longer than an hour or so. soon you will find out at which voltage a good tube drawn 900 ma (or 800 ma/12-12.5 v) so you have an indication if another tube is better or not.
http://www.hellocq.net/forum/showthread.php?p=3498754&posted=1#post3498754
离线BD7JAC
只看该作者 3楼 发表于: 2010-12-05
谢谢朱老师,英文看不明白,好像是说要激活管子?朱老师有没有这个管子相关的功放资料?
离线bd7cv
只看该作者 4楼 发表于: 2010-12-05
我也有一只8211和座
离线浦东星
只看该作者 5楼 发表于: 2010-12-05
http://ncl-2000.n9efj.net/ncl2knewman.html
离线BD7JAC
只看该作者 6楼 发表于: 2010-12-05
谢谢朱老师,我消化消化,不明白再想你请教。
