  • 3398阅读
  • 1回复
Dentron GLA-1000 Conversion, Modification  With 4 × PL/EL-519 or 2 × GI-7B [复制链接]
离线bg8nq
只看楼主 倒序阅读 0楼 发表于: 2020-11-09
Click for NL version
23-aug-2013 With an other input circuit.
Partly finished conversion with a doubling power supply, a 12.6 VAC filament transformer and 2 × GI-7B.
You may possibly build a HF amplifier with the information in this article.
DESCRIPTION
By modifying this amp were minimal changes to the original design and as far as possible minor initial components used.
The pictures are of the (my) older model 80, 40, 20 and 15 m Dentron GLA-1000 (Plane, no tuned input) HF linear amplifier. The export model had not a 10 m imprint on the front but the band switch was equipped with a fifth state allowing an easy extension to 10 m. It was already done in my GLA-1000. That type is a compact little amplifier, size 28.5 × 14.5 × 34 cm, w × h × d. The depth includes the outward-blowing fan to the rear. These PA's were equipped with American 6MJ6, 6LQ6 and 6JE6C line output tubes. They are randomly to be used but it is better if all runs with equal quiescent currents. They cost a fortune if you can find them. Depending on the brand, the quality of the tubes is moderate to reasonable. They have the same sockets as an EL/PL519 only the pen contacts are different. My experience is that these European tubes appear to be much more robust in a HF amplifier than the American types. The latter have more flashovers after a long unused period. The tubes are also troubled with flashover with more than 50 W from the exciter and then the 230 VAC fuse blows. Unfortunately, the manufacturer did not fit a protection fuse and series resistor in the anode circuit so that the tubes can become defective. The rapid deterioration of the tubes was a common phenomenon. In the later versions a relay with three change over contacts was mounted and on transmit the third contact activate a zenerdiode for the correct idle current.
CUT-OFF
Some plane Dentron GLA-1000 series amplifiers did not have a "cut-off" circuit to reduce the cathode current in receives mode. This had two disadvantages: they dissipate a continuous power of 80 W and the amplifier was "on" without an output load. In the latter case a chance for random oscillations was not excluded. With the increased idle current the tubes worked near their anode dissipation and worn out faster than usual.
With this mod there is no need for a 3rd change over relay contact. There is only one component to be added.
A 27 kΩ resistor cuts off the cathode current when the amplifier is stand by. There is still about 300-500 μA idle current, eventually mount more than 27 kΩ for minimum current. Relay K1A contacts short cut the resistor when the amplifier is keyed allowing D1 to hold the idling plate current via RFC1. The latter isolates the RF driving signal from ground (via C7). Two paralleled capacitors were installed in the relay lead to the "RF in" input preventing DC current flowing into the transmitter. Choke RFC1 is wired from that relay contact to the bypassed end of the zener diode.
GLITCH PROTECTION
There is no failure mode of "glitch" protection and it is a matter of time before the amplifier fails for a number of reasons or shortcomings. Update the PA with the marked components. The extra 4.7 nF capacitor parallel to C8 improves the decoupling of the anode choke RFC6 on 80 m.
TEST WITH 4 × PL519
Because the American sweep tubes has the same socket as an EL519 a modification would be a piece of cake. The ever-flashing 6LQ6 tubes (with simultaneously a blown main fuse) were replaced by PL519's, so it was easy and safe to see how the amplifier would react in the various bands.
4 × PL519
Drive
Output
PL519 = EL519, filaments: PL519 = 40 VAC/300 mA, EL519 = 6.3 VAC/~2 A
During the test a FRI-match ATU was used for matching the PA's input with a length of 2 m coax cable between ATU and amplifier.
80 m
80 W
500 W
40 m
80 W
425 W
30 m
85 W
450 W
20 m
80 W
375 W
17 m
85 W
400 W
15 m
80 W
375 W
12 m
70 W
350 W
10 m
85 W
250 W
WIDEBAND INPUT CIRCUIT & EL519's
The static input impedance of the cathode in a grounded grid circuit can be calculated if the valve characteristics relating to the specific circuit are known. The dynamic input impedance (during working conditions) is often higher. Furthermore it varies during a SSB transmission because the driver (the transceiver) is delivering power varying between say 0.1 W (the suppressed carrier) and about 100 W. The input- and output impedance of the amplifier are constantly varying and the driver sees a constantly varying load. If the internal controlling system (ALC) cannot handle this, a distorted signal will be generated in the transceiver. With a fast reacting SWR-indicator between TX and PA, one will see a constantly varying SWR. The input impedance of the PL519's in the circuit chosen by me was not known. With an experimental test rig, I have tried to obtain some relevant data. It turned out that these data were different for every amateur band, roughly averaging 17 Ω–27 Ω and with some guessing, I found that for 4 valves in parallel, the average real part was 22 Ω, say 25 Ω.
In most cases a tuned circuit between driver and final stage is recommended. By way of flywheel-action this tuned input-circuit will, to a degree, level out the quite variable input impedance, thereby preserving a reasonable match and thus linearity and output of the driving transceiver. The tuned input circuit also shortens the HF return path between anode and cathode by preventing this HF current to follow the longer path via the transceiver. As modern transceivers have more than sufficient power, the "flattening" of the input impedance may also be obtained by extra loading (swamping) the input-circuit with a resistance or suitable wide band combination, in which excess driving power can be absorbed. This also helps in lowering the HF return-path impedance.
In our case, matching is done with a 4 : 1 RF impedance transformer (fig») which transforms the 25 Ω impedance to about 100 Ω. By putting a 100 Ω-swamping resistor across it, the driver will see a load with a SWR of less than 1.5. Nearly all transceivers can deliver about 100 W with such an SWR without an antenna tuner. The 100 pF trimmer is for minimising the input SWR in the 10 m band. Adjustment of the input- and output-circuits must be done with full carrier power (key down) for maximum output power and minimum input SWR.
This transformer («fig) is wound on a ferrite rod from an old MF radio. A 5 cm piece of 1 cm diameter will do, longer is OK. With enamelled wire of 14–19 SWG, 9 close bifilar turns are made on a 9.5 mm drill bit and then slipped onto the ferrite rod. This is a safe method as the ferrite is quite fragile. The two inner wire ends must now be soldered together; this junction goes via 2 × 10 nF to the common junction of the 39 Ω cathode resistors. The two outer wire ends will go, via capacitors, respectively to earth and, with a piece of coax cable, to the input relay.
This (right picture) alternative simpler resistor input circuit has a higher SWR on 10–40 m and reduced output on 10 m, however this should not be a problem with a modern transmitter with a built-in antenna tuner.
IDLE CURRENT ADJUSTMENT
When using valves in parallel, we have to consider the individual differences. With collective bias, individual-resting currents will differ. Even if the idle currents are made equal, the HF-amplification factors are not. In our bare-bones circuit, an individual adjustment was considered, but left in favour of a simpler system, based upon DC-feedback during excitation.
This is done («fig) with by-passed 39 Ω resistors in the individual cathode leads; a valve drawing more current will bias itself more and therefore reduce its amplification. The resistors will also partly determine input-impedance and SWR. Their value can be lowered (down to 10 Ω), to increase the output. However, the SWR will be higher on some bands, causing a transceiver without built-in antenna tuner to resolutely settle back. The older transceivers with valves and pi output tuning do not have this problem.
The value of the collective bias is adjusted with a string of 3–10 diodes in series. Short circuit one of more for a standing current of about 20–25 mA per valve, i.e. 80–100 mA in total for 4 valves. When using this simple bias circuit, it is advised not to wait too long with speaking after pushing the PTT button, in order to let the valves draw standing current for only a short moment. The reason for this prudence is the possibility that the individual currents deviates so much, that one or two will draw much more current and dissipate excessively. In this way, the valves will only conduct when the PTT is activated. As a rule, the individual products of standing current and anode voltage should stay below the maximum dissipation of 35 W per valve. Assuming a 10 % spread in standing currents the total dissipation, while sending without drive, will be about 130 W.
FILAMENT PL519's
Each PL519 filament requires 40 VAC/0.3 A. In our circuit, the four filaments may be fed in series; with a capacitor of 5.6–6 μF/250 VAC added in series. The string may be connected directly to the 230 VAC (50 Hz) mains. If the chassis of the PA is earthen through the cable to the mains, this method is acceptable, with the added benefit of a gradually heating up of the filaments, i.e. without the thermal shock incurred by transformer feed. Because the cathodes are not at RF earth level, the filaments are by-passed to earth with capacitors.
This (fig») is an example for the calculation of the capacitor in series with 0.3 A filaments. NOTE: substitute in the formula 60 for 60 Hz mains. (fig»)
ADJUSTMENT
After having (re) checked the newly built linear, the transceiver, a dummy-load and a power meter are connected. Don't forget the control lead for the relay! If, after applying power, the linear does stay stable, you probably did everything right. Now push the PTT-switch (in SSB mode but without speaking into the mic.) then one at a time, short as many of diodes in the cathode diode string as it takes to obtain the desired 80–100 mA anode idling current.
Warning: Be sure the power is off and the HT electrolytic discharged before touching any internal wiring!
With about 10 W drive and beginning with the 80 m band, tune the output-circuit for maximum power. Repeat the procedure, alternating between loading C and tuning C, till maximum power is reached. NB Whistling in the mike will not give a steady signal, a carrier (CW or FM) is necessary for repeatability.
Now raise the drive level to 100 W and repeat. Let the PA cool for at least 30 seconds after every 30 seconds of transmitting, to keep the valves healthy. Off-resonance, hefty currents can flow through the valves! If possible, proceed initially with lowered supply voltage. All now seems adjusted optimally but pay attention: lower the capacitance of the loading C until the needle of the power meter falls back 2 to 3 needle thickness; now re-adjust the tuning C for maximal power. Only after this last adjustment is full linearity achieved. Record capacitor settings before proceeding to the next frequency and/or antenna.
REACTIVATON GI-7B and 6LQ6
To avoid flashover in a new or a long time unused tube, it is prudent to prepare ("reactivate") it for his task. There are various opinions and solutions how to do it, but with a GI-7B it can be relatively simple. A DC of 30 to 40 V is sufficient for the tube to draw 500 mA as the grid is connected to the anode. Heat the tube 30 minutes with a filament voltage of 12.9 V. Then supply a HT of about 25 V "high voltage" and set for a current of 400-500 mA. If possible use a current limiter, because during reactivate the current can increase suddenly so that continue monitoring could be necessary to maintain the selected current. Usually I will not reactivate longer than an hour or so. Soon you will find out at which voltage a good tube drawn 500 mA, so you have an indication if another tube is better or not.
TEST OF 2 × GI-7B WITH THE ORIGINAL 1050 V SUPPLY
Left: the original axial-flow cooler replaced with a transversal cooler (black), both have a 6 mm metrical thread. Right: an alternative cooler.
Test 1 × GI-7B with a smaller cooler for the anode. The tube was temporary mounted on a base of a defect 3-500Z for eventually testing in my FRI750 PA
Test with minor modifications of the schematic. The blue colour marks the details.
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/gi7btestf2.jpg[/img]
Test with 2 × GI-7B and an external input circuit (ATU) to obtain SWR = 1 on all bands. Anode supply was about 850 V on load.
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/original-sockf1.jpg[/img] [img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/original-sockf2.jpg[/img]
An original socket for the GI7B.
Test with 4 × PL-519 and 2 × GI-7B with minor modifications (see schematic) of the original GLA-1000 design. NOTE: "low" output due to the 221 VAC mains in my home, anode voltage under load 850V.
4 × PL519
Drive
Output
2 × GI7B
Drive
Output
80 m
80 W
500 W
80 m
80 W
450 W
40 m
80 W
425 W
40 m
80 W
450 W
30 m
85 W
450 W
30 m
80 W
425 W
20 m
80 W
375 W
20 m
80 W
450 W
17 m
85 W
400 W
17 m
80 W
400 W
15 m
80 W
375 W
15 m
80 W
450 W
12 m
70 W
350 W
12 m
80 W
450 W
10 m
85 W
250 W
10 m
80 W
425 W
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/feedbackrs.gif[/img]
This converted amplifier requires less drive than the 100 watts many transceivers provide. Addition of a ± 10 Ω/15 W non-inductive resistor (R) is a simple way of correcting the overdrive. An RF-negative-feedback voltage will be developed across R when the GI-7B amplifies RF and reduces the driving voltage developed at the cathode. The negative feedback also improves amplifier linearity by reducing IMD to a level lower than that attainable when the tube is driven at its rated driving power without the feedback resistor, it helps to keep tube operation in its linear region. R absorbs the excess driving power as heat. The input impedance without a input circuit is ± 50 Ohm and SWR ≤ 1.7.
EXPERIMENTAL VARIABLE INPUT CIRCUIT WITH 1 KNOB
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/gi7binputf.jpg[/img]
2 × GI7B
Drive
Output
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/gi7binputs.gif[/img]
80 m
100 W
480 W
40 m
100 W
500 W
30 m
100 W
450 W
20 m
100 W
450 W
17 m
100 W
400 W
15 m
100 W
450 W
12 m
100 W
450 W
10 m
100 W
425 W
I did experiments with an input circuit based on my Fri-match design. This matching system increased the output on the lower frequency bands and improves the input SWR. The test model (fig») is made with a T94-6 toroid and a small twin ganging variable cap.
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/gi7binputs2.gif[/img] [img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/t68-2f.jpg[/img]
I have not tested this (F1FRV) modified alternative input circuit, but you can do it yourself.
TEST 2 × GI-7B WITH DOUBLING 2100 V SUPPLY
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/gi7bs2.gif[/img]
The "final" circuit? The key-down output is limited to 700–750 W with a 25 Ohm feed-back resistor (R).
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/feedbackrf.jpg[/img][img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/testhvf.jpg[/img]
Testing the "final" circuit with 10 Ohm feed-back and an (fig») temporary external HT doubling components, 6 × 220 µF/450 V and 6 × 1300 V/1 A. Key-down output was 700–850 W with 1500 V on load. Average CW/1850 V, SSB/2000 V and off load ± 2100 V. An 24 zener diode holds the idling plate current flow to around 100 mA.
The dissipation of the tubes is overrated in this design but the transformer is not e.g. the output should be limited to 700–750 W. Therefore the feedback resistor "R" was increased to 25 Ohm. Two 50 Ohm/30 W non inductive "chip" resistors («fig) in parallel on a small heath sink ware mounted in the airflow of the blowing fan.
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/socketf1.jpg[/img]
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/tool-clipsf.jpg[/img]
Tool clips
Test with temporary wiring and alternative cathode/filament connections with hose clamps and tool clips.
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/socketf2.JPG[/img]
Standard tool clips used as connectors.
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/socketf3.jpg[/img]
The improved wiring.
The elevating of the voltage from 1050 to 2150 V increased the plate load impedance.
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/draadf1.jpg[/img]
Remove the 20-15-10 m coil L1 and wind another coil with the same wire size or with standard 6 mm² tinned solid copper wire (fig ± 2.76 mm diameter»). It has 13 turns with an inner diameter of ± 34 mm, a length of about 6.5 cm. My coil was tightly wound on a standard grey 32 mm PVC tube, then elongated. The turns were evenly spaced and tapped on 4½, 8½ and 11½ turns for respective 10 m, 15 m and 20 m. Eventually reposition the 20 m tap for maximum output. An output match for 30 m is possible with the 20 m tap but a better match occurs by installing an additional contact on the band switch for 13 turns such as already drawled in the schematic. The new coil and L2 will now tune the tank circuit properly on both 40 and 80 m with the existing tune and load capacitors. The capacitance of the tuning C9 was increased by soldering an extra 100 pF/5 kV from the 20 m tap to ground.
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/elcosf1.JPG[/img] [img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/elcosf2.JPG[/img]
PCB with fusing, rectifier & doubling supply, metering plate current and plate voltage.
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/filtrafof.jpg[/img]
Note:
The filament voltage on load is 12.8–13.1 VAC
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/elcosf3.jpg[/img]
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/frontf.gif[/img]
Planned front with tuned input circuit.
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/gridcurrents.gif[/img]
Function Switch: Volts converted to grid current or rel. output converted to grid current.
To be continued
[img]https://pa0fri.home.xs4all.nl/Lineairs/GLA1000/bar2.gif[/img]
cq  cq  cq this bg8nq  bg8nq   calling   cq   and  stand  by !
离线bh5ehq
只看该作者 1楼 发表于: 2020-11-10
加防尘网的就是讲究
