  • 4723阅读
  • 0回复
FLEX-6000系列收发信机面板LED指示灯状态说明 [复制链接]
离线BA7NQ
只看楼主 倒序阅读 0楼 发表于: 2017-07-21
此部分内容摘自FLEX-6000系列的硬手册:
SOLID BRIGHT RED: Transmitting on PA
红色长亮(高亮度):电台处于发射状态
SOLID ORANGE: Transmitting on XVTR port with low power
橙色长亮:电台通过XVTR(变频器)端口在低功率发射
SOLID DIM RED: Transmit engaged, but transmit interlocks are not ready. Refer to SmartSDR documentation for description of transmit interlocks.
红色长亮(低亮度):电台处于发射状态,但由于发射互锁被锁定,实际没有发射。具体功能参考SmartSDR说明书中关于发射互锁的章节
SOLID PURPLE: Radio is performing a software update
紫色长亮:电台正在进行软件升级
SOLID GREEN: Radio is in receive mode
绿色长亮:电台处于接收状态
FLASHING RED: Flashing three blinks indicates radio software is not running
红色闪亮:三下三下闪动,表示电台内部的固件没有成功加载,此时电台不能正常使用
FLASHING GREEN: Radio is booting or loading firmware
绿色闪亮:电台正在启动,启动过程需要把固件加载
FLASHING WHITE: Radio is performing a reset to factory defaults
白色闪亮:电台正在进行恢复原厂默认设置
FLEX-6700 and FLEX-6500 Reset Procedure
With the radio powered off, press and hold down the “OK” button on the front panel of the radio. Momentarily press and release the power button to power on the radio. Continue holding in the OK button until the front display counts down to 0, the power LED starts flashing white and the “CALIBRATING...” message is displayed, then release the OK button. Allow the radio to continue booting normally.
FLEX-6300 Reset Procedure
With the radio powered off, press and hold down the power button for approximately 5 seconds until the Power LED flashes white, then release the power button. Allow the radio to continue booting normally.
