  • 3785阅读
  • 6回复
这个PCB文件用什么软件打开 [复制链接]
离线bg2qcg
只看楼主 倒序阅读 0楼 发表于: 2011-01-31
将文件扩展名改为 .brd
离线zgj
只看该作者 1楼 发表于: 2011-01-31
试了一下,allegro不行
离线bg2qcg
只看该作者 2楼 发表于: 2011-01-31
下载破解版 cadence_spb_16.3,没打开,
离线nbcdmagsm
只看该作者 3楼 发表于: 2011-01-31
eagle board
离线bd2bo
只看该作者 4楼 发表于: 2011-01-31
用wps打开,但是你看不懂。呵呵。
离线BH7OJ
只看该作者 5楼 发表于: 2011-01-31
grid 2.54 mm c025-024x044 <b>capacitor</b><p>
grid 2.5 mm, outline 2.4 x 4.4 mm <b>electrolytic capacitor</b><p>
grid 2 mm, diameter 4 mm <b>resistor</b><p>
type 0204, grid 7.5 mm 0207/2v <b>resistor</b><p>
type 0207, grid 2.5 mm ctrimtz03 <b>trimm capacitor</b> murata rtrimt93ya <b>trimm resistor</b> vishay<p>
cermet, abgedichtet nach ip67 c1702-05 <b>diode</b><p>
diameter 3.5 mm, vertical, grid 5.08 mm <b>diode</b> <b>diode</b> inductorsb toroidsingle toroidcirc 3,0-pad <b>mounting pad</b> 3.0 mm, round <b>dual in line package</b> ic-package <b>dual in line package</b> <b>crystal</b> transistor to92-ebc <b>to-92</b> pads in line e b c from top<p> con-amp-quick <b>amp quick connector</b> <b>to-92</b> <b>dual in line package</b> transistor-pnp to92-cbe <b>to-92</b><p>
grid 5.08 mm transistor-neu-to92 to92-ebc <b>to-92</b> pads in line e b c from top<p> <b>solder pad</b><p>
drill 1.0 mm <b>heatsink</b><p>
distributor schuricht monoband n6kr by 5z4ft 2009 monoband n6kr by 5z4ft 2009 monoband n6kr by 5z4ft 2009 mono band sierra n6kr by 5z4ft/ki4lth 2009 mono band sierra n6kr by 5z4ft/ki4lth 2009 10k(10 turn pot) 龆j  custompcb * <language en><u><b>custom pcb design rules</b></u>
<br>
<b>eagle design rules</b><p>
the default design rules have been set to cover
a wide range of applications. your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</language en> (1*16) xv4? ? ? ? ?
用eagle 这个软件开。
离线bg2qcg
只看该作者 6楼 发表于: 2011-02-01
正在下载中
