  • 3510阅读
  • 1回复
软件无线电的SMA拉杆天线 [复制链接]
只看楼主 正序阅读 0楼 发表于: 2014-04-24
ANT500 from Great Scott Gadgets is a telescopic antenna designed for operation from 75 MHz to 1 GHz.
Its total length is configurable from 20 cm to 88 cm. ANT500 is constructed of stainless steel and features
an SMA male connector, rotating shaft, and adjustable elbow.
ANT500 is a 50 ohm antenna designed to match HackRF One. It is the perfect first antenna for
general purpose use with HackRF One.
只看该作者 1楼 发表于: 2014-04-24
Michael Ossmann <mike@ossmann.com>
来信说开卖 供大家参考选择
HackRF One is now available for pre-order!  If you missed out on backing
HackRF on Kickstarter, now is your chance to ensure that you will
receive a HackRF One from the first manufacturing run.
If you backed HackRF on Kickstarter, be sure to read this important
information:
https://www.kickstarter.com/projects/mossmann/hackrf-an-open-source-sdr-platform/posts/818898
Pre-orders are available today from HakShop, NooElec, Hacker Warehouse,
Ada's Technical Books, Wall of Sheep, and Store4Geeks.  For a current
list of links, please visit:
http://greatscottgadgets.com/hackrf/
_______________________________________________
GSG-announce mailing list
GSG-announce@greatscottgadgets.com
http://four.pairlist.net/mailman/listinfo/gsg-announce
