  • 5119阅读
  • 19回复
FTDX10机内ATU评价 [复制链接]
离线BG6LH
只看楼主 倒序阅读 0楼 发表于: 2022-06-02
烧过两次FTDX10功放管。。因此对它的ATU特别关注了一下。
关于FTDX10的ATU,QST杂志有一个评论。说它很慷慨,别的电台认为调不下来不能发射的频点,它都能调下来发射。
这句话说的很微妙,两方面理解,FTDX10的ATU可调谐范围很大,另一方面也可以理解为它的驻波检测有问题。
2021年6月的QST杂志第44页:
Automatic Antenna Tuner
The FTDX10’s internal automatic antenna tuner isdesigned to handle impedance mismatches that resultin SWRs of 3:1 or less at the antenna port. The tuneractivates with a push of the TUNE button, and therelays chatter madly for a couple of seconds as itattempts to find a match. Assuming an acceptablematch is found, the tuner then appears to track acrossa substantial range within the band, adjusting quicklyas necessary each time you transmit on a new frequency.
I can’t help but mention that the FTDX10’s autotunerwas more generous in its matching ability compared tothe tuner in my own transceiver. In one instance, theFTDX10’s tuner found a match with my antennasystem at a frequency and impedance that my currentradio’s tuner stubbornly refuses to accept.
关于FTDX101D的ATU,QST杂志说很危险,因为发现它可能会按照你操作时设定的功率就调了。
在2019年QST杂志第54页上,原文:
Antenna Tuner
The internal antenna tuner quicklytunes an antenna system with up to aspecified 3:1 SWR to near 1:1, and itremembers the tuner settings for thatfrequency. I found that it could tunesome antennas with a higher SWR,but the internal SWR meter onlyshows up to a 3:1 value, so it can behard to tell. Attempting to use anantenna with more than the specifiedmismatch can be a risky business.While the radio cuts back to 10 W out(adjustable) during tuning, it will try topush whatever power setting youselect during operation, and damageto tuner components is possible inany tuner if ratings are exceeded.
从这个理解,101和10的机内ATU应该是一个意思的。
调谐功率是10瓦,但是可能会按照100瓦就调,并且末端的SWR检测和保护功能都不太准。
有条件测试的,可以关注一下自己的外置驻波表,分享一下体会。
我的正在苏州厂里排队维修。。
这里有一些相关资料:
QST杂志对FTDX101D的评价
https://www.yaesu.com/downloadFile.cfm?FileID=15279&FileCatID=156&FileName=PROD%5FREV%5F1119.pdf&FileContentType=application%2Fpdf
QST杂志对FTDX10的评价
https://www.yaesu.com/downloadFile.cfm?FileID=16965&FileCatID=156&FileName=FTDX10%20Product%20Review%20%28June%202021%20QST%20%2D%20ARRL%29.pdf&FileContentType=application%2Fpdf
FTDX10的技术手册
https://groups.io/g/ftdx10/attachment/508/0/FTDX10%20technical%20manual.pdf
离线bh5ehq
只看该作者 1楼 发表于: 2022-06-02
你的烧之前有告警音没?我这有一次无负载误触过发射键,开启过告警音
离线zsh
只看该作者 2楼 发表于: 2022-06-02
我的也回4S店了...........
我是中国最特殊的HAM之一 嘿嘿
DXCC:139 , WAZ Zone:37(缺:02;34;36;)。
革命尚未成功  HAM應需努力
致力于收集共享设备技术维修手册软件...........
个人业余电台呼号:BD7OA(EX:BG2IJJ)
诚实、守信、开拓、进取。73!
网名叫:金阿甘 QQ:444341969 微信:zsh5198
MSN:zshdodo@hotmail.com
网店:https://shop136258697.taobao.com
Blog:http://blog.sina.com.cn/radionew
Blog:http://www.radionew.com.cn/
手机:壹伍玖 0432 5198 只收短信
电邮:zsh518@gmail/126.com
住址与通信地址:请在www.qrz.cn用BG2IJJ/7查!
本人目前在七区!!!
只看该作者 3楼 发表于: 2022-06-03
大部分人买了机器是来用的,很少一部分人买了设备是来搞极限挑战的,4s店和售后服务站表示谢谢啊!
离线BG4IGX
只看该作者 4楼 发表于: 2022-06-04
不碰YAESU好多年了,原因嘛,都懂。
离线BD6AHP
只看该作者 5楼 发表于: 2022-06-06
貌似Y记的机子在ATU调谐是都是直接按照正常通联设定的功率发射的,不会自己降功率,至少我用过的FT1000、950、2000都是这样。
de BD6AHP
安徽滁州
离线ba4dl
只看该作者 6楼 发表于: 2022-06-14
回 BD6AHP 的帖子
BD6AHP:貌似Y记的机子在ATU调谐是都是直接按照正常通联设定的功率发射的,不会自己降功率,至少我用过的FT1000、950、2000都是这样。 (2022-06-06 08:16)
我的950和你的不一样,降到5瓦
离线bi4tgj
只看该作者 7楼 发表于: 2022-06-22
离线bd2bh
只看该作者 8楼 发表于: 2022-07-07
FTDX-10机内天调,1.8-29.7MHz、50MHz范围内,调整阻抗范围为16.7-150ohms,动态范围比较有限。
[ 此帖被bd2bh在2022-07-07 23:30重新编辑 ]
BD2BH_SHE@163.COM
离线bd2bh
只看该作者 9楼 发表于: 2022-07-15
调谐时不降低功率?这是不可能存在于商品发射机中的。一是,大功率调谐继电器烧蚀,粘连损坏的可能性大增;二是,如果一个继电器不动作,或者接触不好,将影响整个天调的适用范围,甚至总是调谐失败,形成恶性循环,直至损坏天调:三是,天调调谐动作时,天线处于失谐状态,所以任何末级功放是严谨禁大功率发射的,否则就容易损坏功放管!
BD2BH_SHE@163.COM
离线bg8il
只看该作者 10楼 发表于: 2022-07-15
用电动机带动可调电容调节的是不是就不用降功率?
QRP+鱼竿=折磨对方的耳朵。
田伟 重庆火腿回到了重庆
TEL:一八二二三〇六〇九八二
QQ:三七六一一二一二二
离线bg5ilx
只看该作者 11楼 发表于: 2022-07-24
我的101mp测试了数个波段开机内天调,驻波表显示9-11W,测试前提:发射功率调至180W测试,模式:cw,机器版本MAIN:V01-23, 图片上传不了
离线BG6LH
只看该作者 12楼 发表于: 2022-07-28
我后来测试FTDX10设置在20瓦,机内天调启动的时候,外置驻波表是大致在10瓦。
离线williamlee
只看该作者 13楼 发表于: 2022-08-06
不快, 但是 穩.
FT-450D,FT-817D, FTDX-5000MP LT., FTDX-10, IC-705
*Had been owned:Heatkit SB220, FT-920,FT-650,FT-180A,TS-480HX, FT-850, FT-847, FT-897, FT-857.ICOM 756 PROII, IC-703, TS-2000, FT-1000MP, FT-2000 Mk V, FT-900, TS-970, IC-7400, IC-7000,FT-950, ELECRAFT KPA500,
Palstar Inc. AT2K, AMERITRON AL811.
离线kg5srk
只看该作者 14楼 发表于: 2022-08-06
Ftdx1200 也是降到5w
离线BG1ADI
只看该作者 15楼 发表于: 2022-08-08
刚我用FTDX10测试了一下,各种模式启动天调,发射功率设置100W,调谐时功率也就1-2W,最多3W。
不知道是不是我的方法不对。
游  趣
离线王雷生
只看该作者 16楼 发表于: 2023-04-04
用891的路过   不管是接不接天线    直接发射,会报驻波大,也不会烧功放管啊 !!!!弄得我都不敢买DX10了
呼号:BG6OJX
QQ:68330835
电话:19939000388
地址:河南 济源 沁园 南夫 胜利街北六巷四十六号
离线bg2bfg
只看该作者 17楼 发表于: 2024-03-27
回 BG4IGX 的帖子
BG4IGX:不碰YAESU好多年了,原因嘛,都懂。 (2022-06-04 21:36)
最后还是碰了DX10
呼号:BG2BFG QQ:193257
黑龙江大庆
ICOM-7760
FTdx10
ft-991A
ft-897D
离线邹蕾
只看该作者 18楼 发表于: 2024-09-14
回 bd2bh 的帖子
bd2bh:调谐时不降低功率?这是不可能存在于商品发射机中的。一是,大功率调谐继电器烧蚀,粘连损坏的可能性大增;二是,如果一个继电器不动作,或者接触不好,将影响整个天调的适用范围,甚至 .. (2022-07-15 11:05)
应该会降到10W左右,在设置100W发射的情况下,自动调谐,纳胜驻波表上看到最大功率在10W左右
[ 此帖被邹蕾在2024-09-14 02:31重新编辑 ]
BI7NTP
离线bi6ndi
只看该作者 19楼 发表于: 2024-11-11
我也是感觉这个ATU不行,调好了,第二天就又变回去了,不知道怎么搞的
