  • 3134阅读
  • 12回复
Grid Squared Award 是个什么奖?求教! [复制链接]
离线bg8tfn
只看楼主 倒序阅读 0楼 发表于: 2017-08-22
今天朋友帮我在QRZ.COM申请了一个六大洲通联奖和这个Grid Squared Award,英文没看明白,不想稀里糊涂的,特向懂的老师请教!
[ 此帖被bg8tfn在2017-08-22 18:11重新编辑 ]
BG8TFN-昆明
E-mail:1723331435@qq.com
离线BD7IS
只看该作者 1楼 发表于: 2017-08-22
天下无敌打遍天下无敌手联合国特邀业余无线电台杰出优异诺贝尔通联大奖
离线BH4SRC
只看该作者 2楼 发表于: 2017-08-22
Award Description
Requires contacts using the “Maidenhead” Locator grid square system.
Grid square locators are designated by combination of 2 letters (AA-RR)(a field), the squares by 2 numbers (00-99),and 2 sub-squares letters (aa-xx).). i.e. QF56od is the location Sydney, Australia.
Therefore the Grid Square for Sydney is QF56.
Rules
Grid Square Award
The GRID SQUARE award is available as recognition of the appropriate number of confirmed contacts with Amateur Radio stations in Grid Squares. It's purpose is to stimulate interest in the IARU grid-square system.
• General rules apply
• Requires contacts using the (IARU) three regions “Maidenhead” Locator grid square system. Note that the Maidenhead Locator system uses the WGS84 datum.
• Grid square fields are designated by combination of 2 letters (AA-RR), the squares by 2 numbers (00-99). i.e. QF56 is the location Sydney, Australia.
• The applicant must also quote the location or field where the contact was made from.
• Only contacts made on and after the 1st January 1990 qualify for this award and must be land based.
• Minimum requirements are:
o 100 contacts on any combination of HF bands: 1.8, 3.5, 3.8, 7, 10, 14, 18, 21, 24, 28 MHz. (100 different locators), or
o 50 contacts for VHF 50-54 MHz. (50 different locators),, or
o 30 contacts for VHF 144-148 MHz. (30 different locators) , or
o 25 contacts for UHF 420-450 MHz. (25 different locators) , or
o 10 contacts for UHF 1240-1300 MHz. (10 different locators) , or
o 5 contacts for 13cm and above 2300-2450 MHz, SHF– EHF 248-250 GHz. (5 different locators)
CRAC C类考试群:264623089
搜集和翻译的资料:www.zsrj.ys168.com
无线电点滴记录:www.qsl.net/bh4src
离线BH4SRC
只看该作者 3楼 发表于: 2017-08-22
中译,就当做是网格通联奖吧。
以梅登黑格网格系统为基础,通联IRAU3个分区的网格内的电台。
1990年1月1号后的通联有效,
必须是陆地台
主要奖项有:
HF段100
V段6米50
V段2米30
U段430MHz25
U段1.2GHz10
13cm段及以上5
在线husy
只看该作者 4楼 发表于: 2017-08-22
爬格子奖,叶老可以看成是你读书的时候的作文比赛,爬的格子越多,越有机会获奖。
LOC:OL63na
离线bg8tfn
只看该作者 5楼 发表于: 2017-08-23
回 BD7IS 的帖子
BD7IS:天下无敌打遍天下无敌手联合国特邀业余无线电台杰出优异诺贝尔通联大奖 (2017-08-22 18:35)
大佬,无梨搭圾咁,打击我地滴靓仔咁唔得既!
BG8TFN-昆明
离线bg8tfn
只看该作者 6楼 发表于: 2017-08-23
回 BH4SRC 的帖子
BH4SRC:Award Description
Grid square locators are designated by combination of 2 letters (AA-RR)(a field), the squares by 2 numbers (00-99),and 2 sub-squares letters (aa-xx).). i.e. QF56od i .. (2017-08-22 20:00)
谢谢您的好意回复,虽然我E文不认识,但还是真心谢谢!
BG8TFN-昆明
离线bg8tfn
只看该作者 7楼 发表于: 2017-08-23
回 BH4SRC 的帖子
BH4SRC:中译,就当做是网格通联奖吧。
1990年1月1号后的通联有效,
....... (2017-08-22 20:09)
这样的解释我懂了!再次感谢您!
BG8TFN-昆明
离线bg8tfn
只看该作者 8楼 发表于: 2017-08-23
回 husy 的帖子
husy:爬格子奖,叶老可以看成是你读书的时候的作文比赛,爬的格子越多,越有机会获奖。 (2017-08-22 22:48)
简单明了通俗易懂,感谢猫老!
[ 此帖被bg8tfn在2017-08-23 12:12重新编辑 ]
BG8TFN-昆明
只看该作者 9楼 发表于: 2017-08-23
方框奖,无敌了
离线bi4vip
只看该作者 10楼 发表于: 2017-08-23
学习了
VY 73 De BI4VIP
操作等级:C类
Email:bi4vip@126.com
https://www.qrz.com/db/bi4vip
离线bh1phl
只看该作者 11楼 发表于: 2017-08-25
通过不同的100个格子里面的电台。
神聊四大怪:
1. 呼号指配了就不能换,人死了三百年也不能重新指配,不过自己考了B考了C就得给换BD、BA,否则看不出辈分来
2. 7050是祖宗成法不能变,驻波大于1.1世界就会毁灭,绝对不能往7100以上挪
3. 业余无线电就是萧条了,FT8那叫虚假繁荣
4. 没执照用自编呼号最有理,别人不回卡片就是道德败坏,就是不会换位思考
离线BD7IHN
只看该作者 12楼 发表于: 2018-05-10
这个我已经够卡片了。到哪里申请?
73!
DE BD7IHN/赵向东
