  • 1589阅读
  • 1回复
KX3 固件 MCU 2.36 / DSP 1.33, 12-23-2015 [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2015-12-26
KX3 Beta Firmware Revision
Please read KX3 Beta Firmware Instructions for   installing beta firmware.
Only the current production firmware releases can be downloaded by KX3 Utility automatically.
• 4-METER POWER OUTPUT IMPROVED: Changed IF band-pass filter configuration to increase drive level on 4 meters. This should improve 4-meter power output in cases where it was marginal due to filter rolloff.
ftp://ftp.elecraft.com/KX3/firmware/beta/kx3fw2r36.zip
离线电离层
只看该作者 1楼 发表于: 2015-12-26
跟我没关系,我没有4米模块!
