  • 850阅读
  • 3回复
用Excel HAM QTH 梅登黑德坐标转换 [复制链接]
离线bh4bin
只看楼主 倒序阅读 0楼 发表于: 2023-02-02
春节在家闲的蛋痛,用Excel VBA 实现梅登黑德坐标转换功能,在VBE中输入以下代码,Excel 就增加了两个梅登黑德坐标转换函数。
嫌麻烦的可直接下载附件,在相应的单元格中输入就可以了。
Public Function LatitudeAndLongitudeToMadenheadGrid(Longitude As String, Latitude As String) As String
    ' 经纬度 转 梅登黑德网格
    ' Longitude: 经度,东为正,西为负。 度、分、秒用“,” 分隔。
    ' Latitude:纬度,北为正,南为负。度、分、秒用“,” 分隔。
    ' bh4bin
    ' 2023/1/29
    Dim A As Single, B As Single, C As Single
    Dim D As Single, E As Single, F As Single
    Dim X As Single, Y As Single
    Dim grid As String, Tmp As String
    Dim InputAyy() As String
    If Trim(Longitude) = "" Or Trim(Latitude) = "" Then Exit Function
    InputAyy = Split(Trim(Longitude), ",")
    A = InputAyy(LBound(InputAyy))
    B = InputAyy(LBound(InputAyy) + 1)
    C = InputAyy(UBound(InputAyy))
    X = A + B / 60 + C / 3600 + 1 / 1000000
    InputAyy = Split(Trim(Latitude), ",")
    D = InputAyy(LBound(InputAyy))
    E = InputAyy(LBound(InputAyy) + 1)
    F = InputAyy(UBound(InputAyy))
    Y = D + E / 60 + F / 3600 + 1 / 1000000
    If X >= -180 And X < 180 And Y >= -90 And Y <= 90 Then
        A = X / 20 + 9: B = Int(A): grid = Chr$(B + 65)
        C = Y / 10 + 9: D = Int(C): grid = grid + Chr$(D + 65)
        A = (A - B) * 10: B = Int(A): grid = grid + Chr$(B + 48)
        C = (C - D) * 10: D = Int(C): grid = grid + Chr$(D + 48)
        B = Int((A - B) * 24): grid = grid + Chr$(B + 97)
        D = Int((C - D) * 24): grid = grid + Chr$(D + 97)
        LatitudeAndLongitudeToMadenheadGrid = grid
    Else
        Tmp = MsgBox(prompt:="数据有误,请检查!!!", Buttons:=vbExclamation, Title:="警告")
        Exit Function
    End If
End Function
Public Function GridToLatitude(Optional grid As String = "PM01qd ") As String
    ' 梅登黑德网格 转 经纬度
    ' bh4bin
    ' 2023/1/29
    Dim strArr(1 To 6) As String
    Dim Longitude As Double, Latitude As Double
    Dim LongGroup As String, LatGroup As String
    grid = UCase(grid)
    For i = 1 To 6
        strArr(i) = Mid(Trim(grid), i, 1)
    Next i
    Longitude = (Asc(strArr(1)) - 65 - 9) * 20 + Val(strArr(3)) * 2 + (Asc(strArr(5)) - 65) * 5 / 60
    Latitude = (Asc(strArr(2)) - 65 - 9) * 10 + Val(strArr(4)) * 1 + Round((Asc(strArr(6)) - 65) * 2.5 / 60, 5)
    If (Asc(strArr(1)) - 65 - 9) * 20 > 0 Then
        LongGroup = "东经"
    Else
        LongGroup = "西经"
    End If
    If (Asc(strArr(2)) - 65 - 9) * 20 > 0 Then
        LatGroup = "北纬"
    Else
        LatGroup = "南纬"
    End If
    GridToLatitude = "经度在: " & LongGroup & Round(Longitude, 5) & " ~ " & Round(Longitude + 5 / 60, 5) & "; 纬度在: " & LatGroup & Round(Latitude, 5) & " ~ " & Round(Latitude + 2.5 / 60, 5)
End Function
Sub test()
    Dim Latitude As String
    Dim Longitude As String
    Longitude = InputBox(prompt:="东经+,西经-。度、分、秒用【,】分隔!", Title:="请输入经度", Default:="111,11,22")
    Latitude = InputBox(prompt:="北纬+,南纬-。度、分、秒用【,】分隔!", Title:="请输入纬度", Default:="11,1,21")
    If Longitude = "" Or Latitude = "" Then Exit Sub
    MsgBox prompt:=LatitudeAndLongitudeToMadenheadGrid(Longitude, Latitude), Title:="您的梅登黑德网格(Madenhead grid):"
End Sub
86893(933)部队86919部空军导弹学院105队94921部队
离线bh4bin
只看该作者 1楼 发表于: 2023-02-02
上传附件还要安装其它插件,晕!
离线BG6IYQ
只看该作者 2楼 发表于: 2023-02-02
       太牛了!!!
离线BD7BW
只看该作者 3楼 发表于: 2023-02-10
蛮好用的,感谢楼主。
湖南省郴州市
LOC:OL65MT
