HF Propagation 高频传播
HF Propagation 高频传播
bg8nq
UID:3064
390小时
发表于: 2020-11-07
HF Propagation 高频传播
http://www.hamqsl.com/solar3.html#hfprop
Oct 7 2020 - HAMQSL Updates and Upgrades in Progress
Items completed:
Special thanks to Andrew KC2G and Alan N5PA for identifying a reliable source for MUF for Athens,GR; Hermanus,ZA; Sondrestrom,GL; Alaska,US; Niue IS; Darwin,AU; Tromso,NO; Mawson,AQ; Jicamarca,PE; Port Stanley,FK; Ascencion IS; Jeju IS; and Millstone Hill. This has been fixed on all selectable MUF banners, and specifically the marston.php and solarmuf.php banners. Data updated every 10 minutes and validated to be less than 1 day old (otherwise displays No Report)
Site is secure SSL from Clouldflare. Just substitute https:// vs http:// in the banner links
Separate CRON job for Boulder MUF updated every 10 minutes and validated to be less than 1 hour old (otherwise displays No Report)
CRON jobs fixed so data and images are once again updated every 30 minutes
Background X-Ray and Flare strength (both used in predicted forecast for all bands) fixed (new reliable source)
Proton & Electron Flux fixed (new reliable source)
Boulder MUF, fof2, and MUF factor fixed (new reliable source thanks to Alan N5PA)
xml and rss outputs updated (with new sources)
Updated NOAA SWPC WSA-Enlil Coronal Mass Ejection (CME) Solar Wind Prediction pages
Items in progress:
6m North America propagation
If you have a source please let me know. Understand I will need their permission, and so far at least one reliable source has refused.
Broken links and outdated information as well as new data as it becomes availablePlease let me know if I break/or you see anything while fixing these issues. Lets hope the lousy Solar Cycle 25 forecast is totaly wrong (as have been in the past).
HF Propagation Tools and Solar Data are now on multiple pages for faster loading
Use the buttons at the top and bottom of the page to navigate, or use the following links:
For Solar-Terrestrial Data banners and widgets (both web page and devices)
click here
For Online MOF/LOF HF Propagation Prediction Tool, and conversion tools
click here
For NOAA's SWPC WSA-Enlil Coronal Mass Ejection (CME) Solar Wind Prediction Model
click here
For Understanding/Using Solar-Terrestrial Data, Solar Images, and HF Tutorials
click here
pdf presentation that contains tutorials and information on understanding radio propagation, and how to use all the data contained in the solar panels. You can download from
this link
pdf presentation that contains detailed instructions on adding a banner to your
www.qrz.com
BIO page. You can download from
this link
Current HF Propagation Conditions
f0f2 Critical Frequency, T-Index, & HF Fade
Courtesy of
Australian Space Weather Agency
Select desired plot from box. Page refresh updates all images at once.
Global f0f2 Freq Global f0f2 T-In Global HF Fade TEC Solar Wind Speed Solar Stereo A Solar Stereo B Solar Wind Angle Solar Activity
Current Global foF2 Frequency Map
Current Space Conditions (Solar Wind/Interplanetary Magnetic Field/Miscellaneous Dials) at Sun-Earth L1 Point
Courtesy of
Rice University
Select desired item from box. Page refresh updates all images at once.
On the dial background color schemes, green indicates that values in this range are unlikely to disturb the near-Earth space environment. Yellow indicates that values in this range may contribute to disturbances, and Red indicates that values in this range are likely to drive disturbances. This scheme is valid for all dials except the "Log[Beta]" dial
Solar Wind
Miscellaneous
Speed Density Pressure Temp
Solar Wind Speed
Magnitude Polar Ang AZ Deg
Interplanetary Magnetic Field Magnitude
Convection ALFVEN Spd Sound Speed Therm Energy Log (Beta) ALFVEN Mach Mach No.
Voltage Across the Polar Cap / Convection Potential
Maximum Usable Frequency (MUF), 5-30MHz Absorption, F2 Height, and Solar Angles
Courtesy of
Solar Terrestrial Dispatch
MUF Map Critical f2 Map Critical E Map 5MHz Absrptn Map 10MHz Absrptn Map 15MHz Absrptn Map 20MHz Absrptn Map 25MHz Absrptn Map 30MHz Absrptn Map F2-Layer Height Solar Zenith Angle
Current MUF Map
Current Solar Space Weather and Aurora
Courtesy of
National Institute of Information and Communications Technology
Last 30 days of Solar-Terrestrial Activity based on data from sunspot groups and solar flares, solar wind data from ACE, geosynchronous observation from GOES satellite, and K index from Kakioka magnetic observatory.
Courtesy of
KHO Auroral Forecast Service
Left image show the size and location of the impact zone of energetic particles from the Sun.
Right image shows the local all-sky view of the oval. Sun, moon and satellite or star poistions are also included.
Top images North pole, bottom images south pole.
North Pole KHO Auroral Forecast
South Pole KHO Auroral Forecast
Courtesy of
SWPC NOAA
and
University of Bradford
Select desired plot from box. Refresh page updates all images.
Solar Flare Mtr USAF Wing Kp Solar X-Ray Satellite Env ACE Solar Wind Space Weather Overview D-Region Abs Proton Flux Electron Flux Magnetometer Kp-Index Radio Flux
University Of Bradford Solar Flare Monitor
cq cq cq this bg8nq bg8nq calling cq and stand by !
