  • 160200阅读
  • 564回复
ICOM706MKIIG(以及此系列机器)使用探讨专贴(请各位706的腿子们捧场) [复制链接]
离线bd2fw
只看该作者 300楼 发表于: 2005-06-17
欢迎加入......
离线bd2fw
只看该作者 301楼 发表于: 2005-06-18
这里有icom电台的civ电脑连接线(usb接口)40元一条。
http://hellocq.com/cgi-bin/topic.cgi?forum=18&topic=39668
bg9dm提供的控制软件下载地址:
http://www.ham-radio.ch/kits/beta/3.1/hamradiodeluxeversion031b687.exe
速率设为9600波特
可用机型:icom:
ic-703, ic-706, ic-706mkii, ic-706mkiig, ic-718, ic-725,ic-726,ic-728, ic-729, ic-735
ic-736, ic-737, ic-738, ic-746, ic-746pro, ic-756, ic-756pro, ic-756proii
ic-775dsp,ic-781, ic-7400, ic-r10, ic-r75, ic-r8500 and ic-910h
离线BA2QM
只看该作者 302楼 发表于: 2005-06-22
顶!!!!!!!!!
离线bd5ir
只看该作者 303楼 发表于: 2005-06-23
http://www.mods.dk/view.php?articleid=1447
  谢谢!回去试一下!
离线BD7JAC
只看该作者 304楼 发表于: 2005-06-24
想知道mkiig和mkii除了多个0.7米以外,在功能上还有什么差别吗?
离线BD7ISO
只看该作者 305楼 发表于: 2005-06-25
基本没有差别。。。。。
离线BD7JAC
只看该作者 306楼 发表于: 2005-06-25
那就是说mkii的说明书已够用了,我在mods.dk的网站上看到这个,英文不行,只知道意思是功率可以调整到:
hf: between 125 watts and 150 watts (on 40mtr)!
6 mtr: 120 watts
vhf: 70 watts
uhf: 40 watts
深圳的muv好像已试过hf最大220w,150w可以长时间工作,不知还有哪位试过或者愿意试试。
for this mod you need an power meter and a dummy load!
open the transceiver case (top panel, 5 screws) as shown in the manual on page 59
locate r1082 (hf), r1084 (6 mtr), r1086 (vhf) and r1088 (uhf) see manual page 63
for adjustment r1082 (hf): power on the rig set frequency to: 14,100 mhz, mic gain: 5, mode usb and push ptt (don´t forget to whistle in the mic or use an audio generator set to 1,5 khz 30mv !)
the same procedure for 6mtr (set to 52,000 mhz), vhf (set to 145,000mhz) and uhf (set to 435,000 mhz)
turn above potis (r1082, r1084, r1086 and r1088) clockwise to maximum output
that´s it!
i have done this mode on my rig and i have no problems! my final is still ok!
my ouput power after the modification:
6 mtr: 120 watts
vhf: 70 watts
uhf: 40 watts
warning: doing this mod may eventually result in a damaged final transister and/or reduced service life!!
mod done by alex, hb9tsf, nh7vw
离线bg7muv
只看该作者 307楼 发表于: 2005-06-25
6 mtr: 120 watts
vhf: 70 watts
uhf: 40 watts
我又被点名了?ic-706mkiig有三个三菱rd70hvf1功放,其中一个用于u/v段,两个合成功率用于hf+50m,所以706的功率冗余量很大,好机器,不过别调太大功率,实践觉得hf120-150w长期使用还没什么问题。
根据706功放芯片技术参数可以知道以下:
uhf最大功率:50w(单个功放)
vhf:70w(单个功放)
短波:150w-220w(两个功放)短波底段比较高,高段没那么高
三菱rd70hvf1参数:
http://www.rfparts.com/pdf_docs/rd70hvf1.pdf
离线BD7ISO
只看该作者 308楼 发表于: 2005-07-01
战火考验过的706
火烧后的706
离线三戒斋主
只看该作者 309楼 发表于: 2005-07-01
用户被禁言,该主题自动屏蔽!
在线BD9DM
只看该作者 310楼 发表于: 2005-07-01
还正常使用吗?
离线BD4AGK
只看该作者 311楼 发表于: 2005-07-11
看这个样子还能正常使用!!!太强了~~~~
离线BA2QM
只看该作者 312楼 发表于: 2005-08-21
顶起来!大家继续讨论啊!!!!!!!!!!!!!
离线BG2AJH
只看该作者 313楼 发表于: 2005-10-10
我也想买,请教老师们,706有跨段中继功能吗?
离线bd2fw
只看该作者 314楼 发表于: 2005-10-11
跨段中继功能有用吗?
离线BG2AJH
只看该作者 315楼 发表于: 2005-10-11
也没什么用,只是功能缺了一样心里不舒服。
离线BD7ISO
只看该作者 316楼 发表于: 2005-10-12
706主要是车载短波机,u/v是附加功能。
买全新706mkiig要us$950,还没有算运费。
你要是真买一台706恐怕还不敢每天放车上。
离线xzxdf
只看该作者 317楼 发表于: 2005-10-12
ic-703 也算是小弟弟!哈哈
我刚搞了台ic-703,有哪位知道它的内置天调如何使用?
离线bd2fw
只看该作者 318楼 发表于: 2005-10-27
有给706配手提箱的吗?
离线bd2fw
只看该作者 319楼 发表于: 2005-11-12
有加装ssb滤波器的吗?谁有渠道帮我搞一个。
