  • 4797阅读
  • 3回复
请高手指点: 学习码630解码1527,1527遥控两个键,请问程序有什么问题, 编译成功,但 写不进芯片去 [复制链接]
离线门外汉
只看楼主 倒序阅读 0楼 发表于: 2010-03-11
include <pic.h>
#include <pic16630.h>
__config( wdtdis & pwrten &intoscio & mclrdis);
#define uchar unsigned char
#define uint unsigned int
#define rfin ra2   //11脚
#define fmq   rc0   //10脚蜂鸣器
#define laba rc2 //8脚报警
#define   chufa rc3 //7 脚传感踩下为低
#define unlock rc5 //5脚 解锁
#define ceshi   rc4   //6脚
#define led rc2 //8脚
#define study   rc1 //9脚学习按钮
uint l1, m1,n1;
uchar tlow;
uchar thigh;
uchar recnt; //接收位数24位
uchar keygeshu;//键数
uchar tmp1; //键按下时间变量
uchar tmp2;   //学习按下时间变量
uchar tmp3; //临时
uchar ks11; //开锁码1
uchar ks12;
uchar ks13;
uchar js11; //加锁码1
uchar js12;
uchar js13;
uchar ma01; //学习码变量
uchar ma02;
uchar ma03;
uchar ma11; //上次学习码变量
uchar ma12;
uchar ma13;
uchar ma21; //学习码变量
uchar ma22;
uchar ma23;
uchar tmp,tmp0;
const uchar cs@0x3ff;
bit   tongbutou; //同步头接收成功标志
bit   rfok;
bit   rf_er;//接收失败
bit   signth; //信号高低标志
bit study1;//是否学习状态标志
bit cdj; //踩下标志
bit   press;//有键按下
bit anxia;//有键持续按下
bit xuexi;//学习时间标志
bit     diffkey; //不同的键
bit   kaisuo;
bit   jiasuo;
void delay1(void)
for(tmp3=0;tmp3<100;tmp3++)
void delay2(n1)
for(l1=0;l1<100;l1++)
  for(m1=0;m1<n1;m1++)
void delay1(void)
asm("nop");
asm("nop");
asm("nop");
asm("nop");
void interrupt isr (void)
  clrwdt();
  if(t0if==1) //time0 100us中断
        t0if=0;
        tmr0=179;
  if(rfin==1)
        if(signth==1)//由低到高开始接收
                    if(tlow>thigh)//判断是否低电平
                          if(tlow>5&&tlow<19&&thigh>2&&thigh<9)
                                            recnt++;//是低电平
                                            ma01<<=1;//移动一位
                            else
                                            {//接收失败
                                            rf_er=1;
                    else if(tlow<thigh) //判断是否低高电平
                            if(tlow>2&&tlow<9&&thigh>5&&thigh<19)//
                                            recnt++;//是高电平
                                            ma01<<=1;//移动一位
                                            ma01++;
                            else
                                            rf_er=1;
                    else if(tlow==thigh)
                              rf_er=1;
                    if(rf_er==1)
                        tongbutou=0;//接收失败
                        recnt=0;
                        rfok=0;
                    else
                        if(recnt==8){ma03=ma01;}
                        else if(recnt==16){ma02=ma01;}
                    if(recnt==24)
                        tlow=0;
                        thigh=0;
                        recnt=0;
                        tongbutou=0;
                        if(ma01==ma11 && ma02==ma12 && ma03==ma13)
                        rfok=1; //接收成功
                        ma11=0;ma12=0;ma13=0;
                      if(ma01!=ma21 || ma02!=ma22 || ma03!=ma23)
                        diffkey=1;
                        press=1;
                        anxia=0;
                        tmp2=0;
                        ma21=ma01;ma22=ma02;ma23=ma03;
                    else
                    diffkey=0;
                    anxia=1;
                    tmp2=0;
                      else
                    ma11=ma01;ma12=ma02;ma13=ma03;
                    thigh=0;     //signth==1函数
        else   if(tlow>30&&tlow<180)     //判断同步头判断低与if(signth==1)并行
                  tongbutou=1; //检测到正确的同步头
                  recnt=0;   //接收位数,清除0
                  thigh++;
                  tlow=0;
                  signth=0;
                  rf_er=0;//接收失败标志
  else   //与if(rfin==1)接收低并行
      {     //输入端口为低电
        tlow++;
        if(tongbutou==1)//开始接收标志
              signth=1;
        else
            thigh=0;
  if(tmr1if==1)
        tmr1if=0;//清中断标志位
tmr1h=0xcf;//初值53035
tmr1l=0x2b;
if(xuexi)//
  ++tmp2;
  if(tmp2==25)
tmp2=0;
  if(!study)
xuexi=0;
study1=1; //学习状态标志
led=1;
keygeshu=0;
ma23=ma22=ma21=0;
        if(anxia)
            press=0;
            ++tmp1;
            if(tmp1==5)
            tmp1=0;
            anxia=0;
            press=1;
void main(void)
    osccal=cs;
    portc=0x20;
    porta=0x00;
    cmcon=0x07;
    trisa=0x07;
    trisc=0x0a;
    wpua=0x04;
    ioca=0x04;
    option=0x0e;
unlock=0;
tmr0=179;
intcon=0xe0;       //使能timer0;
t0ie=1; //使能timer0;
  if(eeprom_read(1)!=1)
// delay1();
eeprom_write(1,1);
delay1();
eeprom_write(2,0);         //存开锁码
delay1();
eeprom_write(3,0);
    delay1();
eeprom_write(4,0);
    delay1();
eeprom_write(5,0); //存加锁码
    delay1();
eeprom_write(6,0);
    delay1();
eeprom_write(7,0);delay1();
ks11=eeprom_read(2);
//delay1();
ks12=eeprom_read(3);
//delay1();
    ks13=eeprom_read(4);
//delay1();
js11=eeprom_read(5);
//delay1();
js12=eeprom_read(6);
//delay1();
js13=eeprom_read(7);
delay1();
if(eeprom_read(6)!=0) {ceshi=1;}
tmr1h=0xcf;
tmr1l=0x2b; //time1 0.025s*8预分频定时
t1con=0x30; //关闭timer1 设置1:8预分频
pie1=0x01; //使能time1定时中断
tmr1if=0;
tmr1on=1; //启动timer1
  while(1)
if(rfok)
rfok=0;
if(!study1)
if(press)
    if(ks11==ma01 && ks12==ma02 && ks13==ma03)
        unlock=1;
        kaisuo=1;
        jiasuo=0;
        fmq=1; delay2(100); fmq=0; delay2(100);
    else if(js11==ma01 && js12==ma02 && js13==ma03)
        unlock=0;
        kaisuo=0;
        jiasuo=1;
        fmq=1; delay2(100); delay2(100); delay2(100);
        fmq=0;
    else
    if (diffkey)
    ++keygeshu;
      if(keygeshu==1)
eeprom_write(2,ma01);         //存开锁码
delay1();
eeprom_write(3,ma02);
    delay1();
eeprom_write(4,ma03);
    delay1();
        //save();
  else if(keygeshu==2)
    eeprom_write(5,ma01);         //存加锁码
delay1();
eeprom_write(6,ma02);
    delay1();
eeprom_write(7,ma03);
    delay1();
      // save1();
    keygeshu=0;
    led=0;
    study1=0;
    //ceshi=1;
    //anxia=1;
    //press=1;
  if(!study)//学习
    if(!study1 && !xuexi)
    xuexi=1;
    tmp2=0;
  else
xuexi=0;
tmp2=0;
led=0;
study1=0;
keygeshu=0;
用mplab8.0版本编译成功 ,偶尔一次能够写进芯片,偶尔又不行。请指点
编译都能够成功,在什么都没改变的情况下,有时编译后能够写进芯片,有时编译后又写不进去,不知道什么原因?能够写进芯片的程序都能够正常工作
在线BG4UVR
只看该作者 1楼 发表于: 2010-03-11
我觉得,目标代码能不能写进去芯片,和代码本身基本没啥关系。(虽然pic的熔丝设置是在hex中~)
离线门外汉
只看该作者 2楼 发表于: 2010-03-11
我用的是wellon 的 vp-pic1编程器
离线XLDZZ
只看该作者 3楼 发表于: 2010-03-11
看你的config位设置不全
里边还有代码保护和flash保护段
如果没有设置,编译器也许会自动保护代码的,
所以设置一下保护位试试看。
